Coolant leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Deelandy, Dec 12, 2020.
  1. Dec 12, 2020 at 9:56 AM
    Deelandy
    Deelandy [OP] New Member
    2014 Tundra 4x4
    hi, i have 2014 Tundra with a coolant leak under my engine, i'm wondering what that hose is in the event i have to change it. which hose is that and what is the part it is connected to. thanks
  2. Dec 12, 2020 at 10:02 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I hope someone can help you with this issue.
  3. Dec 12, 2020 at 10:11 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Transmission cooler lines. It goes to the top of the engine snaking towards the front transmission cooler. Starter bolts are right behind that hose. There are like 3 brackets that hold it down, if you needed to know.. maybe TMI... LOL.
  4. Dec 12, 2020 at 11:27 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    If it was my truck, I would just compress and slip that stock clamp up the line and take a aftermarket screw clamp and install it where the stock one was. Then keep an eye on it.
  5. Dec 12, 2020 at 11:30 AM
    pickeledpigsfeet
    Kings & Icons
    Looking closer at the pic, someone has moved those clamps in the recent past. Any idea why? That might point to why it is leaking, thwy might have tore the hose when pulling it off the nipple.
    rebmo likes this.
  6. Dec 12, 2020 at 11:32 AM
    blackdemon_tt
    @pickeledpigsfeet beat me to it, lol It almost looks like that top hose has been pulled back somehow. The bottom one looks good. They both should be pushed all the way in.
    rebmo and pickeledpigsfeet like this.
  7. Dec 12, 2020 at 11:45 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I'd measure the rubber hose for length and diameter. Run to my nearest parts store and buy a new length of it and some appropriate coolant. Swap the hose and top of the coolant.
  8. Dec 12, 2020 at 12:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So....maybe I'm not visualizing this correctly, but on my truck with the Tow Package and transmission cooler, those lines have transmission fluid in them. Is it possible that the OP's truck may not have the Tow Package/transmission cooler? I would have to agree that what's pictured does indeed appear to be coolant.
    rebmo likes this.
  9. Dec 12, 2020 at 12:42 PM
    blackdemon_tt
    Yes that is correct... tow package does come with transmission cooler which is what that is. I do believe it is transmission fluid caked with dirt and other road debris...
    Wynnded[QUOTED] likes this.
  10. Dec 12, 2020 at 12:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Huh...I would've expected it to look....oilier.
  11. Dec 12, 2020 at 12:52 PM
    I'm seeing dried, crusted, pink coolant. I'd checked the water pump seal actually.
  12. Dec 12, 2020 at 12:55 PM
    blackdemon_tt
    LOL, Toyota Transmission fluid is red, lol.... although I have to admit the white crusted edges would lead me to believe it is actually coolant, which is the track you're on... I'm on the fence about it, but would say it is transmission fluid from the pictures.. if he tracks higher and sees crystalized residue higher, then it might be coolant.. Issue with pictures like these, and nothing against the OP, is that we get a 1D picture and we can probe as far as that goes, but no concrete answers...
    @Black Wolf I don't know about all that... since its more towards the back would have residue toward the skid plate more than the back of the engine... I'm talking from experience... mine blew and it never reached back there...
    Wynnded[QUOTED] and Black Wolf like this.
  13. Dec 12, 2020 at 12:59 PM
    I didn't realize tranny fluid was red too. Ha
    rebmo and blackdemon_tt[QUOTED] like this.
  14. Dec 12, 2020 at 1:11 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    That is the hockey puck transmission heater/cooler. Lines to it carry engine coolant (one showing drips). Directly above is the lines for transmission fluid going between the thermostat and the cooler in the front. Thermostat is sandwiched between the hockey puck and the transmission.
    Could be transmission fluid dripping down or engine coolant dripping directly from that hose.
    rebmo likes this.
  15. Dec 12, 2020 at 1:16 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Looks like coolant going to the puck, to me. . .and my eyes aint great. . Bur if I blow the pic up, I swear is see a slit in it. . .
  16. Dec 12, 2020 at 1:18 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
  17. Dec 12, 2020 at 1:19 PM
    blackdemon_tt
    some people may call that a clue, lol... (sarcasm)
  18. Dec 12, 2020 at 1:21 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Well. . .I could be looking at it wrong . . . But thats what it looks like to me. .lol
    blackdemon_tt[QUOTED] likes this.
  19. Dec 12, 2020 at 1:27 PM
    blackdemon_tt
    I'm not knocking on you... on the contrary, I can agree with you as usually a clean area with a dirty surrounding would indicate possible damage to that specific area. LOL
  20. Dec 12, 2020 at 1:30 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yep, I think you're right. If not a slit, then a tear. That's why it's wet around the defect, because it's leaking out of it. If it were leaking from the hose end, there would be a wet trail down to the low point.
    @Deelandy , those are formed hoses from Toyota. You can get cheaper bulk hose at the auto store, but it won't fit the same way. Your choice.
    Wynnded likes this.
  21. Dec 12, 2020 at 1:36 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Oh I know! Lol
  22. Dec 12, 2020 at 5:56 PM
    Deelandy
    2014 Tundra 4x4
    This makes sense because I recently had the starter changed, this was done without removing the manifold therefore these hose were removed. I'll try finding a replacement hose.
    Thanks!
  23. Dec 12, 2020 at 6:07 PM
    azs406
    azs406 New Member
    It is the trans cooler but on that set up, it takes coolant to the transmission instead of transmission fluid to the radiator.
  24. Dec 13, 2020 at 5:33 PM
    blackdemon_tt
    I know because I did it too... but I didn't remove the hoses, so chances might be the hose isn't properly pushed all the way in, or it is damaged at the spot previously pointed out or was damaged at either end which makes it no good... so you may need to do some probing...
  25. Jun 2, 2022 at 5:29 PM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Custom paint, wheels, icon suspension, JBA uppers, Katzkin interior, rigid lighting, Kicker System
    Did a simple hose replacement do the trick for you? I have the exact same leak, and I also did the starter recently. Although the hose appears in perfect condition even after removal. How did you remedy?
    HulkSmurf14 likes this.
