Payload way over recommended
Discussion in 'Towing & Hauling' started by Yota707, Dec 10, 2020.
  1. Dec 10, 2020 at 11:30 PM
    Yota707
    Yota707 [OP] New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Need some advice once again. I’m a Mobil detailer and I haul around a 200gal water tank as well as all my supplies. I have been doing this in this truck for 4 years and have never had a problem. I would estimate my payload is around 1800lb. Even with all that weight the truck isn’t bottomed out and it seems to handle it fairly well. I have been looking into getting air bags for the back. My question is would air bags pop under that amount of weight? Also looking for a simple air bag I have read on this forum a lot of guys recommended the Firestone airbags. What model or part number are you guys running? Any advice would be greatly appreciated.
    Banshee01 and Bigboitundra like this.
  2. Dec 11, 2020 at 12:30 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
  3. Dec 11, 2020 at 12:47 AM
    18" TRD Off Road Wheels
    Best advice? Get a trailer.
  4. Dec 11, 2020 at 3:27 AM
    Bammer
    Monroe, CT
    AGREED ! 200 Gallons X 8 lb/gall = 1600, plus you and all the other stuff. Trailer makes the best sense and way safer.
    Backslider, Pkahir12, Tundra2 and 5 others like this.
  5. Dec 11, 2020 at 3:44 AM
    A nice enclosed trailer would do wonders for you OP. 200 gallons x 8.33 lb/gall=1666 lbs. 1666 + 55 lbs for tank weight=1721 lbs. 1721 + 200 lbs for supplies and hoses= 1921 lbs. Add your weight and anything else not factory....damn.
    OldGuy03, Tundra2, JLS in WA and 7 others like this.
  6. Dec 11, 2020 at 3:45 AM
    timsp8
    NY
    I have airlift air bags and compressor to help level out my decked and cap. But yeah 1800 is too much for a tundra. Check your door sticker. Your payload is probably 1100-1300 lbs. Have to calculate for passengers too.
  7. Dec 11, 2020 at 8:45 AM
    Yota707
    Bay Area
    2015 Tundra TRD
    Thanks for the advice I try not to load the tank full all the time only if I have a big job. I been doing this for 4 years with this truck and has never been a problem but I know it’s not the safest option. I have considered the trailer option as well. Thanks all for the advice
  8. Dec 11, 2020 at 9:04 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Trailer or a used box truck and have your entire "office" laid out in it. I can see why a trailer may be difficult to cart around in neighborhoods. But the benefit is your truck becomes multi faceted again now that you don't have all that always in your bed.
    Yota707[OP] and Cpl_Punishment like this.
  9. Dec 11, 2020 at 9:25 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    You might have never had a problem, but you are pushing the limitations and stressing the suspension and associated drivetrain elements past what they're good for. They'll fail earlier, rather than later.
    If it were me I'd at least get: E rated tires, rear sway bar, stronger leaf springs, and quality 3" shocks to account for that load - and I'd still add an air bag or sumo spring. You need a tow ready setup for weight like that 100% of the time.
    Like others said, pulling that weight is the better option for the truck if you intend on keeping it for the long haul. Plus you'd be able to ditch that weight and have a usable truck bed. Bonus points for being more professional looking.
    Trailers are cheap and you can write it off - suspension too.
    You've got a sweet looking truck btw, I always dig the stormtrooper look - do the black headlight mod to tie it in ;)
  10. Dec 11, 2020 at 10:35 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    I just had a custom built bag setup installed in my suspension, got a local guy that specializes in that stuff. My truck has a 4" lift kit in the front and a 2" add a leaf in the rear, so with the bags deflated its stock height + the 2" lift leaf and fully inflated the bags can add about 4" more of lift on top of what I already have. I usually only run them to where the truck is level after whatever weight I have in or on the back though. I have on board air and a 5 gallon tank also with a custom control box to do everything inside the cab. Truck handles great hauling my roughly 10k pound tractor and trailer setup. Not sure that a rear sway bar is even needed anymore. Price was like $750 for everything.
    Bigboitundra, speckmon and Ckatz53 like this.
  11. Dec 11, 2020 at 4:00 PM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    Trailer
    Yota707[OP] and Rider0120 like this.
  12. Dec 12, 2020 at 7:21 AM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    I agree with all those that stated a trailer is the safest way to go. But when you are talking about "maximum payload" which is based directly of the Manufacturer's determined Gross Vehicle Weight Rating(GVWR), and not any industry standard like SAE J2807 which is specifically designed for Gross Combined Weight Rating (GCWR)and towing, it is a little more precarious.
    Manufacturers mostly estimate "maximum payload" by adding the estimated pin/hitch weight of the towing capacity for a particular vehicle to it's curb weight( dry weight of the vehicle). Payload is more legal liability than science. That being said, I take everyone of my setups through the CAT scales with full fluids to know that I am under the limits. Although, I am aware of no documented incident of someone being cited for being over payload on their 1/2 ton.
    Additionally, I appreciate when people become self-righteous about maintaining payloads under the manufacturers' limits for the safety and respect of others on the road, but they're probably some of the same people that fly by me at 85mph on the interstate with their boat behind them.
    When it comes to safety, I am actually more concerned about lighter vehicles (looking right at you F150 owners) with higher payload and towing capacities, but significantly lower curb weight/GVWR than the Tundra. It seems as though engineers are willing to throw out simple physics for purposes of passing an agility test. Talk about the tail wagging the dog?
    KTM753, AircareTundra, Gravy and 11 others like this.
  13. Dec 12, 2020 at 7:29 AM
    szabo101
    szabo101 New Member
    ED
    Additionally, I should add that I would be more concerned about not exceeding my Gross Axle Weight Rating (GAWR) for both front and rear axles as well as my load rating on my tires when it comes to hauling.
  14. Dec 12, 2020 at 6:16 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    This is all great advice I really appreciate everyone giving there advice. For right now I’m going to install the rear firestone airbags. I also plan on looking into a trailer after winter when my busy season picks up. Thanks again for the advice
  15. Dec 12, 2020 at 6:36 PM
    Wallygator
    I can't believe that your leaf springs are not touching the bump stops with that much weight in it.
  16. Dec 12, 2020 at 6:41 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Grab a 6x10. That's what I use for detailing and it works perfectly. Can find good deals on a used one if you're in a pinch.
  17. Dec 12, 2020 at 7:01 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    I will be looking at new trailers. Is that a enclosed trailer you use?
  18. Dec 12, 2020 at 7:02 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    No they don’t touch at all unless I go over a major bump
    Wallygator[QUOTED] likes this.
  19. Dec 12, 2020 at 7:06 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Gasp! You can't exceed the payload rating! Muh sticker! :eek::eek::eek:
    Clearly your truck is handling it just fine. Just get some bags. Working out of a trailer sucks ass.
    Gravy, Tundra2, TONKA TUNDRA and 5 others like this.
  20. Dec 12, 2020 at 7:09 PM
    Ckatz53
    Ckatz53 Newish
    MD
    Yup. V-nose flat top. Haven't had time to install a tank and hose reel setup as I work full-time and do this as a side gig. Plans are to reorganize the cabinets and drop a 100gal with compressor and accompanying hose reels this winter.
    Joss1799, smslavin and Cpl_Punishment like this.
  21. Dec 12, 2020 at 7:25 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    My suggestion. Sumo springs if you don't want to get a trailer. (I think I have a set I could sell somewhere around this place.) They worked well for me but that took away from my articulation so I switched to airbags with cradles.
    Edit: with airbags you never want to exceed a working pressure of 100psi (under load) I believe you will VERY quickly reach that limit and quickly got over. Even when I tow my 9K trailer I only air up to about 85psi to account for road bumps and such.
    Wallygator and szabo101 like this.
  22. Dec 13, 2020 at 8:24 AM
    Yota707
    Bay Area
    2015 Tundra TRD
    Nice set up
    Ckatz53[QUOTED] likes this.
  23. Dec 13, 2020 at 8:26 AM
    Yota707
    Bay Area
    2015 Tundra TRD
    Yeah with the firestone max is 100psi. I plan on not going over 75psi. Just looking for some help with the bags to help with the sag in the rear.
  24. Dec 13, 2020 at 8:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    This. You'd think you were planning murder by the way some people treat 1lb over ratings. If the truck is safe to you and seems fine I'd keep doing that. A truck within payload with an incompetent driver is a bigger issue than someone aware of how their vehicle handles. You've already been doing it for years, get some bags and keep on keeping on.
  25. Dec 13, 2020 at 8:45 AM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    I am not the most experienced with hauling heavy loads or towing trailers as I don't do either. One point I would make is the legal aspect of hauling or towing over payload. Had a friend of a friend on a motorcycle get run off the road by a douche in a truck, bounced off a rock wall and into the oncoming lane, and was run over by a guy in a truck hauling a camper trailer who was in the oncoming lane. The oncoming truck did everything correct, braking, and steering to not run a tire over him etc, drove exactly over him so he was hit by bumper, and some undercarriage stuff, but he lived to tell the tale (after extensive surgery and rehab of course). Had he been run over by the oncoming truck's wheel he would have died on the spot, so the oncoming driver did it right. None the less, he (and his rig) was heavily investigated by the police and the friend of a friend still had to sue him in order to somehow sue the guy who actually caused the incident and have his insurance cough up significant dollars (I don't fully understand all the legal stuff, but the point still applies). Had the oncoming guy, who did nothing wrong, not follow all safety rules and regulations (and payload limits) in regards to his own truck, he would have been more on the chopping block legally speaking even though outcome likely wouldn't have changed. Even though our trucks can handle a lot, working within the legal limits is critical for your own safety, both physically and legally, and the safety of others on the road. Just my 2 cents.
  26. Dec 13, 2020 at 8:59 AM
    Yota707
    Bay Area
    2015 Tundra TRD
    Yes I totally agree with this!
    Nm6300'asl likes this.
  27. Dec 13, 2020 at 9:03 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I never want to find out what towing a 13k load with an F150 feels like.
  28. Dec 13, 2020 at 9:26 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Don't worry, the tongue weight will exceed the payload long before you get there unless the trailer is loaded so far back that it would be unsafe behind any truck.
  29. Dec 13, 2020 at 9:47 AM
    Terndrerrr
    Music City
    6UR-FE
    Thats only 100lb over my 2012 4Runner’s payload. It’s hard for me to believe that is *really* unsafe in a Tundra.
    I mean, I understand the legal issues of getting into an accident while overloaded, but Toyota is such a conservative company, I don’t think you’re playing with everyone’s lives on the road if you’re overloaded but not riding on the bump stops with our trucks.
  30. Dec 13, 2020 at 9:52 AM
    Terndrerrr
    Music City
    6UR-FE
    A 13k trailer’s tongue weight is around 1300lbs (10%). Say it’s higher due to the way it’s loaded...say it’s 15%—that would be 1950 lbs, which is well under an ecoboost F150’s payload of 3250 lbs. All I’m saying is, I don’t want to be pushed around by that heavy of a load in that light of a truck even though Ford says it’s ok.
