NEED HELP 2nd Gen Tundra Crew Cab foldable back seats
Discussion in '2nd Gen Tundras (2007-2013)' started by antonio702, Dec 10, 2020.
  1. Dec 10, 2020 at 3:03 PM
    antonio702
    antonio702 [OP] New Member
    antonio
    Las Vegas, Nevada
    2007 White Tundra Crewmax Limited 5.7
    bone stock
    My back seat is folded down and doesn’t want to come back up I think there is something stuck on the bottom of the seat, how do I loosen the seat to see what’s holding it from folding it back up
  2. Dec 10, 2020 at 3:39 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Maybe try to unbolt from the floor to check under it. Or try to remove the black plastic off rear of seat , maybe something got disconnected. (Sorry if not much help, I have not encountered this issue)
  3. Dec 11, 2020 at 8:51 PM
    LillDragun
    LillDragun New Member
    Might be dumb and maybe you've tried it. But try placing pressure on the back of the seat downward while unlatching the lock?
  4. Dec 11, 2020 at 9:10 PM
    Mr. Wasteland
    Mr. Wasteland New Member
    2013 Tundra crewmax platinum
    You're pulling/disengaging the same lever/latch you did to fold it right?
