2016 CM 4X4 w/2" Lift: Will BFG 275/65/R20s Fit?
Discussion in 'Wheels & Tires' started by Badknees, Dec 10, 2020.
  1. Dec 10, 2020 at 9:20 AM
    Badknees
    Badknees [OP] New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Hello and Newbie here!
    I recently bought a 2016 1794 CM 4X4 and looking to do approx. 2" lift using stock TSS wheels so I don't need the diff. drop or rear spacers. If I use 5100's set in the middle or the 6112(?) at 1.9" setting, does anyone know if these tires will fit (diameter is 34.09")?
    Here's the same wheels I have on a very similar truck to mine:
  2. Dec 10, 2020 at 12:54 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Dec 10, 2020 at 1:08 PM
    Badknees
    Thanks Frank for the feedback.
    I did read the thread about maximum tire sizing and I saw the below thread which made me think they might fit OK:
    2018 Tundra - with 3/1 Ready Lift and Tires
    Discussion in 'Suspension' started by AG_2006, Apr 9, 2019.
    Also, not sure who this is, but really like the looks of his Tundra and similar to what I am looking to do but maybe a bit taller tires..
  4. Dec 10, 2020 at 1:09 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    That is the size I am getting. I took measurements after installing 6112s at 1.9. My truck came with 285/55/20. Figuring the larger diameter it appears they will clear mud flaps but closer on the little air dam in front of the tire.
  5. Dec 10, 2020 at 1:16 PM
    Badknees
    Great to know! Many Thanks for your help!
