Rearview Camera Cloudy.
Discussion in '2nd Gen Tundras (2007-2013)' started by CitySlicker0123, Apr 23, 2020.
  1. Apr 23, 2020 at 10:28 AM
    CitySlicker0123
    CitySlicker0123 [OP] New Member
    Charlotte, North Carolina
    2012 Grey Tundra TRD
    I just bought a 2012 Tundra and when I test drove it, I noticed the camera looked foggy, but I figured I would wipe it when I took it home. I did and it is still cloudy and actually you can't see the warning lines. Any help would be appreciated....and if I need to buy anything to replace it, let me know.
    Thx.
  2. Apr 23, 2020 at 11:25 AM
    Is the lens actually clear and not frosted over?
  3. Apr 23, 2020 at 11:37 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Mine gets cloudy and needs some soap and water. Water alone won’t cut it. The guidelines I’m not sure as I have a third gen. Are the warning lines there but distorted or are they completely gone? Don’t quote me but I thought the warning lines could be toggled on and off with the headunit.
    CitySlicker0123[OP] likes this.
  4. Apr 23, 2020 at 3:27 PM
    CitySlicker0123
    The lens is clear
  5. Apr 23, 2020 at 3:28 PM
    CitySlicker0123
    The lines are there, but the background is mainly white, cloudy and you can make out a little of what’s behind the truck.
  6. Apr 23, 2020 at 3:38 PM
    Tundyfundy
    Bay Area, CA
  7. Apr 23, 2020 at 3:39 PM
    Tundyfundy
    Bay Area, CA
  8. Apr 23, 2020 at 6:15 PM
    CitySlicker0123
    I don’t have the head unit. It was replaced with a KENWOOD prior to me buying the truck. I will probably end up buying a new camera from the links you sent. Thx man appreciate it.
    Tundyfundy[QUOTED] likes this.
  9. Apr 30, 2020 at 7:23 PM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    I find the 2nd gen cameras horrible. Don't seem to be any good fix. Was thinking about a new head unit but seems like that doesn't work either. Let us know if you find one!
  10. Dec 10, 2020 at 9:54 AM
    Redman333
    Redman333 New Member
    Jared
    Tundra
    Yes
    Any update on this, I seem to have the exact same issue. I have a 2012 crew max with a keyword head unit and the backup camera is somewhat useable but very cloudy even though I’ve cleaned the exterior of the camera very well.
  11. Dec 10, 2020 at 10:08 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I had same issue. I bought a replacement from Ebay for around $100. It is plug and play, fits like the factory one. It works good now.
    Maxi13 likes this.
  12. Dec 10, 2020 at 10:27 AM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    Nudding yet
    So do you still have the factory HU or is your aftermarket? If factory, can you give a description of how much it improved? I had a 2017 Taco and the cam was great. My wife's honda is really good, probably better than the Taco was, even at night. Also are there guidance lines, or is that something that is in the HU? Thanks for reporting!
  13. Dec 10, 2020 at 11:10 AM
    jalam321
    jalam321 New Member
    I still have factory JBL navigation HU right now. It's probably slightly better than the factory but not by much. Definitely still not as good as newer cars. But it's good enough for me to see what's behind me. I had aftermarket pioneer HU and camera in my other Tundra, and was better than factory for sure.
    Maxi13 likes this.
