TPMS Experience
Discussion in 'Wheels & Tires' started by Coffee*8), Oct 18, 2020.
  1. Nov 16, 2020 at 8:22 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I have found a 2-3 lb diff between the tpms and my manual gauges and the reading on my compressor.
  2. Nov 16, 2020 at 8:38 AM
    timsp8
    NY
    2-3 lbs isn’t that much. Mine change that much depending on the outside temp.
  3. Nov 16, 2020 at 9:00 AM
    Melikeymy beer
    Muscogee Nation
    Yeah, it's not like we're racing Indy, lol.
    timsp8[QUOTED] likes this.
  4. Nov 19, 2020 at 4:33 AM
    jtorres83071
    jtorres83071 NY TRD Pro
    Jay
    2020 Tundra TRD Pro
    Yes, I believe I followed the instructions to a T. I'm going to try again but it's tricky with the 3 button presses.
  5. Nov 19, 2020 at 5:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My experience with TPMS is to replace them with standard valve stems, and use a quality air pressure gauge to check the air pressure in my tires.
    Bammer likes this.
  6. Nov 21, 2020 at 6:30 AM
    jtorres83071
    Jay
    2020 Tundra TRD Pro
    Fixed it!! I had to turn ‘on’ the accessories and not have the truck running initially. Then drove for 10 minutes and now the pressures are displayed !!!
    thomasbus337 likes this.
  7. Dec 8, 2020 at 11:48 AM
    jlsusa
    jlsusa New Member
    Jon
    2020 Black Limited Crew
    Thanks for the follow-up! I have the same problem after installing winter tires with new rims and new non-Toyota sensors. I've been back to Costco twice and the sensors are good and "registered" to the truck, but after 500 miles and multiple attempts with the the "three push" reset it still isn't working. I'll try the "accessories on" trick after work. Finger crossed. It's super annoying that this isn't easier!
  8. Dec 8, 2020 at 3:46 PM
    jtorres83071
    Jay
    2020 Tundra TRD Pro
    Yeah, I was frustrated because I thought I was following the instructions. But the truck should not be turned on, but only in accessories when pressing the tire pressure sensor reset button 3 times. That’s what worked for me.
