  1. Dec 7, 2020 at 5:52 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I can probably take a decent guess at how it got the name:monocle:
  2. Dec 7, 2020 at 6:07 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    You totally made me spit out my beer. Party foul, but worth it.
  3. Dec 7, 2020 at 7:12 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    So you installed LED's in a halogen housing? Looks like it's spilling a ton of light (translation: blinding the shit out of oncoming drivers).
  4. Dec 7, 2020 at 7:12 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    I c
    I called them today. They offered 5% off or an exchange. I opted for the exchange. I’ll have to send it back this week and wait for the return to be processed and a new one shipped.
    Hopefully I have better luck with the replacement.
    3xYOTA and bocabasser[QUOTED] like this.
  5. Dec 7, 2020 at 7:16 PM
    :fingerscrossed: :thumbsup:
    aark12 likes this.
  6. Dec 7, 2020 at 7:21 PM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    How much were they discounted?
  7. Dec 7, 2020 at 7:35 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    as mentioned, you actually can remove it without taking off the whole silver surround, just need some patience and a small screwdriver (or something similar) to push tabs in...I opted to just remove the surround when I had entire dash apart for the 107th time...lol...when taking 4x4 knob apart to swap it, just pay attention to the order/orientation of the small parts, it’ll make your life so much easier when putting back together
    AJT Design 4x4 Knob Installation on Toyota Tundra
    https://youtu.be/YeYsHb1vHdE
    It’s nowhere near as bad as it looks!...lol...the dash is honestly not bad at all, and the wheel is super easy
    Toyota Tundra Disassembly and Removal of Dash
    https://youtu.be/xu1C1AapaAI
    How To Remove Wheel Trim For Customizing (2020 Toyota Tundra)
    https://youtu.be/fRILgZG2QAs
    GAknight, aark12, mgm16trdpro and 2 others like this.
  8. Dec 7, 2020 at 7:41 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Maybe I'm just weird but those welds along the inside of the rail look... well, just look.
  9. Dec 7, 2020 at 8:18 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Yeah I was able to get it done without removing the whole piece, and you're right about the small pieces inside. I put it on wrong and had to redo it, the way it was spinning was the opposite way. I did use your videos for most of the AJT install. My interior doesn't have a hint of chrome anymore.
  10. Dec 7, 2020 at 8:23 PM
    2020Platinum
    Patrick
    Northeast PA
    Nice, looks good man!...I still have to cover the lock on my glove compartment, I keep forgetting about that little spot
    Alexstundra and jr1016[QUOTED] like this.
  11. Dec 7, 2020 at 8:34 PM
    OnespeedTRD
    Don
    San Diego
    Take the molle mount plate out of the equation. The seat jackers raise the front of the seat 1" to give it a little more rearward tilt.
    When I test drove a Tundra for the first time one of the first things I noticed was the seat was very flat. Even with the power seats lifted all the way up in the front and all the way down in the back it still felt like I was sliding off the front of the seat.
    My other daily driver was an E55, with a very low and down-in-the-seat feel and the Tundra seat just felt uncomfortable in comparison. Apparently this is a common complaint in the Tacoma as well. I thought about just putting some spacers or something under the front seat brackets to raise it up (I did this a long time ago in an old Dodge) but after looking at these I don't think just a spacer would be safe. The front brackets have a guide pin and a recessed area that makes this design a necessity to get a solid mount.
    These raise the front of the seat enough to make a difference, but in no way make it harder to reach the pedals or be too crowded between the steering wheel and your legs. With these installed I still have the front all the way up and the rear all the way down and its way better than before.
    The molle plate is just an add on since I was going to do the seat jackers anyways. You can mount just about anything to it that has a clip or strap of some sort, stuff you'd normally have in your door pockets or center console. A flashlight and an IFAK are my initial thoughts. Would also be an ideal spot for a fire extinguisher. It's right there inside the door, pretty easy to reach if you're already out of the truck, and right there on your way out if you're sitting inside, but not really in the way of your feet unless you sit with your legs straight down at a 90* angle.
    Like I said, the seat jackers are what I was after... the mounting plate is just something I'll try out and see if it works for me.
  12. Dec 7, 2020 at 8:35 PM
    OnespeedTRD
    Don
    San Diego
    Huh?
  13. Dec 7, 2020 at 8:41 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Actually I see an option for a seat jacker that was not an option when I installed mine. Maybe that’s a new thing
  14. Dec 7, 2020 at 9:05 PM
    OnespeedTRD
    Don
    San Diego
    Yeah, they have mounts for just the panel if that's all you want, but these go under the seat brackets to raise it up 1".
    gabex35[QUOTED] likes this.
  15. Dec 8, 2020 at 8:01 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Early Christmas present from the S.O. Went ahead and installed it rather than wait, it certainly it not going to be any warmer after Christmas.
    As you have probably read here on the forum, adding the rear bar is a great and noticeable upgrade. Probably the most cost effective (best bang for the buck) upgradesway.jpg for the Tundra. Significantly better handling for @$220 and half an hour of your time.
  16. Dec 8, 2020 at 9:08 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    How difficult was the install? Scale 1-5 5 being difficult
  17. Dec 8, 2020 at 9:10 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    everyone i've seen do it says it pretty simple. but if he did it in half an hour....i'd say a 1
    ElNopal likes this.
  18. Dec 8, 2020 at 9:53 AM
    frichco228
    Frank
    Virginia
    It is a 1. Simple install. It helps to have a 2nd set of hands but it can be installed alone. This video is a good install vid with some great tips.
    https://www.youtube.com/watch?v=cZdVjObkTLs
  19. Dec 8, 2020 at 10:00 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Difficult depends on who you are. For me it was about a 3/5. Took me at least an hour, possibly longer. Torquing those U-bolts took forever for them to torque to the proper setting. I still need to go back and re-torque to make sure they haven't lost too much since the original install.
  20. Dec 8, 2020 at 10:02 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Driving up my driveway last night.
  21. Dec 8, 2020 at 10:08 AM
    RBB
    RBB Member
    Vancouver Island B.C. Canada
    Barcelona Red Mettalic 2020 Tundra TRD off road
    Blackout badges, tailgate insert, sill protectors
    IMG_20201205_132126.jpgGave her a bath, then it rained!
  22. Dec 8, 2020 at 11:41 AM
    frichco228
    Frank
    Virginia
    Oh, I almost forgot. Built a bed divider out of some extra framing wood I had. Works fine, fits great and $0 cost since I had the material.
  23. Dec 8, 2020 at 11:42 AM
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    Thanks. I guess I have just never experienced this in either of my Tundras. If I put the front seat edge fully down, I feel like it's too flat or tilted forward, but I only have to raise it a centimeter before if feel comfortable, and I have it raised about 2cm from full flat, with probably another 1-2 cm up upward distance left. That's why this mod makes no sense to me - for me it's easily fixable with the seat control rather than installing something under the front seat bracket. With a seat jacker on, I imagine if I used the front seat control to raise the lip, I would feel like I was being folded in half. ;) Maybe my butt is different than everyone else's? LOL
  24. Dec 8, 2020 at 12:00 PM
    bocabasser
    bocabasser New Member
    2019 cm limited
    6 inch ready lift w/coilovers 20x10 fuel couplers with 35 ridge grapps
    at least they are owning it. if you could give me the number that would be great. I can't install it if it looks like that. ill send mine back as well.
    RobertD likes this.
  25. Dec 8, 2020 at 12:06 PM
    PNW_Husky
    Installed my Desert Eagle Catalytic Converter Skid Plate. Shortly followed up by my aluminum RCI skid (not pictured).
  26. Dec 8, 2020 at 1:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Great. Something else I didn't know I might want/need. :spending:
  27. Dec 8, 2020 at 1:18 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Started de-chroming the interior with a combination of Tufskinz matte black and AJT Designs black. Didn’t tackle the 4WD & climate control knobs yet. Planning to tear apart the dash when my anytimebackupcamera.com kit shows up.
    I wish there was a de-silver kit. Thinking of using matte or satin black vinyl wrap on the silver pieces. 32F2A929-C213-4649-B00C-956E5F066610.jpgF0506EED-60F0-4914-AE9A-1F097739EB45.jpg39AFF7AA-3680-48ED-B44F-60F53BF31D5E.jpgDF59B555-0976-48B6-9E37-7E7CC0409BBA.jpg
  28. Dec 8, 2020 at 1:28 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    i want to do this, but I've seen so many people hate on them.
  29. Dec 8, 2020 at 1:33 PM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    I have a Galaxy Note 20 Ultra and it fits snug
    Ostrich[QUOTED] likes this.
  30. Dec 8, 2020 at 1:42 PM
    RobertD
    Robert
    DFW, Texas
    Where have people been hating on this? Most everyone on here loves the rear sway bar.
    The front sway bar has a mixed feeling about it. Most agree it is an upgrade from the stock front bar but most don't think the improvement is worth the cost and rather spend that on other mods.
    If you can PM me a link to where people hate on them, I'm curious what they are saying since that is the opposites of everything I've seen.
    Edit: had typo...
