Low Coolant?
Discussion in '2nd Gen Tundras (2007-2013)' started by ICECOLDBEER, Dec 7, 2020.
  1. Dec 7, 2020 at 4:13 PM
    ICECOLDBEER
    ICECOLDBEER [OP] New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    So I was filling up with washer fluid and noticed my coolant is low. Its a little bit below the low mark on the reservoir. Wondering if I should be worried? I haven't really been keeping an eye on it so no idea when it got low. I know two years ago when I bought it, it had more lol.
    No major obvious signs of a leak. It gets parked in the garage usually so I would notice puddles on the floor. Other threads said to check the water pump. I'm not exactly sure where that is right now. It hasn't over heated or anything. Truck runs great. Oil level is fine and looks clean.
    It did get cold here the last month or so and I have been driving more than usual.
    I guess maybe just top it up and see what happens. The coolant smells a little rotten to me. Probably wouldn't hurt to drain the whole thing.
    Should I get the OEM Toyota Fluid or as long as it is pink?
    Thanks guys :)
  2. Dec 7, 2020 at 4:28 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yeah Toyota Long Life is best.
    So how Old is radiator? Tank may be leaking really slowly but also check the overflow hose, they get old, crack..
  3. Dec 7, 2020 at 4:29 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    OEM. Check your hoses and the bottom of that radiator ASAP.
  4. Dec 7, 2020 at 4:44 PM
    ICECOLDBEER
    Assuming original radiator. Where is the over flow hose? I am a total noob with radiators.
  5. Dec 7, 2020 at 4:49 PM
    ICECOLDBEER
  6. Dec 7, 2020 at 4:58 PM
    ICECOLDBEER
    I think Ill be okay. Fill her up and see what happens.
    Filthyphil likes this.
  7. Dec 7, 2020 at 6:21 PM
    FXFormat
    FXFormat New Member
    Waterpump likes to weep on these trucks, you'll see a trail of pink crust accumulating underneath the fan clutch area, might have to pull skid plate to see it.
  8. Dec 7, 2020 at 6:25 PM
    ICECOLDBEER
    Hmm Ill go poke around at it again. I have the skid plate off. I think I know what the water pump looks like now thanks to youtube.
  9. Dec 8, 2020 at 6:02 AM
    Dr_Al
    Dr_Al New Member
    Al
    Did you see what level the fluid is in the radiator? What does the fluid look like? Does it look like strawberry milkshake? I would fill it back up and see what happens. But I would check it after one use to see if the fluid is dropping. Since you haven't looked at the level in 2 years this could be a gradual think that's no big deal or it could of started the day before you opened the hood. If the fluid is like a milkshake you could have a bad trans cooler (a big problem) and your fluid is mixing with the tranny fluid. While unlikely if this is the case you need to identify it immediately or you will damage the transmission.
    ICECOLDBEER[OP] likes this.
  10. Dec 8, 2020 at 7:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Replace that lower clamp. It'll be clamping fine until it doesn't, then you're going to have a big problem. If you remove the hose to replace the clamp (OEM spring clamp), drain the coolant from block and radiator, flush the system, and replace the coolant.
    Otherwise, top it off and observe closely the overflow reservoir level and temp gauge. If the reservoir level starts dropping, it's probably because the engine is getting hot enough to expand coolant into the reservoir until the reservoir overflows to the ground. Once you've lost enough coolant from the system that the radiator is sucking air back in, the radiator level will be dropping. The risk of extreme overheating and engine damage is then increasing as time passes and more coolant is lost.
  11. Dec 8, 2020 at 11:38 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    You might also consider pressure testing the cooling system. That would eliminate worry about anything major being involved.
  12. Dec 8, 2020 at 8:46 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    This. Just did mine...
  13. Dec 8, 2020 at 9:04 PM
    ICECOLDBEER
    Was it a slow leak?
  14. Dec 9, 2020 at 4:27 AM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Yes. Was weeping past the first seal. It's made like that so it doesn't kill the bearing and strand you.
