Tire size after a 3" lift
Discussion in 'New Member Introductions' started by Dwayne P, Dec 6, 2020.
  1. Dec 6, 2020 at 4:12 AM
    Dwayne P
    Dwayne P [OP] New Member
    2018 Toyota Tundra TRD Sports
    Hi
    I'm a new Tundra owner, I bought a 2018 TRD Sports with 12600miles. I bought a 3" lift kit.
    I did some checks and found i can run 305 55 20.
    Can anyone confirm if this info is correct?
    Prostar 190 and YardBird like this.
  2. Dec 6, 2020 at 5:11 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
  3. Dec 6, 2020 at 5:27 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    yes, the 305/55/20 will fit, however, a 33" tire is going to look small on a 3" lift. instead, i recommend that you run a larger tire such as: 295/60/20, 35x12.5, or a 295/65/20. the 295/60/20 (34") will fit with a tiny bit of plastic trimming and the other 2 will require more trimming. running those larger tires will also depend your wheel offset. if you keep your offset higher than +18mm, you will be fine.
    here is what i did to fit the 295/60/20 tires:
    https://www.tundras.com/threads/trimming-front-bumper-liner-and-mudflaps.63755/
    here are 34's on a 3 inch lift:
    good luck :)
  4. Dec 6, 2020 at 6:03 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer brah!!
    Netmonkey[QUOTED] likes this.
  5. Dec 6, 2020 at 6:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    285/65/20 is another awesome size
  6. Dec 6, 2020 at 7:04 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Dec 6, 2020 at 12:52 PM
    Welcome from Ohio
    naterwt likes this.
  8. Dec 6, 2020 at 3:20 PM
  9. Dec 6, 2020 at 3:30 PM
    naterwt
    naterwt New Member
    Nate
    2017 crew max
    Bone stock but not for long
    jmeza99 likes this.
  10. Dec 6, 2020 at 3:32 PM
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Go with 35s...or else you’ll be buying them 6 months from now...don’t ask me how I know!
    naterwt likes this.
  11. Dec 6, 2020 at 7:26 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  12. Dec 6, 2020 at 8:57 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. Dec 7, 2020 at 9:03 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA
  14. Dec 9, 2020 at 9:43 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  15. Feb 26, 2021 at 3:10 PM
    Dwayne P
    I've lifted my truck with the rough country 3" lift kit..Installed yokohama 295/65/20
    at full turn the tire touches the chassis..any suggestions on what can be done.
    mattgecko likes this.
  16. Feb 26, 2021 at 3:39 PM
    Netmonkey
    Georgetown, TX
    is it touching the body mount? If so, you can have the body mount chop done. It’s probably a couple hundred bucks.
  17. Feb 26, 2021 at 3:47 PM
    Where is it hitting...at the bottom of the wheel well right behind the tire? If so you would need a body mount chop.
  18. Feb 26, 2021 at 6:48 PM
    Dwayne P
    thanks a million guys
