Radiator Leak Questions - Real Time Help Needed
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Patriot 1776, Dec 5, 2020.
  1. Dec 5, 2020 at 1:29 PM
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I’m 200 miles from home on vacation and realized I have a hole in my radiator. It’s enough to drip a drop about every 3-4 seconds. There doesn’t appear to be any damage to it. It’s about 4” from the top of the radiator. It never got hot (I watched the gauge closely)95F2B947-AE7F-44C1-9424-31DC73109A38.jpg and I noticed it when I walked back up to the truck and saw it dripping. It left a pretty good puddle where it had been parked for a few hours that I didn’t notice but found after I got back from the 15 mile trip I was on when I discovered the leak.
    Is this a common Tundra problem?
    Is the radiator covered under the 60K drivetrain warranty?
    With it running, will it quit leaking after it gets below this point or will it pressurize and push all the coolant out the pinhole?
    Think I can make it back the 200 miles as long as I pay attention to the temp gauge and top off every so often?
    Thanks!
  2. Dec 5, 2020 at 1:43 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any chance you're close to an autozone or o'Reilly? If it were me I'd try to swap it out before heading home. Most will have loaner tools available, although you might need to buy some supplies to tackle a swap in the parking lot.
  3. Dec 5, 2020 at 5:45 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Go to an auto parts store and get some stop leak for rads. Only use enough to stop the leak. When you get home give a call to the dealer and see if it's covered. It' not a common problem but can happen on older trucks.
  4. Dec 5, 2020 at 7:00 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I appreciate the input but I’m not putting that in my truck. I’d rather have it towed 200 miles than contaminate my engine with that. That’s next to impossible to get completely out, even with multiple flushed, and causes long term clogging.
    I got 2 jugs of Zerex Asian coolant. I’m going to fill it up before I leave in the morning, take a couple jugs of water, watch the temp gauge and hope for the best. If I run into issues I can’t resolve then I’ll have it towed.
  5. Dec 5, 2020 at 7:05 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Agreed on not putting that in your vehicle. Extra coolant, extra water, extra eyes on the gauge. If you can stand it in the cab put the heat on and try to keep the truck moving.
    Good luck!
  6. Dec 5, 2020 at 7:14 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you get the rad seal that uses small aluminum particales it wont harm anything. It moves around in the coolant until it passes through the hole and plugs it. There are some products that can cause issues but the stuff I'm talking about is a dry product in a small tube. Flush the system when the rad is changed. Adding coolant will work if you keep am eye on it but maybe pick up some in case that plan doesn't work. Cheap back up.
  7. Dec 5, 2020 at 7:19 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    I wouldn't rely on the factory temp gauge for quick and or accurate feedback
    Remember when 2nd gen tundras had trans temp gauges that never moved until they were overheated anyways?
    Or gas gauges that have delays that say 1/2 full when the pump clicks off?
    An OBD reader gauge would give you better resolution and data you can trust.
    Honestly 200miles is only like 3 hours of driving, I would top it off and make a pit stop 30 mins in and pop the hood and check it. if the resivoir is empty, you know it will be a long trip home with alot of stops.
    The problem with relying on the temp gauge is that the coolant resivoir will have to completely drain + the coolant system will drain to the point it can't cycle fluid. (IE impact cooling ability). Then its a rush to pull-over get the truck shutoff to avoid overheating and re-fill system.
    The Patriot 1776[OP] likes this.
  8. Dec 5, 2020 at 10:08 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Deal is, reservoir hasn’t dropped at all. I’m assuming because, for it to drop, the pressure has to pull vacuum and pull from the reservoir. It can’t pull on the resi if there’s a hole because it’ll pull from that hole.
    Make sense?
    Am I correct I. That thinking?
    Thanks.
  9. Dec 5, 2020 at 11:21 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's correct. When the coolant cools and contracts it pull in coolant from the reservoir. With the hole the air is just being drawn in. If you start loosing a lot of coolant you could leave the rad cap on the first notch so it doesn't build pressure. This will help slow the leak.
    Make sure there is no pressure in the system before opening the rad cap buy squeezing the upper rad hose.
  10. Dec 6, 2020 at 11:53 AM
    The Patriot 1776
    '16 TSS CM 4x4
    Well, made it home without any incidents. It took 1/3 gallon to fill it up before we left. Drove 1:15 and added another 1/3. Drove another hour and added another 1/3 and filled the reservoir. Made it home without adding any more. It will now probably take another 1/3 gallon. As soon as I pour it in it starts leaking then I guess quits when it gets down to where the whole is. This worked out a lot better than I thought it would. Thanks for the input fellas.
    Does Denso make the factory radiator for the Tundra? Online dealers want $300 for it but I’d imagine I can find it cheaper. I won’t use a cheap Chinese one from parts store.
    Anybody have a good write up on R/R the radiator? I’ve done them before but never on a Tundra. I might add, due to my bumper, I can’t remove my grill and I hope that doesn’t present a problem in removal.
    JLS in WA and AZTundra like this.
  11. Dec 6, 2020 at 11:55 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check Napa for a rad. I believe they have a lifetime warranty.
  12. Dec 6, 2020 at 11:56 AM
    AZTundra
    Paul
    Phoenix, AZ
    For a little over $300 you can do the Koyo aluminum radiator. https://shop.redline360.com/products/koyo-aluminum-radiator-toyota-tundra-2007-2016-hh012076
    yoshi82 likes this.
  13. Dec 6, 2020 at 11:58 AM
    The Patriot 1776
    '16 TSS CM 4x4
    While that’s a beaut I’d prefer not to spend that much. That one is $381 with shipping. I have a good, local radiator shop and I’m going to see what they repair mine for first. Until then, I’ll be looking for a cheaper Koyo or CFS (I think it’s CFS I’m thinking of).
    AZTundra[QUOTED] likes this.
  14. Dec 6, 2020 at 12:05 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
  15. Dec 6, 2020 at 12:22 PM
    AZTundra
    Paul
    Phoenix, AZ
  16. Dec 6, 2020 at 1:09 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    If its in the aluminum and not too close to the plastic I'd get it repaired. Got mine repaired when I accidentally put a hole in it replacing my water pump, cost me 30 bucks and he cleaned it and made it look like new as well. Took him about 2 or 3 hours
  17. Dec 6, 2020 at 2:26 PM
    TheBeast
    TheBeast The Beach
    oem is best imo
    Ruggybuggy likes this.
  18. Dec 6, 2020 at 2:30 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Is OEM Koyo or Denso? My factory one says Made in Mexico so I doubt it’s the best. It has a familiar looking D on it which I think is Denso.
  19. Dec 6, 2020 at 2:31 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wow, guy works for less than $15/hour and that's before material costs.
    Sumo91[QUOTED] likes this.
  20. Dec 6, 2020 at 4:04 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Got it out. Would’ve been a 15 minute job but I couldn’t remove the grill due to the bumper. Took about 45 minutes. Hole is on the front of the radiator but in this area, it’s 100% protected by other stuff. Idk how this happened.
    491C1EE8-60E3-40E9-BDEC-521D7E762EFC.jpg AE359DF0-63BB-48CF-856F-B5E0A5E35A51.jpg
  21. Dec 6, 2020 at 4:22 PM
    Sumo91
    TN
    I think the hole itself only took a few minutes, but leaving it in the cleaning solution probably took the longest. I just ran my errands around town and came back 2 or 3 hours later and it was done. Not exactly sure how long it took him to do it, but he didn't have any other work going on, it was a one man show when I went there. Still holding up good a year later
    Ruggybuggy[QUOTED] likes this.
  22. Dec 6, 2020 at 4:23 PM
    Sumo91
    TN
    That is 100% repairable. Id repair it if it was my radiator.
  23. Dec 6, 2020 at 4:33 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I'm taking it to a radiator shop in the morning. Hopefully they can knock it out quickly! I'm @ a loss as to how this even happened. Other than this & it being a bit dusty, looks pretty good for 58K miles.
  24. Dec 6, 2020 at 7:53 PM
    Sumo91
    TN
    Is there anything that the radiator could have hit, that is attached to the truck that could have done this? Like hitting a big pothole shifting the radiator forward and it hitting a bolt or something? Had it happen on an 91 f150 I had. Glad to hear you're getting it repaired instead of replaced! Too much stuff that could be fixed is just thrown away these days.
  25. Dec 6, 2020 at 7:57 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I've thought about that & looked there area over well. There's no bolts in that area & no way a rock/bug could hit there. The closest thing to it is the 'cage' the radiator is bolted to. The area around it is flat & could've even touch the radiator @ this spot.
  26. Dec 6, 2020 at 8:04 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    OEM Denso rad off Amazon is $130ish dollars. Can swap easily,since you already got yours out clearly you know that already. That one looks to be fixable. Mine the plastic end cap cracked. Easy fix
  27. Dec 6, 2020 at 8:44 PM
    Sumo91
    TN
    Hmm that's strange.... maybe its related to the transmission cooler, and thats why toyota removed them.... :rofl: but in all seriousness I'm not sure how it could have happened. Rocks thrown from the road can and do wind up in strange places, ill take a look at my radiator tomorrow to see if I can come up with a conspiracy theory.....I mean, uhhh, a probable cause :thumbsup:
  28. Dec 7, 2020 at 11:52 AM
    The Patriot 1776
    '16 TSS CM 4x4
    Rad. is at the shop now. He’s going to clean it, pressure test it and fix any/all holes in case there’s one somewhere I’ll I never saw. He thought it was weird it got a hole there too. I walked up and he said “Toyota radiator?”. He could tell from 20’ away what it went to. He said he doesn’t know why Toyota uses such a basic radiator for such an overbuilt truck.
  29. Dec 7, 2020 at 11:55 AM
    The Patriot 1776
    '16 TSS CM 4x4
    He just called and said it’s ready. Just the one hole. I dropped it off at 9:30 and it’s ready at 2:00. Total cost : $30.
    Hooray!
    He said it’s 100% ready to go flushed, cleaned, brazed. $30 is a steal!
    Sumo91, Piney and realprotundra like this.
  30. Dec 7, 2020 at 1:22 PM
    Sumo91
    TN
    Thats great to hear! Glad it worked out for you
