Help: Failed inspection — need Raptor LED covers
Discussion in '2.5 Gen Tundras (2014-2021)' started by SLAPPYROOTZ, Dec 5, 2020.
  1. Dec 5, 2020 at 8:26 AM
    SLAPPYROOTZ
    SLAPPYROOTZ [OP] New Member
    Slap
    Hey all. I just bought my first Tundra, a super white ‘15 Crewmax SR5 TRD...
    Update: found a fix with the second largest grommet in this set:
    https://www.amazon.com/gp/aw/d/B07ZPNLHKX?psc=1&ref=ppx_pop_mob_b_asin_title
    The previous owner (cleanly) installed three LED lights above the grill that illuminate when the lows are on. State law only allows for four lights to be on at any one time, hence the failed inspection. Shop says I need to properly cover or remove them. Obviously, I’d prefer to keep them.
    The LEDs and their shrouds are circular and are roughly 7/8 of an inch. I tried rubber furniture caps from Home Depot but they weren’t inconspicuous/secure enough.
    I have a TRD Pro grill so if covering the lights themselves isn’t feasible, I was thinking of covering the small rectangular housing entirely with something.
    Any suggestions? Thanks!
    ETA: found a fix with the second largest grommet in this set:
  2. Dec 5, 2020 at 8:33 AM
    GODZILLA Ask me about my hot doc
    So strange. I wouldn't have thought that marker lights counted toward the 4 lights bit. Do they make Raptor owners remove/cover them? It sounds like BS to me, but who knows with how much authority they are flexing these days.
    Pictures would help a ton.
    Edit: Wait, are these marker lights?
  3. Dec 5, 2020 at 8:33 AM
    biebs96
    PA
    What state are you in?
    I would just wire them to a switch. Leave it off for inspection, then on full time after.
  4. Dec 5, 2020 at 8:35 AM
    Pull the fuse for the inspection.
  5. Dec 5, 2020 at 8:42 AM
    SLAPPYROOTZ
    Slap
    Pic added. I’m in VA.
    If lights are mounted, they must work so pulling fuse for inspection won’t work.
    I wouldn’t mind having it wired it to a switch but I’m not entirely sure how to do so. From what I’ve read, I’d have to run the wiring from the fuse through the firewall, back to the switch, and then back to the lights.
  6. Dec 5, 2020 at 8:45 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Go to a dif shop that does inspections. Exactly they don’t pass any Ford raptors?
  7. Dec 5, 2020 at 8:46 AM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Low cost solution: cover them with electrical tape.
  8. Dec 5, 2020 at 8:49 AM
    SLAPPYROOTZ
    Slap
    I asked about LED blackout stickers and tape but the shop said no...
    I’m thinking I’ll try my luck at another inspection location.
  9. Dec 5, 2020 at 8:50 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I live in VA too and they can be a real PITA regarding lights. Besides failing inspection, county and state police will ticket you if you have more than 4 lights running on the front of the vehicle- so if you have headlights and fogs- you are already at max. Any other lights such as off road lights, ditch lights, light bars must be covered and not used on the roads.
    Saltyhero13 likes this.
  10. Dec 5, 2020 at 8:52 AM
    SLAPPYROOTZ
    Slap
    Yep, it’s brutal. I do have a pair of Rigids in there as well.
    And I have to cover the light bar for the inspection, too, but it’s done easily with a factory cover. The problem is they don’t make “factory” covers for the Raptor LEDs...
  11. Dec 5, 2020 at 9:04 AM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Maybe a small one piece plexiglass panel to cover middle. Worst case, I'd find someone giving away a center insert for cheap, throw it on for inspections and swap back afterwards
  12. Dec 5, 2020 at 9:09 AM
    I'd raise hell and point to factory trucks that have running lights on the roof and Raptors that have lights in the grille. The shop is just being a pain in the ass. Go up the chain and tell them you don't like being harassed.
  13. Dec 5, 2020 at 9:12 AM
    Look up the law that regulates it and see what it says. Also, read the legal definitions they use in the law. I highly doubt they are failing Raptors for this BS.
    ElNopal likes this.
  14. Dec 5, 2020 at 9:18 AM
    TaquitoBandito
    Joel (AKA Bif)
  15. Dec 5, 2020 at 9:22 AM
    TaquitoBandito
    Joel (AKA Bif)
  16. Dec 5, 2020 at 9:29 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Lol. What’s an inspection?
  17. Dec 5, 2020 at 9:29 AM
  18. Dec 5, 2020 at 9:44 AM
    SLAPPYROOTZ
    Slap
    Appreciate all the responses.
    I’m going to go hunting for some black rubber screw caps to see if they work. If not, I’ll have to try my luck at another shop.
    4x4_Angel likes this.
  19. Dec 5, 2020 at 10:02 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    VA is a pain, I have a light bar in my front winch bumper, I ended up just cutting a piece of sheet metal and screwed it on the bumper, pulled it off as soon as leaving inspection place. So inspection, smog, then registering here, you have to have it titled in this state. Then there’s the property tax on the vehicle at the end of the year. Dealing with the dmv here is a whole messed up experience in itself. I thought CA dmv sucked.
    Darkness and Saltyhero13 like this.
  20. Dec 5, 2020 at 11:30 AM
    timsp8
    NY
    When I lived in va the inspection spot let me cover my light bar with tape and passed me. But I was pulled over not long after that for speeding and the trooper told me I had to get actual covers for the lights. He didn’t ticket me though. Could try a different inspection place, but I think they enter the failure in the computer so all the stations can see it. Or just ask at a different one about them.
  21. Dec 5, 2020 at 11:45 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I can't comment because it would get me in trouble with the mods. Let's just say I'm glad I live in the South.
  22. Dec 5, 2020 at 12:37 PM
    Blazing Blue
    Blazing Blue New Member
    I would differently fail. The only thing they check in Jersey is emissions. My Camry just passed with tint all around bald tires, abs light and air bag light on no problem.
  23. Dec 5, 2020 at 1:58 PM
    TheBeast
    TheBeast The Beach
    man are they not fun in your state..and I'm in CA :D
  24. Dec 5, 2020 at 2:28 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Op is free to do as he wishes with his truck. If it were me I’d just take the lights off and leave them off. I’ve never understood the appeal.
  25. Dec 5, 2020 at 2:35 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Probably the easiest thing to do is remove them and reinstall once you get inspected. If they have plugs you can pull the sockets and unplug them or remove them all together imo they should be left on the Raptor.
    ZappBrannigan likes this.
  26. Dec 5, 2020 at 2:48 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Nope... you would fail in the exact same fashion as OP.
    Bammer, Uhhhh...., ColoradoTJ and 3 others like this.
  27. Dec 5, 2020 at 6:55 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Got my inspection sticker a couple days ago, guy literally said " well, your truck looks new enough to me, here's your sticker"
    On my 95 he just wanted to make sure my blinkers worked.
  28. Dec 5, 2020 at 7:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Are they amber or white? I can see them having an issue with white on the grounds that they are illuminating lights and not marker lights (the Raptor lights are amber, which is universally accepted as a marker light). That is pretty shaky ground, but if there’s one thing I understand well, it’s that all too many laws are based on shaky ground. Most states have the “4 forward lights” law, but things like the white DRLs and such don’t usually count because they are below a certain lumens or visible only to a certain distance.
    Probably the best option is to wire them to a separate switch in the cab (which they probably should have been to start with), though that will take some work to do. Another option would be to make some sort of little metal cover with some sheet metal from Home Depot that can clip over the mounting brackets they are attached to.
    I’m glad they did away with inspections here in WA years ago (my first car when I moved here in ‘98 I had to get inspected, but nothing since). I also live out of town just far enough I’m outside the emissions requirement zone (although we only have one car that is old enough to fall into the state requirement for that as well).
    Blue Thunder likes this.
  29. Dec 6, 2020 at 8:04 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Yeah VA sucks. Don't get me started on the over 80 = reckless regardless if its 15 over or not, or over 90 = misdemeanor and jail time.
    VA is probably one of the worst states to drive in.
    Pro Tip: Highway 81 around Christiansburg is nothing but a huge revenue generating speed trap. They are everywhere and its not even remotely a secrete what they are doing. I've read its one if the most notorious speed trap areas in the nation.
  30. Dec 6, 2020 at 9:43 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    So in VA how do any vehicles pass that have fog lights ? With the headlights on and fogs you would also have the parking lights on which would be 6 lights . If the Tundras have “flash to pass “ that would be 8 front lights on at the same time . I think that inspector doesn’t understand what he’s doing and blowing smoke up your a@@ .
    16 blue crewmax likes this.
