Speed Check
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_15, Dec 2, 2020.
  1. Dec 2, 2020 at 3:24 PM
    1kTyy_15
    1kTyy_15 [OP] New Member
    I want to add more acceleration & top end speed. How do I do this and with what parts? 2001 Tundra SR5 4.7L
  2. Dec 2, 2020 at 3:27 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  3. Dec 2, 2020 at 3:42 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    seriously though... not sure if you're 2WD, 4WD, lift? If you're running larger diameter tires my first suggestion would be regearing the differentials. Most bang for your buck.
    1kTyy_15[OP] likes this.
  4. Dec 2, 2020 at 3:43 PM
    Professional Hand Model
    Fred
    Hand Protectors
    1) Optimize your engine. Fuel, spark, and air.
    2) Reduce weight on truck.
    3) Super Charger if you can find one for our trucks anymore...
  5. Dec 2, 2020 at 3:49 PM
    1kTyy_15
    4WD, No Lift, 265/70R16 Tire Size
  6. Dec 2, 2020 at 4:12 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    You're starting with about 245hp, which actually isn't too bad, especially considering the gen1 era of most trucks (early 2000s). Pro Hand Model listed good places to start for engine mods, consider headers and exhaust too. There are a lot of basic mods like that which will give you a little gain in hp without breaking the bank too much. Bottom line is hp costs a lot of money if you want a substantial increase. SCs and turbos are next-level, both in performance and cost. It'll be hard to get over 300hp out of these 4.7s without breaking the bank. I haven't researched and not sure if the 5.7 will swap into these but that might be a cost-effective option if you could obtain the harness, ECU, and drivetrain along with it from a junkyard (ballpark $2500ish?). Just thinking out loud...
  7. Dec 2, 2020 at 4:15 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The top speed is governed and the ECU will shut you down when you reach that speed.
  8. Dec 2, 2020 at 4:22 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I used to have a Chevy 3500 that would govern at 110. What's the limiter on these? (I'll never come close)
  9. Dec 2, 2020 at 4:26 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  10. Dec 2, 2020 at 4:28 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I drove my 1st gen Today and forgot how Zippy it feels really compared to the 3rd Gen Giant!
    Outbound and Rex Kramer like this.
  11. Dec 2, 2020 at 4:30 PM
    I had one cheby express maybe 01, that governed at 110 area; only found that once, maybe twice, always on the reservation.
    The new cheby express I had to drive for a while, would govern out at 85!!!!!!!!!!!! Like wtf!?!? That was super dangerous at times trying to pass!
    It’s weird...... that one went thru 3 tranny rebuilds
    But I also put the most miles one the first express, they are strangly great work vehicles, the Econolines always seemed to be junk.
  12. Dec 2, 2020 at 4:33 PM
    1kTyy_15
  13. Dec 2, 2020 at 4:36 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Probably a good thing without suspension or transmission/drivetrain mods. Friction.
  14. Dec 2, 2020 at 4:44 PM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    In my younger days, I was spending all my money on a GMC Zr2 with a V-6 and found the most "seat of the pants" power i recieved in one mod was an electric fan. Taking the drag of the clutch fan off the crank has very noticeable, especially on low end.
  15. Dec 2, 2020 at 4:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    For starters, why would you want more top speed? You'll never use it.
    Now that my old man deed is done for the day...
    If you want faster acceleration get lower gears. You'll be quicker off the line.
    If you want more top speed you have two options.
    1) get a yellerbox and fool your truck to think it os going slower, you should be able to go over the governed +/-107mph
    2) get in touch with Unichip and see if they still have the file to remove the speed limit. It has been done in the past. A
  16. Dec 2, 2020 at 5:36 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Agree with everybody.
    OP, how much do you want to spend?
  17. Dec 2, 2020 at 7:31 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    On my '03 Tundra 4.7, I found out that it is only governed while in overdrive( 4 th},turned off the OD and went over 118mph, just watch the rpm's! The truck was very stable at that speed.
  18. Dec 3, 2020 at 1:52 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Lol my trucks tops out at 92mph before the governor kicks in. Dont really need to be traveling that fast anyways but it would nice to go faster if I wanted to.
    Stuck in the '00s likes this.
  19. Dec 3, 2020 at 2:32 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Been sayin' that for decades.
