Another 4x4 not working thread
Discussion in '1st Gen Tundras (2000-2006)' started by Hoondc5, Dec 1, 2020.
  1. Dec 1, 2020 at 5:06 AM
    Hoondc5
    Hoondc5 [OP] New Member
    Hello everyone,
    I have an 04 DC, pretty clean truck, but it has one issue: 4LO won't come on.
    I have been browsing several threads and I can't seem to find my exact issue.
    4HI works flawlessly, but when I try to engage 4LO (in neutral, brake pedal down) nothing happens. No lights (on dash or button), no beeps, no whirring actuator noises underneath the truck.
    Underneath the truck it looks great, no corrosion at all, the actuator connector is spotless and the vacuum line is solid.
    I'm sort of at a loss, and am hoping to be pointed in the right direction. I'm wondering if something is wrong with the PCB where the button is or maybe the 4WD computer?
    Thanks for reading!
  2. Dec 1, 2020 at 6:20 AM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    Did you have your foot on brake pedal?
  3. Dec 1, 2020 at 6:22 AM
    Hoondc5
    Yes I did. I will update the original post.
  4. Dec 1, 2020 at 6:35 AM
    Suprafantx
    Make sure you stop the truck completely. I would try 4HI at low speed then stop completely, put in neutral, brake pedal down, and switch to 4LO. Try this to see if it works.
  5. Dec 1, 2020 at 6:38 AM
    Hoondc5
    Ok, will do. I had a 4th gen 4runner with a v8 with the notorious stuck actuator, and that at least made some mechanical noises when I pressed 4LO and would beep at me until I stopped trying. This just does nothing, so I was suspecting that the actuator wasn't even getting a signal from the computer.
  6. Dec 1, 2020 at 9:21 AM
    Hoondc5
    Just wanted to add that this did not work, unfortunately.
  7. Dec 1, 2020 at 9:44 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Medinasmoke likes this.
  8. Dec 1, 2020 at 10:03 AM
    Hoondc5
    Thank you. I came across that video in my initial search. I am not exactly having that same issue, as my 4HI works fine but 4LO just does nothing, no blinks or anything. I have inspected the actuator and the contacts all look great.
  9. Dec 1, 2020 at 10:19 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Here's the section of the transfer system from the FSM. It gives instructions on testing the components towards the end.
    • 4wd.pdf
      File size:
      16.2 MB
      17
  10. Dec 1, 2020 at 10:21 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    After you hit the button for 4 lo, try driving slowly for a little bit (like 2 miles an hour). Mine won't engage just sitting, I have to be moving.
    Saltyhero13 likes this.
  11. Dec 1, 2020 at 10:23 AM
    Hoondc5
    I have tried this as well. When yours isn't engaging are you at least getting a blinking 4lo light?
  12. Dec 1, 2020 at 10:27 AM
    rock climber
    I'll double check tonight, but I'm pretty sure I am.
  13. Dec 1, 2020 at 10:29 AM
    Hoondc5
    That's where I'm stumped because I'm getting nothing. It's not even getting to that point. After looking at the above FSM section shared, I think I'm going to be spending some time checking the PCB where the buttons live and the 4wd computer.
  14. Dec 1, 2020 at 10:33 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    On my 2014 same process I did according to the manual, 4lo doesn’t wanna work and sometimes when it does it doesn’t want to get out of 4lo. The trick that seems to work for me is from 4hi and in neutral, the second I switch to 4lo I release my foot from the brake and it has worked every time. Try that. If that fails for me I’ll take it to Toyota, but they want $140 just to look at it not including what has to be fixed, ridiculous!.
    Hoondc5[OP] likes this.
  15. Dec 1, 2020 at 10:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  16. Dec 1, 2020 at 10:42 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Good chance the actuator is to blame.
  17. Dec 3, 2020 at 6:44 AM
    TN Turbo
    TN Turbo New Member
    Glen
    1at gen Tundra 4wd
    I'm new to the Tundra, so please forgive me...
    I bought my 01 LTD 4WD because it was the only one I found in a year that didn't have a rotten frame, but it had a terrible shudder in 4Hi above 20mph. It also needed differential bearings. After replacing the diff bearings, the 4Hi issue seems to have ceased. What? That makes no sense. Any ideas?
