Diff Drop Won't Fit
Discussion in '1st Gen Tundras (2000-2006)' started by lamboboy732, Dec 2, 2020.
  1. Dec 2, 2020 at 10:48 AM
    lamboboy732
    lamboboy732 [OP] New Member
    Posted in the what you did today thread with no response so also posting here.
    Just redid the suspension with ome shocks and springs as well as all new bushings. Wanted to also install a diff drop as its a bit higher. I got the wheelers offroad kit which says it's compatible but I'm not really sure how it is possible to space the diff down. When I drop the diff down and put in the spacers it is touching the cross member. I didn't keep the spacers in since i imagine the metal to metal contact would make noise and vibration. Anyone else used this kit or another? How did you have space to install!
  2. Dec 2, 2020 at 11:23 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    that's intriguing. I had no issues with my supreme suspension kit.
  3. Dec 2, 2020 at 12:16 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Nor did I.
    Are BOTH spacers in place?
  4. Dec 2, 2020 at 12:18 PM
    lamboboy732
    Yep, I put both in and snugged it all up. Diff was still sitting on the cross member. I couldn't figure a way to make it not hit without making smaller spacers.
  5. Dec 2, 2020 at 3:54 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    It doesn't look like it in the picture, but could the crossmember be bent or one of the attachment points?
  6. Dec 2, 2020 at 4:18 PM
    lamboboy732
    I put a level on it and it seemed to mach the trans support brace pretty well and didn't seem bent. Frame is about 4 years old from the records I have wonder if there was a design change.
  7. Dec 2, 2020 at 5:43 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Are those 1"?
  8. Dec 2, 2020 at 7:14 PM
    lamboboy732
    Yes
  9. Dec 2, 2020 at 7:24 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Dang..well, that was my best guess. Anybody else got any ideas?
  10. Dec 2, 2020 at 7:35 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    How much your axles actually drops with 1" spacers?
    I'm curios about that?
    Stuck in the '00s likes this.
  11. Dec 2, 2020 at 7:56 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    This is one of those math questions with no right answer, right?
    gosolo likes this.
  12. Dec 2, 2020 at 8:02 PM
    Piki
    Piki New Member
    It's practically useless because you are dropping probably .5 inch if?! Your angles aren't change a lot so I don't see purpose of actual diff drop only on one side. My 2 cents
  13. Dec 3, 2020 at 4:59 AM
    lamboboy732
    I was curious before I installed but when I was getting it in there is was a pretty decent angle change. Just at the expense of it hitting the cross member which makes it pretty useless.
  14. Dec 3, 2020 at 5:00 AM
    lamboboy732
    Yea it's not a huge difference but a bit would certainly help keep the cv alive for longer. Not sure what you mean by one side, it definitely drops both down a bit. Just dosent fit without hitting the cross member.
  15. Dec 3, 2020 at 5:58 AM
    Piki
    Piki New Member
    You dropping only front side of the diff and your axles are in the middle of the diff so you gained probably.5 inch maybe less. How big lift are you running on the truck?
  16. Dec 3, 2020 at 6:14 AM
    lamboboy732
    It's probably 2.5-3". At this point I'm just going to run without it and contact wheelers for a refund. If the cv boots tear then I'll figure out a replacement. Just wish I could have gotten them a little less stressed since we don't have hubs to unlock them so they spin all the time.
  17. Dec 3, 2020 at 7:38 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
  18. Dec 3, 2020 at 7:49 AM
    lamboboy732
  19. Dec 3, 2020 at 9:27 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Maybe the diff bushings are worn enough to sag a bit?
    I'd probably just mark the spots that touch and clearance the crossmember with a hammer.
  20. Dec 3, 2020 at 9:32 AM
    fighthedude
    fighthedude New Member
    If CV boots are not torn, once done with lift take the clamp off and replace with narrow stainless steel hose clamp as the new angle will cause you to lose grease. I ran into that problem and not a drop since. Thanks to the men on this site for the info...
  21. Dec 3, 2020 at 11:05 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    When me and a friend went to install the diff drop we ran into the same issue. With more reading I agreed that it wasn’t necessary. I didn’t dig too deep as to why there wasn’t room for the kit.
    I did the clamp mod but a few weeks in I was spraying grease again. I did install the high angle boots and all has been well since.
    My opinion - if you lift the front spend the money and install the high angle boots.
