2011 Tundra, Bluetooth, Volume Control, Cruise Control all out
Discussion in '2nd Gen Tundras (2007-2013)' started by Stelios, Dec 1, 2020.
  1. Dec 1, 2020 at 1:07 PM
    Stelios
    Stelios [OP] New Member
    2011 Tundra, Bluetooth, Volume Control, Cruise Control all out. IDK if they're related but occasionally when the steering wheel is turned volume and mode will show up albeit briefly. Does it connect to the radio? I reseated the molex connectors in the steering wheel and changed the Cruise arm with a new one, no change. Could it be two separate problems? tHANKS
  2. Dec 1, 2020 at 1:26 PM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Most definitely the clock spring. There are many posts here about it and how to replace.
    Stelios[OP] likes this.
  3. Dec 1, 2020 at 1:30 PM
    Stelios
    Isn't that the module that controls the horn and the air bags? I already replaced it once, you may have read my previous post, that did fix the horn problem for sure but I don't think it's related to this new problem. Thanks!
  4. Dec 1, 2020 at 2:12 PM
    CTB Mike
    Southern Arizona
    The clock spring is the interface to just about everything on your steering wheel.
    Stelios[QUOTED][OP] likes this.
  5. Dec 1, 2020 at 2:19 PM
    Stelios
    Without any check engine lights on do you think a scan would/could verify this?
  6. Dec 1, 2020 at 2:23 PM
    Stelios
    Just ordered OEM clockspring from EBAY, cost $8.99...crazy cheap
  7. Dec 1, 2020 at 2:25 PM
    CTB Mike
    Southern Arizona
    I doubt it. The steering wheel controls are all "user initiated" functions. The computers do not consider them "faults" if they do not work.
  8. Dec 1, 2020 at 2:51 PM
    Stelios
    Thanks for your input, much appreciated!
