Upgrade Front Sway Bar on 2020 TRD PRO?
Discussion in 'Suspension' started by Rusty27, Nov 30, 2020.
Upgrade to TRD Front Sway Bar?
  1. Yes
  2. No
  3. Other
Results are only viewable after voting.
  1. Nov 30, 2020 at 8:36 PM
    Rusty27
    Rusty27 [OP] New Member
    Rusty
    Mississippi
    2020 Army Green TRD PRO
    * Fox TRD PRO Lift Kit 1.5" front lift (total of 3" in the front) and the rear 1" by Westcott Designs * Venom Power Terra Hunter X/T 35X12.50R18LT 123R Tires
    Should I upgrade my front sway bar on a 2020 TRD PRO to the TRD Sway Bar? Have a Fox TRD PRO Lift Kit (1.5" Front / 1" Rear) w/ Terra Hunter X/T 35x12.5 tires. Looks great but I don’t care for the feel while driving. Any suggestions?
  2. Nov 30, 2020 at 8:40 PM
    RobertD
    Robert
    DFW, Texas
    Do you have the rear sway bar?
    Rusty27[OP] likes this.
  3. Nov 30, 2020 at 8:53 PM
    Rusty27
    Rusty
    Mississippi
    I do not have rear sway bar. I heard it is not recommended with the TRD Pro suspension. Plus I read where it doesn’t help as much as upgrading front sway bar.
  4. Nov 30, 2020 at 8:57 PM
    RobertD
    Robert
    DFW, Texas
    Ah... then I'm going to bow out since my knowledge doesn't seem relevant.
    From what I know, the rear sway bar makes a significant difference from no sway bar. Your truck has an existing sway bar and the TRD one is just better and limits body roll a little more. Most agree you can feel a difference when upgrading the front but its minimal so most don't think it's worth the money (many still do it) but just about everyone agrees that the rear TRD bar is worth it.
    Hopefully others with knowledge on your suspension will chime in.
    frichco228 and Rusty27[OP] like this.
  5. Nov 30, 2020 at 9:04 PM
    Rusty27
    Rusty
    Mississippi
    Robert - thanks for feedback. I’m not opposed to adding rear sway bar. May give it a try as well for sure as I don’t do much off roading.
    RobertD likes this.
  6. Nov 30, 2020 at 9:05 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Depends on how you use your truck.
    Sway bars increase stability and reduce body roll when cornering etc on pavement. They also reduce articulation when driving off road. If you seriously off road you’re better off removing your front sway bars instead of upgrading them
    porkitt, the ER kid and Rusty27[OP] like this.
  7. Nov 30, 2020 at 9:56 PM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    I can’t comment on your exact set up. But I can say that the rear sway bar made driving/cornering on my ride (leveling kit) much improved. There was a tighter and more controlled feel. Coming from a M5 Competition this was a needed addition. I ended up doing the front also with slight improvement. The rear made the most perceptive change in handling.
  8. Nov 30, 2020 at 10:02 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    I did the rear sway bar a few years back and was pleased with the upgrade.
    I added the front TRD sway bar a few months back and noticed how the truck just felt more planted and stiffer.
    I tow a 28' travel trailer and the big difference was how the rebound on a dip in the road felt much faster than before.
    Very happy with the results.
  9. Nov 30, 2020 at 10:53 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    As @gosolo said, it all depends on how you will be using your truck. I have a 17 Pro, with both the front and rear sway bars removed. My truck was mall crawler for the first 2 months with the stock suspensions and both sway bars on. While the cornering was great on pavement, the sway bars became a limitation with an upgraded suspension.
    Rusty27[QUOTED][OP] and gosolo like this.
  10. Nov 30, 2020 at 10:55 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It seems significant, especially since the pro is engineered for off road prowess. Most people don’t really care, past the bed stamps though.
    Rusty27[OP] and porkitt[QUOTED] like this.
