Will new tire size affect transmission?
Discussion in 'Wheels & Tires' started by wwolvverine, Nov 30, 2020.
  1. Nov 30, 2020 at 6:49 AM
    wwolvverine
    wwolvverine [OP] New Member
    2018 Tundra 1794
    I want to go from the current P275/55/R20's i have and try P275/60/R20's maybe the extra inch will help with the ride a bit. Question is will it screw up transmission? hate to have to change rims and go down to R18 rims.
    Thanks,
  2. Nov 30, 2020 at 7:00 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    It's all kinda relative honestly. I have a wheels/tires that are about 45#s heavier at each corner and I'm still on stock 4.30 gears and transmission. Have put 11k miles on it with the setup. I also do lots of highway and live in a flat area. Someone with same setup that drives lots of city and hills may say something totally different.
  3. Nov 30, 2020 at 8:12 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    There are many guys & gals on here that have gone with bigger tires without causing any harm on the transmission. Your odometer and speedometer will be a little off. If the tires are really heavy, your acceleration will be slower.
  4. Nov 30, 2020 at 8:25 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Will it change things? Yes. It won't damage the transmission if that's what you're asking. Heavier tires, altered gear ratio will affect performance. I doubt the difference will be significant to you, but only you can answer that.
    wwolvverine[OP] likes this.
  5. Nov 30, 2020 at 9:11 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    you are fine. 33's on these trucks is not an issue.
  6. Nov 30, 2020 at 9:37 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Going to 33's will not cause the slightest harm to your rig. You will barely feel any difference in the drive. I went from OEM to 35"s after I purchased my Tundra and that was nearly 20k ago. No problems.
  7. Nov 30, 2020 at 9:55 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Your odo actually may be more accurate now
    YardBird and Netmonkey like this.
  8. Nov 30, 2020 at 2:18 PM
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    I got a speedo healer thing installed so its pretty accurate. Those digital speed signs are pretty spot on.
    YardBird likes this.
  9. Nov 30, 2020 at 6:05 PM
    wwolvverine
    2018 Tundra 1794
    Thanks!
