Desert eagle off-road transmission skid plate install
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Oct 9, 2020.
  1. Oct 9, 2020 at 4:45 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    ***Very long read, review and install.***
    Tundra transmission skid plates with catalytic converter protection
    So I was looking for a transmission skid plate and was leaning RCI since I have their front skid plate. As I was googleing and doing research I came up with old threads about a company (OR Fab) that made a transmission skid plate that also offered catalytic converter coverage for anti theft. But the company went out of business.
    I was cruising eBay and found this ad.
    https://www.ebay.com/i/133393394724?chn=ps
    $325, free shipping. Or best offer. I liked the looks of it, looked just like the old company that was out of business. I liked it was in Texas and seemed well built. So naturally I shot the guy a low ball offer just to see if he would bite.
    That opened a line of communication with desert eagle off-road in Texas. The owner, KW, gave me his personal cell number and we had a great chat.
    He knew I was from CA from my eBay profile and one of the first things he asked was if I was safe from the fires that we had out here a few weeks ago! Just goes to show you are dealing with a real person and not some guy that wants your cash.
    So he tells me about his company and prior work experience and it turns out he used to work for OR fab that originally made the skid plate with converter coverage. Now he makes them in TX.
    So he sends me an invoice and 3 days later a huge box shows up from KW.
    Install***
    I am running an RCI front skid and with mating parts from different manufacturers there will be some modifications made. KW gave me the heads up with a TRD skid there would be notches cut. He was unaware of how it would mate with the RCI.
    Disclaimer. I did all the mods to the RCI plate while it was still installed. I chose not to remove it because it was a beast to install before being one guy on the ground. If I had help or better tools I would have done it a little differently and cleaner.
    So after looking at both skids I knew I would need to notch both. Each skid uses different mounting holes at the transmission cross member.
    The RCI uses the inner holes of the cross member, the desert eagle off-road uses the outer holes. The RCI blocks the outer holes. So I cut off a 1”x2” square off the corners to allow access to these holes. All nothing done, I used some chassis paint for touch up.
    I initially thought I would install the KW plate, then the RCI on top of it, I saw that once the kw was installed I would not be able to access the upper bolts for the RCI. So RCI first, then the kw.
    I notched the kw front holes, I did this for ease of install this is just my method. I did it so I can hang the hardware and slide in the skid plate.
    The kw plate is held in place with four tabbed nuts that slide into the holes and have long flanges so the don’t rotate when the bolts are being tightened.
    Once the front was hung, the back was a breeze. Snugged all four bolts down evenly.
    Ricos, Skew12 and Vizsla like this.
  2. Oct 9, 2020 at 5:18 PM
    Jwood562
    2013 Tundra 4x4
    KW over at Desert Eagle offroad is a great guy and delivers a great product. I will send him a link to this post and the forum and see if he will join. Also check out his facebook page for those that have social media. I am not sure if he has a website.
    Rica25 likes this.
  3. Oct 9, 2020 at 5:24 PM
    Vizsla
    Vizsla 2 = 2.5
    Nice! I did the same a few years back, but put the RCI on top of the KW. FWIW the engine skid got smashed, KW took everything no problem, other than ugly from scratches and scrapes.
    red3, Skew12, Terndrerrr and 4 others like this.
  4. Oct 9, 2020 at 5:25 PM
    Jwood562
    2013 Tundra 4x4
    Nice! How were you able to get to the RCI top nuts after the KW plate was installed? I couldn't reach
    BTW your notches are neat! that is how would have done it I completely removed the RCI to work on the bench.
  5. Oct 9, 2020 at 5:29 PM
    Vizsla
    Vizsla 2 = 2.5
    Wasn’t easy lol. I used a ratcheting wrench for it.
    Rica25 and joonbug like this.
  6. Oct 9, 2020 at 5:30 PM
    Jwood562
    2013 Tundra 4x4
    Nice work, really clean.
  7. Oct 9, 2020 at 5:36 PM
    Jwood562
    2013 Tundra 4x4
    If anyone is interested maybe I can ask him if he will set up a group buy here.
    I paid $295 shipped to my door
  8. Nov 30, 2020 at 3:46 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    I am waiting for my RCI skid plate to show up and in the meantime I want to modify my Desert Eagle Catalytic Converter Skid Plate to work with the RCI skid.
    Does anyone know the dimension between to two rear holes that mount the RCI skid to the sub frame?
    I think it’s about 10-1/4” but want to make sure before I cut any steel on my DE skid.
    danz75 likes this.
  9. Nov 30, 2020 at 4:42 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I installed the front RCI skid over the desert eagle skid. Only notched the desert eagle skid to line up with the RCI skid rear fasteners so ended up only having to use the desert eagle fasteners for the rear. Had to use a ratchet to get to the nut on the top.
    reneaux and Black Wolf like this.
  10. Nov 30, 2020 at 4:49 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I measured out 10 1/4 as well.
  11. Mar 24, 2021 at 3:36 PM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    I live just down the road from KW and just had one of these installed. For the extra $20, I just let him take care of it. Thank y'all for posting about it. I've been looking for something to slow some folks down after hearing all the stories.... Quick, easy and looks good.
  12. Apr 11, 2021 at 10:49 PM
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
    Catalytic converter thefts are on the rise in the PNW—even old dogs like my 07 are getting hit. They seem to like the Toyotas. I just installed the desert eagle plate behind the RCI engine skidplate and relied on a lot of the information I found on this site. Thank you all. I think I would have been somewhat intimidated trying to figure it out without this internet resource. I even called RCI and its technical assistance guy referred me to the info here. So, I thought it would be good to provide a little feedback. I notched the desert eagle at 10 1/4” as has been posted here. I started by drilling a 3/8” hole and then used a cutting disc on a hand grinder to cut slightly angled lines to the hole. Worked great. Filed smooth and touched up with rustoleum. I loosened the two rear nuts on the RCI to expose a space and lifted and slid the desert eagle into place under the RCI. Fit like a glove. All went well to that point. Put in the rear bolts—couldn’t have been easier. But then things got complicated. I have a 9/16” ratchet wrench, but getting my hands between the desert eagle and the rest of the truck to a blind nut on top of a cross bar was very challenging for even a moderately competent person. I’m also pretty claustrophobic so wedging my hand in there trying to tighten the nut was also stressful. There were a couple times my hand kind of got stuck. I finally got both nuts tightened in what was by far the most time consuming and hardest part of the entire project. Which, during a post-install beer made me start to think ... “what happens if I need to take this into the shop and they need to get to anywhere under the front half of the truck?” The mechanic will be cursing me and charging $$ while he tries to undo this thing. So here’s the feedback. I’m going to take everything off and notch the RCI plate where the desert eagle front bolts attach. That way the RCI can be installed with full access to the rear nuts, the desert eagle can then be installed with the front overlapping the RCI (instead of sliding under), and then to disassemble, the hypothetical mechanic just needs to reverse that process—no wedging hands into small recesses trying to blindly loosen/tighten nuts.
    KW at desert eagle was great to deal with BTW. Sounds like he’s doing a brisk business. The RCI + desert eagle make for a pretty nice undercarriage. Thank you again for the advice on posts.
  13. May 14, 2021 at 6:40 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Is this protection for both front and rear catalytic converters?
  14. May 14, 2021 at 7:51 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I also picked up the DE plate. on my 2007 trd CM the plate covers about 60% of the rear cats. It would be very very difficult to get them out of there with the plate on.
    OhEmmBee likes this.
  15. May 14, 2021 at 9:08 AM
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    The desert eagle does NOT cover the rear cats. Another vender on this site (Valhalla’s Shield) makes plates for the front, middle, and rear. I have one of his rear plates on order to completely cover the situation (RCI-front, DE-middle, VS-rear). The feedback on this site is that Valhalla’s Shield are superb products.
  16. May 14, 2021 at 3:10 PM
    Jwood562
    2013 Tundra 4x4
    mine covers half of the rear cats.
    if someone really wanted to steal the rear cats they would have to cut in the middle
  17. May 14, 2021 at 3:38 PM
    The rear cats on the 4wd are more protected with the rear plate than the 2wd.
  18. May 14, 2021 at 3:52 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Local church had their vehicles hit for cats this week.
  19. May 14, 2021 at 3:57 PM
    Jwood562
    2013 Tundra 4x4
    well that explains the differences people are experiencing.
  20. May 14, 2021 at 4:42 PM
    Yep....mine is 2wd.
  21. May 14, 2021 at 7:50 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    N
    Did you do aluminum or steel for the rear? And if aluminum, is it thicker than the DE in the mid? I'm thinking about a full skid plate for roading and seeing if these will hold up well on the side for off roading.
  22. May 14, 2021 at 8:36 PM
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    I went with steel on the Valhalla’s shield rear plate. Still waiting for it so don’t know exactly how it will mate up with the DE plate. I understand Tyler is burning the candle at both ends (it’s great to be busy!), so just waiting patiently.
    I hope everyone can cut Tyler and Kent a little slack right now. There are steel shortages—don’t know if that’s affecting plates—but seems like everything is backed up, and these guys are trying to meet demand, which, by the looks of things, is huge.
    OhEmmBee and Rica25 like this.
  23. May 14, 2021 at 9:25 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I'd love to see photos of the plates installed and some photos of how they go on.
  24. May 14, 2021 at 10:01 PM
    Jwood562
    2013 Tundra 4x4
    i can grab some tomorrow.
    when I initially installed it with my front RCI skid I put the DE on top of the RCI. But now I want to swap them because I can’t remove the RCI unless I remove the DE.
    plus I’m doing an oil change tomorrow
  25. May 14, 2021 at 10:35 PM
    pnw tall trees
    Pacific Northwest
    07 Limited Crewmax
    Wait, I did just the opposite (see post above—slipped front of DE under rear of RCI engine plate—turned out to be kind of an install nightmare). When I get the Valhalla’s shield rear plate I’m going to reverse it (put the DE over the RCI) so I don’t have to wedge my hand in and try to blindly use a ratchet wrench to loosen the hidden nuts at the rear of the RCI. I think it’s going to be a A LOT easier to just take off the DE plate (4 bolts) first and then have full access to the two rear nuts on the RCI on the rare occasions I have to remove the RCI. But hold on, I don’t take off the RCI to change the oil either. What am I missing?
  26. May 14, 2021 at 10:41 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    I think all of this answered my question. Guess I'm going with Vahalla shields for the whole set up
  27. May 14, 2021 at 11:34 PM
    Jwood562
    2013 Tundra 4x4
    I just saw it as the point that the front RCI would need to be removed more often then the rear DE.
    Any engine work that would require the front RCI to be removed would Make it easier than removing both. Shouldn’t be too often but once would be enough for me.
    that’s just my train of thought.
    I did hear it was a nightmare to install it that way though so I might change my mind mid install lol
  28. May 16, 2021 at 8:18 PM
    Blasterrr
    Blasterrr New Member
    Know any place to get replacement hardware? Lost one tab and bolt. Need replacement.
  29. May 16, 2021 at 9:17 PM
    Jwood562
    2013 Tundra 4x4
    I would call him up.
    I think he makes those tabs, nuts with long tabs welded on. Nothing special, but unless you are a welder might not be something you can find at a hardware store
  30. Dec 1, 2021 at 8:48 AM
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    I just got my DE plate. took 4 days to arrive. Packaging looked good. Got the security torx screws but wonder if I need to add lock washers and paint the nut plates?
