Gen III OEM Tire Jack Questions
Discussion in 'General Tundra Discussion' started by copperking81, Nov 29, 2020.
  1. Nov 29, 2020 at 7:04 PM
    copperking81
    copperking81 [OP] New Member
    What's everyone's opinion of the Toyota OEM tire jack that comes with the Gen IIIs? I had to change a tire out on my 2019 Tundra in the back 40 over the summer and it didn't strike me as the best jack around. Granted I've been fortunate in life to not have to change many tires so not much of an expert.
    I decided that I wanted to invest in a better jack to take with me on backcountry excursions. But after looking at all the different options on the market, the Toyota OEM jack seems to be one of the best things going. Hi Lifts are dangerous, other bottle jacks are just as good at best, a floor jack is too bulky and heavy, and I have zero interest in the exhaust jacks. Is there anything else I should be looking at?
    At a minimum, I would like to get a base to widen it's footprint. Are there any bases designed specifically for this jack?
  2. Nov 29, 2020 at 7:07 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    It’ll get the job done for sure. I usually carry a 6x6 block of wood with me just incase. In fact my floor jack was leaking fluid when I changed my wheels out so I did all four corners with the oem jack. Time consuming but it does the job
    Darkness likes this.
  3. Nov 29, 2020 at 7:16 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Carrying a block of wood like the @cctxquicksand mentioned is a great idea.
    If you are looking for a replacement, try to find a surplus H1 Hummer surplus scissor jack. Solid and long travel.
  4. Nov 29, 2020 at 7:21 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    Carry a few blocks of wood. Some pieces of 1inch plywood or similar always helps. sometimes the ground is muddy,sandy etc and its nice to have enough support.
  5. Nov 29, 2020 at 7:23 PM
    copperking81
    Not really looking for a replacement per se, just wondering if there are far and away better options on the market.
  6. Nov 29, 2020 at 7:30 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    This is what I have besides the stock
    cctxquicksand likes this.
  7. Nov 29, 2020 at 7:33 PM
    copperking81
    I've seen that one. Seems to get decent reviews. Have you had to use it and if so, do you like it?
  8. Nov 29, 2020 at 8:31 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    I definitely like the Jack and I have personally used it in Death Valley, actually a few of the guys I run with have the same Jack. It’s hefty and more stable with a block of wood.
    831Tun likes this.
  9. Nov 29, 2020 at 8:33 PM
    TheBeast
    TheBeast The Beach
    same here. I have it in my bed. the powerbuilt version. used to be $39 prime on Amazon.
    831Tun and porkitt[QUOTED] like this.
  10. Nov 29, 2020 at 9:49 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Yup, that's the one that I have as well.
  11. Nov 29, 2020 at 9:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The Powerbuilt jack the guys above posted is a pseudo jack stand as well as a jack. The concave lifting point is much better than the quarter sized point of your average bottle jack.
    porkitt likes this.
