OEM Headunit Issue
Discussion in 'Audio & Video' started by YotaTruckLtd, Nov 29, 2020.
  1. Nov 29, 2020 at 2:54 PM
    YotaTruckLtd
    YotaTruckLtd [OP] Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    On first startup today the screen went blank and stayed white the entire day. Disconnected the battery to see if that would reset it but it stayed the same. Has anyone had this same issue?
  2. Nov 29, 2020 at 3:17 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Never heard of that. Looks like time to upgrade.
    YotaTruckLtd[OP] likes this.
  3. Nov 30, 2020 at 6:42 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    If you hold down the volume button for a while it will normally “reset” and go back to startup screen. Try that and if no luck the dealer can do a software update to see if that fixes. If not, it will need to be replaced.
  4. May 5, 2021 at 7:02 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Ever resolve this issue?
    I just made an appointment today due to my stock unit shutting off abs turning back on during drive several times
    My gauge cluster screen also resets so my mileage is always resetting
  5. May 10, 2021 at 12:41 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Mine started doing this, but only when Bluetooth is being used during a phone call.
