Front sway bar
Discussion in 'General Tundra Discussion' started by NCTundra18, Nov 28, 2020.
  1. Nov 28, 2020 at 7:37 AM
    NCTundra18
    NCTundra18 [OP] New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I'm considering get the front TRD sway bar for my 18 crewmax. Since most of the Toyota dealers here in the south have free shipping. So for those of you that have installed it was it worth it? Any advise would be appreciated.
  2. Nov 28, 2020 at 7:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    The TRD front swaybar is a little beefier than the stock one, minor improvement. Now adding the rear sway bar really makes the most difference.
    Decent upgrade but you will not see a huge difference like when you add the rear TRD bar. The TRD front bar also looks really nice.
  3. Nov 28, 2020 at 7:51 AM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I’ll have to disagree with the previous response. It’s A LOT beefier. The stock bar is hollow, the TRD bar is solid steel and very heavy. I installed it myself.
    In conjunction with the rear sway bar, the truck handles like it’s on rails.
    Tundyfundy, Pkahir12, Rica25 and 2 others like this.
  4. Nov 28, 2020 at 8:09 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks for the help. I already have the rear sway bar. @1999cutiger was the install hard?
    Rica25 likes this.
  5. Nov 28, 2020 at 8:57 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    The front bar is very simple if your good with a wrench. Spray the bushings with PB Blaster if your up north in case they are seized on the bolt like mine were. The guy I bought it from left the endlinks on it so it took me about 30 min to swap out and that was with a sticky end link bolt. Also had a LCA bolt break its weld if you take the wheel off there is a spot to get to it with an open end wrench. And its a wierd size so if you dont have a 21MM open end wrench get one just in case.
    If you already have the rear bar you will notice a big difference adding the front. It is a solid bar unlike the hollow factory one and is about 15lbs heavier from my grip-o-meter, maybe more. Plus its bright red and that makes it 1000% more effective.
  6. Nov 28, 2020 at 8:59 AM
    1999cutiger
    Not too bad of an install. Take your time and torque everything appropriately.
    Tundyfundy likes this.
  7. Nov 28, 2020 at 9:00 AM
    Yep, stock is 17 lbs, TRD is 29 lbs.
  8. Nov 28, 2020 at 9:19 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Both mine are getting installed on my next Service visit in a few weeks.
    Does that make my SR5 a TRD :thumbsup:
    Rica25 likes this.
  9. Nov 28, 2020 at 9:21 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Can I ask what the truck is not doing and what did you want it to do?
    Add a bigger sway bar in the front may make the truck understeer a big more.
    But then again I doubt anyone here is road racing their trucks. :)
    JLS in WA and BravoDeltaRomeo like this.
  10. Nov 28, 2020 at 9:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This right here ^^^.
    Having a second set of hands, that's willing to get under the truck, is of definite benefit.
    Rica25 and BravoDeltaRomeo like this.
  11. Nov 28, 2020 at 9:32 AM
    NCTundra18
    Jeff
    Candler, NC
    The truck does what i want it to. But if i can add a little better ride and performance why not plus it's a Christmas present to myself and it's a cheap mod.
    Tundra234 and BravoDeltaRomeo like this.
  12. Nov 28, 2020 at 10:43 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks for all of the feed back. Just placed my order for one. Got it for $175 and free shipping.
  13. Nov 29, 2020 at 12:26 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Love my rear TRD sway bars
    Tundyfundy and BravoDeltaRomeo like this.
  14. Nov 29, 2020 at 12:28 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Yes the fronts are way heavier and solid
    BravoDeltaRomeo and Rica25 like this.
  15. Nov 29, 2020 at 3:21 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Both are standard on my Sport and do a nice job of reducing body roll. They look cool too...!
  16. Nov 29, 2020 at 5:48 PM
    Lagerstout82
    Lagerstout82 New Member
    2021 Tundra SR5 TRD Sport
    I concur along with the Bilstein shocks.
    maxdriver[QUOTED] and Rica25 like this.
  17. Nov 29, 2020 at 5:54 PM
    Rica25
    Ricardo
    Tulare
    I removed mine due to making the front feel stiffer when hitting bumps or qhen driving on California shit highways.
    Mr. Wasteland likes this.
  18. Nov 29, 2020 at 6:44 PM
    NCTundra18
    Jeff
    Candler, NC
    For those of you that installed the sway bar yourself did you put grease on the bushings? I saw a video and the guy put never seez on the bolts too.
    Saltyhero13 and Rica25 like this.
  19. Nov 29, 2020 at 6:46 PM
    Rica25
    Ricardo
    Tulare
    I
    I did both
  20. Dec 2, 2020 at 9:42 PM
    Warthogdrifter
    Warthogdrifter New Member
    Hello Everyone! After 3 long months of waiting we finally got our 2021 Voodoo blue SR5. I had them add the TRD rear sway bar from the factory. We plan on doing a lot of towing. I can't compare the body roll to a stock rear bar, but I am interested in the front. They did not give me the option for a front bar or I would have had them throw it on.
    My question is do I need to buy different hardware to fit the TRD bar, or does the Bar use the existing hardware? If so does the bar include said hardware with purchase.
    NCTundra18[OP] and Rica25 like this.
  21. Dec 2, 2020 at 9:51 PM
    Rica25
    Ricardo
    Tulare
    No need. It comes with no hardware
    Saltyhero13 and NCTundra18[OP] like this.
  22. Dec 2, 2020 at 10:08 PM
    Warthogdrifter
    Awesome thanks! Ordering one now.
  23. Dec 3, 2020 at 8:58 AM
    NCTundra18
    Jeff
    Candler, NC
    So what size sockets do i need to remove the old sway bar? I'm guessing a 19mm. What other sizes would i need?
  24. Dec 3, 2020 at 9:33 AM
    Give me a sec and I'll let you know...I have my tools out currently.
    BravoDeltaRomeo likes this.
  25. Dec 3, 2020 at 9:35 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Same here.
    Rica25[QUOTED] likes this.
  26. Dec 3, 2020 at 9:46 AM
    The 19mm is for the end links where they attach to the bar and the lower control arms. The 4 bolts at the bushings are 17mm.
  27. Dec 3, 2020 at 10:39 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks
  28. Dec 3, 2020 at 10:40 AM
    :thumbsup:
  29. Dec 3, 2020 at 11:21 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I'm curious how much difference the front bar makes.
    I added the rear bar to mine months ago and it made a huge difference... so now I'm thinking about swapping out the front bar too.
  30. Dec 3, 2020 at 11:26 AM
    NCTundra18
    Jeff
    Candler, NC
    Yeah I've got the rear one already. The front one is supposed tobe here tomorrow. I can hardly wait to get it on and see how it drives. But i work this weekend so it'll be Monday before i can start on it.
    Rica25 and Dragracer_Art[QUOTED] like this.
