Upgrading UCAs today, yay
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Nov 16, 2020.
  1. Nov 27, 2020 at 6:25 PM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Got everything apart today and ready to install new lowers and a set of balls with zerks. The eccentrics arrived via UPS today so I should be able to get everything back together tomorrow... alignment scheduled for Monday.
    Put a couple lug nutz on each wheel and supporting each with screw jacks.
    [​IMG]2020-11-27_05-49-58 by GhostCreekMine, on Flickr
    A little of this...
    [​IMG]2020-11-27_05-49-11 by GhostCreekMine, on Flickr
    A little of that....
    [​IMG]2020-11-27_05-49-31 by GhostCreekMine, on Flickr
    And a lot of SAWZALL!
    [​IMG]2020-11-27_05-52-05 by GhostCreekMine, on Flickr
    Marked and labeled the old eccentrics before removal so I can orient the new ones well enough to drive her to alignment.
    [​IMG]2020-11-27_05-48-45 by GhostCreekMine, on Flickr
    I smell VICTORY!
    [​IMG]2020-11-27_07-14-46 by GhostCreekMine, on Flickr
    Note: If you end up cutting off the lowers like I had to do... definitely get a Diablo carbide tipped blade as pictured. The Milwaukee "Torch" blades were not adequate. One was toast before the first cut was made. The Diablo made all eight cuts without wearing out. Made the job a lot easier. Expect to pay $15-$20 for one Diablo but very well worth it.
    [​IMG]2020-11-27_05-51-46 by GhostCreekMine, on Flickr
  2. Nov 27, 2020 at 7:24 PM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    Damnit wish I had that setup to work on my truck. Baller.
    Stuck in the '00s and Tundra2 like this.
  3. Nov 28, 2020 at 5:48 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’m jealous of his hand protector unit box on that back shelf.
    Darkness, Gmillz85 and Glock 40[OP] like this.
  4. Nov 28, 2020 at 6:26 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  5. Nov 28, 2020 at 12:50 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Tagging this thread for info later.
    Tundra2 likes this.
  6. Nov 29, 2020 at 4:06 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I got everything back together. Alignment scheduled for tomorrow morning.
    [​IMG]2020-11-29_04-50-53 by GhostCreekMine, on Flickr
    The new eccentric bolts (Moog) have grease zerks.
    [​IMG]2020-11-29_04-44-32 by GhostCreekMine, on Flickr
    LBJs have em too. Now I can grease my balls, yay!
    [​IMG]2020-11-29_04-44-50 by GhostCreekMine, on Flickr
    Note to anyone upgrading to Suspension Maxx SB links: If you're running OE style LCAs, you'll need to cut off the bottom of the sway bar link mount on the lower control arm (as I marked in red). This is so you can access the 9/16" bolt at the bottom of the Suspension Maxx link (pictured). It's impossible to get a wrench on that bolt without modifying the sway bar mount like I did. I used a 4" angle grinder with a metal cutoff wheel, simple. Cut it like butta.
    [​IMG]2020-11-29_04-49-01 by GhostCreekMine, on Flickr
    Some RC shocks for the rear.
    [​IMG]2020-11-29_04-51-49 by GhostCreekMine, on Flickr
    Hopefully I'm at the end of this rabbit hole for now. We'll see how she rides after alignment tomorrow.
  7. Dec 1, 2020 at 4:49 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Probably my last installment to this thread. Alignment is close to what I requested... +2.5 caster and .08 total toe. Drives well!! No clunks, bumps, or rubs. I like.
    [​IMG]2020-12-01_05-45-15 by GhostCreekMine, on Flickr
  8. Dec 1, 2020 at 5:00 AM
    Fred
    Hand Protectors
    I’ll post up what the 4wheel place did on mine for comparison before and after. I left it to them to get what they thought was the best setting. Truck drives very well. Tires rub the inside frame at slow tight parking spot turnings.
    Glock 40[OP] likes this.
  9. Dec 1, 2020 at 5:05 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Pretty similar... I requested a little more caster based on another response in this thread. Going to keep a close eye on tire wear.
  10. Dec 1, 2020 at 5:09 AM
    Fred
    Hand Protectors
    I have no idea what any of these numbers mean in terms of real world experience adjustments. The truck was lazy and worn out before the rebuild, but now drives/handles better than new imo.
  11. Dec 1, 2020 at 5:13 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I honestly don't know how it's supposed to drive or what it would be like new. It had bad wheel bearings and a host of steering issues when I got it. Feels pretty dang good now.
  12. Dec 1, 2020 at 5:26 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Nice work, Glock! Great tip on the Diablo blade, too.
  13. Dec 1, 2020 at 7:56 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I think that's a good call. 2.0-3.0 caster is the sweet spot for our trucks. Caster affects high speed stability.
    Also, camber and toe effect tire wear, caster won't.
    Glock 40[QUOTED][OP] likes this.
  14. Dec 1, 2020 at 8:01 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thank you! That's reassuring. I just dropped $2K on a set of 5 (whls + tires) so I'll be keeping an eye on em anyway.
  15. Dec 1, 2020 at 8:16 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  16. Dec 1, 2020 at 8:51 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Set and................................................. spike!
    Well done sir. :rofl:
    Darkness likes this.
  17. Dec 1, 2020 at 6:03 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I notice the rear measurements are grayed out, I'm guessing there's nothing adjustable back there? Was getting the front into specs responsible for the slight before/after rear measurements in PHM's example?
  18. Dec 1, 2020 at 6:15 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I don't think the rears are adjustable.
  19. Dec 2, 2020 at 4:27 AM
    Fred
    Hand Protectors
    Yeah. The rear isn’t adjustable. I think the difference in my rear spec came about due to the new front adjustments realigning the rear Mojo after the drive. My rear leafs were splayed and not boxed in with a my jack leg keepers at that time a few years ago.
    Lil Steve[QUOTED] likes this.
  20. Dec 2, 2020 at 7:43 AM
    #50
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Make sure you loctite those lbj bolts (new of course) and torque everything with wheels on the ground. I redid my whole front end and still chasing a slight knock thunk when turned and going over speed bumps etc. Never ends lol
  21. Dec 2, 2020 at 8:20 AM
    #51
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Roger that on the Loctite. The LBJs actually came with a couple tubes of it. I'll be checking torques again today, and again after about 300 more miles. Lucky me... no unusual knocks, rubs, or anything so far. I have a gauntlet of speed bumps and depressions almost daily that I was sure I'd hear something from, but nothing. Have you checked your strut boxes for rubbing from the UCAs? ....or unhappy SB links maybe?
    Surf_spear_Mex and Darkness like this.
  22. Dec 2, 2020 at 8:35 AM
    #52
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Nice work . . . thanks for the write-up.
  23. Dec 2, 2020 at 11:39 AM
    #53
    Surf_spear_Mex
    Patrick
    05 tundra ac
    I'm in mexico so let's talk about speed bumps and potholes lol
    I have freedom uca's so no rubbing at all thankfully and I have suspension maxx sb links that I'm really happy with. I just re torques them yesterday but still have a little lateral knock somewhere. Going to lift it up today actually and re lubes my brake pads and pins as I squeaking a bit.
    I got done with the front end rebuild a day before we embarked on a 3200 mile trip from manitoba canada to puerto vallarta mexico. Over a month of hard driving a wheeling it's time to do a little check up. I know my driver side cv is getting close to death as it has a fair bit of play laterally. I'm sure once the wheels are off I'll have a better chance of finding the culprit.
  24. Dec 2, 2020 at 2:38 PM
    #54
    Fred
    Hand Protectors
    What is the Torque Spec on the LBJ’s?
  25. Dec 2, 2020 at 2:47 PM
    #55
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    68 ft lbs
  26. Dec 2, 2020 at 2:48 PM
    #56
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    ... or are you asking about the ball stud? I was referring to the 4 bolts that hold it to the knuckle.
  27. Dec 2, 2020 at 2:51 PM
    #57
    Fred
    Hand Protectors
    I’m just looking to do whatever is accessible for re-torque. Whats the ball stud?
  28. Dec 2, 2020 at 2:55 PM
    #58
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Ball stud is the bolt that comes through the boot of the ball joint and connects to the LCA. It has a large castle nut on it with a cotter pin. Shouldn't have to re-torque that (105 ft lbs I think?). The four that hold the lower ball joint assembly to the steering knuckle are worth checking once in a while.
  29. Dec 2, 2020 at 3:00 PM
    #59
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Those bolts (three of the four) and ball stud are pictured above in the "grease my balls, yay" pic.
    Stuck in the '00s likes this.
  30. Dec 2, 2020 at 4:08 PM
    #60
    Surf_spear_Mex
    Patrick
    05 tundra ac
    May just be me but a slim/short 9/16 fits great with the bottom of the link mount intact. I'm not one to cut supporting metal off a vehicle unless it's the stock bumpers to put beefs on.
