2020 Tundra USB port 2.0 or 3.0??
Discussion in 'Audio & Video' started by Anthony605, Nov 27, 2020.
  1. Nov 27, 2020 at 4:07 PM
    Anthony605
    Anthony605 [OP] New Member
    Anthony
    2020 Limited Double Cab
    Is the USB port on a 2020 Tundra 2.0 or 3.0? I am going to pick up a USB drive later and want to see if its worth it to get a 3.0 drive. If the Tundra is only 2.0 then it would not be worth it. Thanks
  2. Nov 27, 2020 at 4:21 PM
    TheBeast
    TheBeast The Beach
    i would get 3.0 so you can use it on other stuff at full speed at least
  3. Nov 27, 2020 at 4:23 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    What are your goals with the USB Drive? USB 2.0 transfer speed is 480 megabits per second (Mbps), while USB 3.0 transfer speed is 4,800 Mbps. This means USB 3.0 is approximately 10 times faster than USB 2.0. It makes a difference when transferring large files, but I'm not sure how much of a benefit it will be for a truck head unit. If I had to guess it's 2.0
  4. Nov 27, 2020 at 4:25 PM
    Anthony605
    Anthony
    Just playing songs. Curious to see that version is installed from the factory. Thats all! Thanks
  5. Nov 27, 2020 at 4:29 PM
    Doxiedad
    James
    Charleston, SC
    USB 2.0 will do that no issues. Also If you look at the port and the plastic piece inside is black it's 2.0, 3.0 has a blue insert to help easily differentiate
  6. Nov 27, 2020 at 4:34 PM
    TheBeast
    TheBeast The Beach
    if you getting your songs from a PC 3.0 usb then get a 3.0 drive to transfer at 3.0 speed to drive then play at 2.0 on the tundra HU imo
    I just stream on my HU. havent used cd or usb stick in ages :D
  7. Nov 27, 2020 at 5:12 PM
    Anthony605
    Anthony
    Thanks. I appreciate it.
