19 tundra trd leaning towards left side
Discussion in '2.5 Gen Tundras (2014-2021)' started by Honda287, Nov 26, 2020.
  1. Nov 26, 2020 at 10:10 AM
    Honda287
    Honda287 [OP] New Member
    19 tundra trd
    I have a 19 trd off-road ans it’s leaning to the left side quite abit. It’s over a 1/4 inch from the right side to the left . This is even with a empty tank of fuel. Brought it back to Toyota and they replaced the left rear leaf spring with a complete new one . Still has the same issue I have a level kit in the front. I do want to install a set of fromt and rear tundra fox pro shocks . Has anyone else had this issue .
  2. Nov 26, 2020 at 10:17 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Typical Toyota
    Shim on the driver side will help
  3. Nov 26, 2020 at 10:17 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    The Tundra lean is very common.
    Some beefier leaf springs, or an add-a-leaf and a Coachbuilder shim up front will take care of it.
    Black Wolf likes this.
  4. Nov 26, 2020 at 10:33 AM
    Honda287
    19 tundra trd
    So do I get the shackle kit or the shin and what’s the shim .
  5. Nov 26, 2020 at 4:47 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Forget about it and drive. Mine leans. My 4runner leans. Who cares. Road isn't flat either....
  6. Nov 26, 2020 at 5:44 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Exactly, quit measuring. I have always said if I can't see it with my eyeballs then who cares. I knew there might be a slight lean when I installed 6112s on front but I could not see it so it did not concern me. I am surprised dealer replaced rear spring. Maybe they felt they could submit as warranty and wanted to make a buck.
    Black Wolf and Ely010606 like this.
  7. Nov 26, 2020 at 7:32 PM
    Honda287
    19 tundra trd
    My lean is very obvious it leans almost 1/2 that seems a lot to me
  8. Nov 27, 2020 at 2:57 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Common issue especially once it has been lifted in any way. Folks put a shim (small top plate spacer) on the driver size to compensate.
  9. Nov 27, 2020 at 3:01 AM
    Honda287
    19 tundra trd
    Where would I get the shim I was thinking about adding a extra leaf to the leaf springs as well .for towing
  10. Nov 27, 2020 at 3:24 AM
    frichco228
    Frank
    Virginia
    Coachbuilder makes some. I would think a 1/4 inch shim on the driver side will bring it back to even.
  11. Nov 27, 2020 at 5:56 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  12. Nov 27, 2020 at 6:07 AM
    Honda287
    19 tundra trd
    Was just on website might get the shackle kit 2”
