High gloss VHT 3rd brake light tint success
Discussion in 'Lighting' started by vegas4x4, Feb 24, 2020.
  1. Feb 24, 2020 at 8:02 PM
    vegas4x4
    vegas4x4 [OP] Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    There’s a few tutorials on YouTube but id be happy to answer any questions.
    5 coats VHT on the unused portion of the light, 2 coats over the brake light, none over the cargo lamps. Then 4 coats of clear to hopefully keep this shine for a while.
    Used my work light to try and show off the reflection, and the transparency of the center section.
    842BAD3A-53BD-4CA2-A7E0-2F1EC7361DD4.jpg E7C549D0-B420-4642-9CFB-A206EEB67F61.jpg B925E088-923C-4AAB-BF9B-6E00075B6DA4.jpg F3481AA4-59DD-45F0-8C3E-FE0CF5C91FE6.jpg
  2. Feb 24, 2020 at 9:21 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice!
    GNTundra likes this.
  3. Feb 24, 2020 at 9:50 PM
    vegas4x4
    Las Vegas
    Thanks! Gonna try to get some pics on the truck tomorrow when its fully dry
    Y0TA PR0[QUOTED] likes this.
  4. Feb 24, 2020 at 10:09 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Looks nice!
  5. Feb 25, 2020 at 1:07 PM
    vegas4x4
    Las Vegas
    Still waiting to fully dry but heres a better view of the gloss. This is without a final cut & buff
  6. Feb 25, 2020 at 2:17 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Oh snap that looks good!
  7. Feb 25, 2020 at 7:21 PM
    vegas4x4
    Las Vegas
    Thanks! Will post pics tomorrow with it on the truck
  8. Mar 9, 2020 at 7:03 PM
    vegas4x4
    Las Vegas
    I totally forgot to update this with photos of it on the truck. So here u go:
    5CCF1F89-9317-4D5C-B4CE-F8D3ACB368C5.jpg CF6C5A21-D8E1-48DD-9F6F-329604A6B036.jpg B13396E1-669D-47C5-A703-95CCE20F86CE.jpg
  9. Mar 9, 2020 at 7:41 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Nice rig.
    vegas4x4[QUOTED][OP] likes this.
  10. Mar 9, 2020 at 7:44 PM
    TXTundra2722
    2015 Black Tundra
    That looks really good
    vegas4x4[OP] likes this.
  11. Mar 9, 2020 at 7:58 PM
    vegas4x4
    Las Vegas
    thanks guys. Havent got a photo of the 3rd brake light in the sun but it is visible.
  12. Mar 9, 2020 at 8:09 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Did you just use masking tape and then use an exacto to trim the exact shape of the reverse lights?
  13. Mar 9, 2020 at 8:52 PM
    TXTundra2722
    2015 Black Tundra
    Also waiting on a response to this
    :popcorn:
  14. Mar 9, 2020 at 9:08 PM
    vegas4x4
    Las Vegas
    I actually just very carefully taped it. No exacto involved. Tape the cargo lights first. Then tape the 3rd brake light area with pull tabs so i could easily remove it. Sprayed the surround very dark, pulled off the tape in the center, then sprayed a couple layers. Pulled off the tape over the cargo area then Sanded it all smooth, then clear coated. Then buffed it.
    Last pic has one thin coat over the center. The discoloration through the center portion of the light is the carboard box the light is sitting on. It had white and black on it
  15. Nov 26, 2020 at 6:11 PM
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    Could you just spray inside so you don't have to use gloss or buff the outside? Would the lights burn the paint?
