I Made a Boo-Boo... :(
Discussion in '2nd Gen Tundras (2007-2013)' started by ICECOLDBEER, Nov 25, 2020.
  1. Nov 25, 2020 at 6:52 PM
    ICECOLDBEER
    ICECOLDBEER [OP] New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    So I was backing out of the garage and caught my mirror... Need to fold them in I guess from now on. It's pretty tight.
    Wondering if this is an easy fix? It looks like you can just order replacement glass inserts. But I am wondering if I need to maybe get that backing plate as well because I think the plastic tabs broke off.
    I saw Doorman makes one. Or would it be better to get OEM? The glass is shattered but still one piece. (the picture doesn't look as bad but its cracked badly)
    Anyone do anything stupid like this before? haha
  2. Nov 25, 2020 at 6:54 PM
    ICECOLDBEER
    Sidenote... Anyone have access to repair manuals/diagrams for our Tundras? Would be very helpful.
  3. Nov 25, 2020 at 6:58 PM
    It would probably be cheaper to just replace the unit since the tabs are snapped off. It happens. If I didn’t have power folding mirrors, would be on my 5th set by now.
  4. Nov 25, 2020 at 7:07 PM
    ICECOLDBEER
    I think I need the mirror and the inside part of the mirror on the right... You may be right may need to get the whole thing... Hopefully you can buy that piece on the right separately.
  5. Nov 25, 2020 at 7:10 PM
    I had someone smash my 2012 CM mirror twice. First time I upgraded to tow mirrors, and the second time the glass was just replaced. If I remember correctly, glass alone was 91.00.
  6. Nov 25, 2020 at 7:24 PM
    Black Wolf and ICECOLDBEER[OP] like this.
  7. Nov 27, 2020 at 4:36 PM
    diavel
    diavel New Member
    Simon
    Tundra Platinum Flex Fuel 4x4
    It happens...I just did a quick check on ebay.com and there are plenty of cheap used ,complete , units that appear in good condition.Might be less hassle, in the long run, than fiddly repairs?
    YardBird likes this.
  8. Nov 27, 2020 at 4:47 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Same thing happen to my brothers Lexus and we dabbed a bit of JB Weld on each broken tab to buy some time until he purchased a new replacement. It has been three years now and he still hasn't purchased a replacement.
    Aesthetically and functionally you would never know that it had ever been broken.
  9. Nov 27, 2020 at 5:03 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Some of us still have the OEM little mirrors in our sheds, Find someone close and see if they will donate a mirror, or just buy one.
  10. Nov 27, 2020 at 5:19 PM
    I think the OP is a Canuck. He needs to check kijiji... @Outbound
    @Cpl_Punishment
    @mountainpete
    @BravoDeltaRomeo
    @SprinterAE86
    @RedGreen
    @MooseHead
    @Ad Nauseam
    :canada:
    NewImprovedRon likes this.
  11. Nov 27, 2020 at 5:51 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    I would like to field this question: YES
    In spades...won't bore you with the details, but have backed in to many objects; am there with ya, brother...
  12. Nov 27, 2020 at 6:29 PM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    I replaced my factory mirrors. Would be willing to donate the glass. You may still need the plastic casing that broke, but you’d be half way there.
  13. Nov 27, 2020 at 7:56 PM
    ICECOLDBEER
    Appreciate the replies guys. I just ended up buying a replacement from the parts store here. Was $130 taxes included. I thought that wasn't too bad. It looks the exact same. Should have it put on tomorrow. Tried kijiji but wasn't much locally. The parts guy said you can't order the inside part (blue circle on the right). Not sure if Toyota sells that part but it would probably be $$$$. It's sketchy driving without it. haha
    ColoradoTJ likes this.
  14. Nov 27, 2020 at 8:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Dang. Where are you located? I have my complete OEM mirrors sitting on a shelf from when I installed tow mirrors.
    @Black Wolf didn’t tag me. :notsure:
  15. Nov 27, 2020 at 8:42 PM
    ICECOLDBEER
    Ontario
    landphil[QUOTED] likes this.
  16. Nov 27, 2020 at 8:47 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Well, then. Not too practical anyway since shipping would take a chunk out of that $130, and you’d be a hazard on the road in the meantime.
    If you’re sneaky when you change the mirror you can remove just the triangular cover panel inside the door and pull the main inner door panel back enough to get a 1/4” drive ratchet on the bottom nut, instead of removing the entire door panel.
  17. Nov 27, 2020 at 8:49 PM
    ICECOLDBEER
    hmmm very sneaky indeed. Removing the door panel doesn't look too hard though.
  18. Nov 27, 2020 at 8:57 PM
    ICECOLDBEER
    Random question. Anyone drill holes into their bed so the water doesn't pool? Mine pools if its not parked uphill. Kind of thinking it might rust where I drill? It has some sort of linex/rubberized coating in the bed. Not sure if this is factory or aftermarket? Did Toyota offer anything like that? I really liked the plastic bed in my Tacoma.
  19. Nov 28, 2020 at 3:35 AM
    It wasn't intentional. Ha! I'll tag you first next time:thumbsup:
  20. Nov 28, 2020 at 8:13 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Don't drill the bed. You have plugs towards the front. Pull one if you really want or drill a hole in the plastic plug.
    Yeah, the spray on coating is not oem. Lots of people prefer it to the plastic liner, but it's really personal preference. I like to slide things in and out. I'm a liner person myself. Rubberized coatings can damage the stuff I put in the bed.
  21. Nov 28, 2020 at 8:17 PM
    ICECOLDBEER
    Okay cool Ill have to look for those plugs. Never noticed them.
  22. Nov 28, 2020 at 8:20 PM
    ICECOLDBEER
    Simple enough job. Got it done today. Works and looks good. This is the old light. What is this crap? Old glue or just dirt? Weird.
  23. Nov 28, 2020 at 8:21 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Where are you in Ontario @ICECOLDBEER ?
    There are a bunch on Kijiji right now and it’s an easy swap for a whole new mirror assembly.
    edit: I’m late to the reply party :)
  24. Nov 28, 2020 at 8:21 PM
    mountainpete
    looks like old road salt.
  25. Nov 28, 2020 at 8:23 PM
    ICECOLDBEER
    ITS COCAINE GUYS I HIT THE MOTHERLOAD!!!
    jk obviously
  26. Nov 28, 2020 at 11:12 PM
    diavel
    diavel New Member
    Simon
  27. Nov 29, 2020 at 4:51 AM
    Ha! Kind of like "Yank".
  28. Dec 3, 2020 at 8:02 AM
    TrucksRCool
    TrucksRCool New Member
    Jordan
    UT
    2021 CM Limited Nightshade
    I have nothing productive to add to this thread. Only posting to share the pain. This morning, I was backing out of my garage and the side of the garage must have narrowed by at least a foot or so and caught my mirror. Did the same thing as OP’s mirror. I don’t believe it had anything to do with my inattentiveness. It’s all the garage’s fault.
  29. Dec 3, 2020 at 9:19 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  30. Dec 3, 2020 at 9:32 AM
    Megaman
    Megaman New Member
    2020 Tundra Limited DC 4X4 TRD Silver Sky Metallic
    I've only had my Tundra for a month or so, and I've nearly ripped my PS mirror off twice!! At the last second, I seen it was going to hit the door frame so I jumped out and folded it in. Wish I had the motorized folding mirrors option.
    -So I'm sure mirrors have been abused a lot on these trucks!
