4x4 Low issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by Drew44, Nov 25, 2020.
  1. Nov 25, 2020 at 9:54 AM
    Drew44
    Drew44 [OP] New Member
    Drew
    Hey all, I'm having some issues with my 2018 Tundra while using the 4x4 low gear, don't know if anybody has issues with getting the low gear to engage.
    I was in a little bit of snow this weekend in the mtns. and had it in low 4x4. It was beeping like usual, but then the Low and the High indicator lights were both on simultaneously (usually it's one or the other). But in the low setting, it feels like the high gear is only engaged. When I switch it over to the regular 4x4 High setting, the beeping stops, and the high light is only on. Has anybody has experienced anything like this? I would appreciate any thoughts and troubleshooting guidance before getting it over to a service garage. It's got 46k miles and only used the low setting probably less than 5 times.
  2. Nov 25, 2020 at 10:02 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It shouldn't ever beep in the first place. Were you stopped in neutral before putting the selector to 4lo and then waited for it to engage?
    15whtrd, GODZILLA, Drew44[OP] and 3 others like this.
  3. Nov 25, 2020 at 10:06 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Need to be in neutral.
    15whtrd, GODZILLA and Drew44[OP] like this.
  4. Nov 25, 2020 at 10:07 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    ^^ This
    it only beeps when you aren’t actually engaged in 4Lo
  5. Nov 25, 2020 at 10:07 AM
    Drew44
    Drew
    It has always beeped (like no seatbelt) when in low 4x4. Yes, was in park (not neutral) when switched over.
  6. Nov 25, 2020 at 10:11 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I have spent a decent amount of time in 4Lo.
    Definitely should not be beeping.. pretty sure you have to be in neutral, not park.
    Give it a shot and see how it goes trying this approach. The lo gearing is very noticeable if properly engaged
    GODZILLA, TG705, AZBoatHauler and 4 others like this.
  7. Nov 25, 2020 at 10:11 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Can’t be in park. Only neutral
  8. Nov 25, 2020 at 10:34 AM
    AZBoatHauler
    So.Arizona
    What everyone else said.
  9. Nov 25, 2020 at 10:52 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If it’s beeping “like normal”, you’ve never actually been in 4wd. Beeping indicates an improper gear transfer and is not normal.
  10. Nov 25, 2020 at 10:59 AM
    NoRcptn
    NorCal
    2017 Platinum
  11. Nov 25, 2020 at 11:12 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I use 4HI regularly, but never needed or even tried 4LO. I'll give it a try soon.
    I'm guessing there are safety measures in place to prevent throwing it into 4LO when driving? Either it doesn't engage or the knob doesn't turn ?
    Drew44[OP] likes this.
  12. Nov 25, 2020 at 11:18 AM
    snivilous
    SW UT
    The safety feature is what happened to OP, it beeps and flashes and won't shift itself.
  13. Nov 25, 2020 at 11:32 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Gotcha, thanks!
    Time to find some snow and test out 4LO. Shouldn't be too difficult, being November in Winnipeg.
    Cpl_Punishment and Drew44[OP] like this.
  14. Nov 25, 2020 at 11:35 AM
    Drew44
    Drew
    well, I've been doing it wrong all these times. You're right, beeping means you did not do the sequencing correctly. I put it in neutral (not park) and clicks into low gear- does not beep.
    While in Low, it does say VSC Turned off, Pre-Collision Brake System Unavailable.
    I'll just take the 2 slices of Gordon Ramsey bread and stick em over my ears... :sandwich:
    Thanks all, really appreciate your quick responses.
  15. Nov 25, 2020 at 12:29 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Your visor has a piece of paper showing you how to engage 4 hi and 4lo. For anyone that doesn't know that. Now you know. :thumbsup:
    Drew44[OP], 15whtrd, TTund16 and 2 others like this.
  16. Nov 25, 2020 at 11:25 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    ...next is the high rpm and low speed while in 4 low
