I got side swiped today on way to work.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kturner23, Nov 24, 2020.
  1. Nov 24, 2020 at 1:28 PM
    Kturner23
    Kturner23 [OP] New Member
    Keith
    2018 Tundra Crewmax Limited
    Anyone know if the pillar will have to be replaced. A buddy of mine said done correctly would end up running 10k min low end.
    Rica25 likes this.
  2. Nov 24, 2020 at 1:34 PM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Ouch. What hit you? that damage is quite high up.
    GODZILLA and Rica25 like this.
  3. Nov 24, 2020 at 1:36 PM
    Kturner23
    Keith
    Lady in an 2012 f150 going about 50 while I was accelerating from a stop light at around 20mph
    Rica25 likes this.
  4. Nov 24, 2020 at 1:36 PM
    Flying Fuzz
    Flying Fuzz New Member
    2019 GX460 Premium with Sport package.
    When I was a teenager I T-boned a pickup in the same spot, I was told that’s one of the most expensive places to hit a truck. I can’t answer your question but I hope I’m wrong.
    Rica25 and Blue Thunder like this.
  5. Nov 24, 2020 at 1:39 PM
    Kturner23
    Keith
    My buddy said. The pillar has to be cut and replaced. Bed has to be replaced also. Mirror is trashed also. Meaning all windows and interior have to be removed for the correct work and painting to take place.
    Rica25 likes this.
  6. Nov 24, 2020 at 1:41 PM
    Blue Thunder
    Washington
    Ouch...that sucks.
    GODZILLA, Tundra14Platinum and Rica25 like this.
  7. Nov 24, 2020 at 1:41 PM
    GreatBigAbyss
    That's a TON of work. With that amount of work, I'd rather the vehicle get written off. Probably not likely, though, given how the truck's only a couple years old.
  8. Nov 24, 2020 at 1:59 PM
    Elduder
    Elduder New Member
    Pillar will for sure need a cut and swap, but its an external cut, not a support frame cut. Luckily the bed is just a bedside. Mirrors are about 250-300 and come prepainted, I lost mine the same way. Took about 30 mins to replace myself, neither window nor interior trim needed to be pulled with the exception of the sail panel that takes 30 seconds to pop out. Aside from that the body shop will replace the one door and they will have to remove the rear seat and trim on the corner.
    Darkness and Black Wolf like this.
  9. Nov 24, 2020 at 2:02 PM
    :eek: I would be so pissed off it wouldn't be funny.
    duece292, GODZILLA and CavalryCrew602 like this.
  10. Nov 24, 2020 at 2:03 PM
    Elduder
    Elduder New Member
    Not really, the mirror will be between 2-300, the door about 500. The box will either be a full swap or a cut and weld job. One option will probably be about 1-2k with a used part, the other will be less. Paint will be a couple be between 1-2k. Its nowhere near enough to total it, which in a way, sucks.
  11. Nov 24, 2020 at 2:06 PM
    Kturner23
    Keith
    So even its dented through to inside door latch? No frame compromise? Good info. I appreciate it
  12. Nov 24, 2020 at 2:10 PM
    Elduder
    Elduder New Member
    No promises, thats where a good shop or adjuster works their magic. But, no based of the location and depth, it doesnt appear too bad. I had similar and the shop seemed unfazed by it.
  13. Nov 24, 2020 at 2:15 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Am so sorry for you....
    Not even my truck and I feel sick looking at those pics....hang in there.
    GODZILLA likes this.
  14. Nov 24, 2020 at 2:16 PM
    Elduder
    Elduder New Member
    For the mirror its attached with 3 nuts and a harness, just pop the sail panel off and unbolt. Easier with two people but I did mine myself quickly.
    Panel off for speaker swap, but you can see 2 of the bolts for the mirror in the top left.
    NewImprovedRon likes this.
  15. Nov 24, 2020 at 2:23 PM
    Elduder
    Elduder New Member
    Mirrors: Left sided
    87940-0C400-J0 No BSM, no dimming ~$165
    87940-0C390-J0 BSM, no dimming ~240
    Not sure if your mirror has a chrome cap, those are for the Cavalry Blue painted ones.
  16. Nov 24, 2020 at 2:23 PM
    Kturner23
    Keith
    RIP carfax. Only had the truck 5 months
  17. Nov 24, 2020 at 2:24 PM
    Kturner23
    Keith
    I replaced the. Ita a limited
  18. Nov 24, 2020 at 2:28 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'll give you $3k and get the truck this week if it's within two states of Utah :D
  19. Nov 24, 2020 at 2:34 PM
    This^^^
  20. Nov 24, 2020 at 2:36 PM
    Easily fixable.
    Elduder likes this.
  21. Nov 24, 2020 at 2:37 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    Yeah trade in or resale value is going to take a hit, not to add insult to injury. I was hit in my Tacoma, and it cost 7500 to fix, and was listed on Carfax as a serious impact, even though the actual hit wasn't bad, it was just a lot of plastic and one painted panel. Oh well. Such is life. Good luck.
    Kturner23[OP] likes this.
  22. Nov 24, 2020 at 2:37 PM
    I'm assuming the lady was at fault and she had insurance. If so go for diminished loss value too. Still suxs though.
  23. Nov 24, 2020 at 2:39 PM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Its minor damage, keep the estimate and when you go to sale it show it to the potential buyer if they even ask for it.
  24. Nov 24, 2020 at 2:41 PM
    Kturner23
    Keith
    Bummer. Would take 3k but unfortunately I'm more than 2 states away. Eff you covid I could have made a profit
    snivilous[QUOTED] and Black Wolf like this.
  25. Nov 24, 2020 at 2:44 PM
    Might not need a new door. Hard to tell without actually looking up close.
  26. Nov 24, 2020 at 2:44 PM
    Kturner23
    Keith
    Yup she just thought I was a bug zapper and ran that f150 sized bug right into it. No traffic. 3 lanes 1 tundra
    Elduder and Black Wolf[QUOTED] like this.
  27. Nov 24, 2020 at 2:46 PM
    Elduder
    Elduder New Member
    Agreed
  28. Nov 24, 2020 at 2:47 PM
    Kturner23
    Keith
    Trade in for 60k used tundra with 100k miles right now?? Lol
    k
  29. Nov 24, 2020 at 2:47 PM
    Figures. A lady was texting and rear ended my 07 in broad daylight. Cost her insurance $8K
  30. Nov 24, 2020 at 2:47 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    When you work with the adjuster it will be for primary damage.....but, don't forget to argue for your "diminished value" that resulted, i.e. Carfax for resale.
