Anyone use Morimoto puddle/mirror lights?
Discussion in 'Lighting' started by Dyollp, Nov 23, 2020.
  1. Nov 23, 2020 at 7:56 AM
    Dyollp
    Dyollp [OP] New Member
    Bay Area
    2020 White Platinum
    Skippy likes this.
  2. Nov 23, 2020 at 3:18 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    The design of the morimoto look a little better in term of it, 'snap' in. I have the vleds and it's held in by double sided tape. After 2yrs the driver side had started to sag. That's something to consider.
    The vleds are pretty bright. Dont know how bright the morimoto are.
  3. Nov 23, 2020 at 4:51 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Run some LED strip lighting along the under jambs of your doors. Puts the light right where you need it vs shining on your door. You can tap into your courtesy lights. Total cost under $20.
  4. Nov 24, 2020 at 6:20 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Snaps into place just like OEM! :) Definitely a good jump over the stock setup, saved my shoes from menacing puddles a couple of times getting out of the Tundra! :rofl:
  5. Nov 24, 2020 at 8:03 AM
    BrandonL812
    Brandon
    Do you know what their rated color temp is?
  6. Nov 24, 2020 at 8:08 AM
    Atlanta, GA
    They come out to be a 5,500k color temp! That is right in the middle of 5K Pure white and that 6k modern LED white color you'll see out there!
    Skippy and BrandonL812[QUOTED] like this.
  7. Nov 24, 2020 at 8:20 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    How did you route the wires?
  8. Nov 24, 2020 at 8:48 AM
    BrandonL812
    Brandon
    5500k is same as the vleds one.
    I would totally get these if you are in the market for one. Clip in like factory, good, bright, color temp. No messy double-sided tape.
    Im starting to consider getting these and sell the vleds one.
    Skippy and Headlight Revolution like this.
  9. Nov 24, 2020 at 9:53 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Are they really only $27 for the pair? Or is that each?
    :spending:
  10. Nov 24, 2020 at 9:56 AM
    Atlanta, GA
    That's for the set man! You'll get x2 mirror lights per 1 order. :)
  11. Nov 24, 2020 at 9:58 AM
    Squatting Pigeon
    Holden
    North Texas
    Nice!
    I see another mod in my near future :rofl:
  12. Nov 24, 2020 at 9:59 AM
    Atlanta, GA
  13. Nov 24, 2020 at 2:29 PM
    Fred
    Hand Protectors
    The red and black wire go up and tap into the courtesy light wires.
