Kill switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by abner, Oct 8, 2020.
  1. Oct 8, 2020 at 5:36 AM
    abner
    abner [OP] New Member
    2017 CM 1794
    I have a 2017 1794 tundra, would like to install a hidden kill switch. Has anyone done this and if so how.
    Mountun Goat likes this.
  2. Oct 8, 2020 at 6:06 AM
    timsp8
    NY
    I asked about this before years ago and the thread got deleted or something cause it disappeared. I think you could put it on ignition wires and hide the switch under the dash somewhere.
    tttrdpro likes this.
  3. Oct 8, 2020 at 7:16 AM
    Cajun1977
    Cajun1977 New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
    Search chrisfix on YouTube. He has a detailed video doing this mod.
  4. Oct 8, 2020 at 7:23 AM
    timsp8
    NY
  5. Oct 8, 2020 at 7:28 AM
    Broncoman
    Broncoman New Member
    Quick fix: Go to a parts store and ask for a High Beam Switch for a 1968 Camaro. Mount this on the floor left of the brake pedal and run the wires under the carpet to the side panel the you can either wire it to the ignition or to the fuel pump. $10.00 or less for the part
    Mountun Goat and CavalryCrew602 like this.
  6. Oct 8, 2020 at 7:30 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    yes, I use an oem switch inside the cab via a relay to the starter..
    hint, you need a momentary switch..
    NewImprovedRon and Mountun Goat like this.
  7. Oct 8, 2020 at 7:36 AM
    CavalryCrew602
    CavalryCrew602 New Member
    2019 Crewmax XP Tundra
    Borla exhaust, Alpine Halo 9 head unit, Oracle Colorshift rock lights, 3in lift on 17in Fuel bead locks, Paragon bed cover, Recon lights...TBC
    If bell bottoms can make a comeback why can’t these switches...
    Mountun Goat and awq735 like this.
  8. Nov 22, 2020 at 7:18 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I tossed a ignition cable switch from the battery to starter on my c10. Works unreal as it sits 98% of the time. Flick the switch it fires up -20 middle of winter.
    Now that I’m working an 8/6 shift the goat sits for 8 days in a row during the winter. I plan on cutting a switch into the tundra circuit here as well. I’ll update once I get it installed.
    BUGEATER likes this.
  9. Nov 23, 2020 at 6:54 AM
    BUGEATER
    BUGEATER SAPPER SWiG
    Nebraska
    2014 black SR5 limited 4x4
    I’ve been wanting to do this. Can’t wait to see what you come up with. :popcorn:
    Mountun Goat[QUOTED] likes this.
  10. Nov 23, 2020 at 7:34 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    doesnt the truck already have this feature or something like it - engine immobilizer
    asking for a friend :rofl:
    Mountun Goat and NewImprovedRon like this.
  11. Nov 23, 2020 at 7:47 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    https://www.torquenews.com/4140/inside-toyota-tundra-theft-and-what-you-can-do-prevent-it
    I'm pretty sure Toyota/Lexus that don't have the buttonless entry + push button start system are not vulnerable to relay attacks because they aren't actively listening for a signal. Like my wife's Lexus, you walk up without needing to push anything on the fob, pull door handle, open door. Lots of Lexus relay thefts around Toronto.
  12. Nov 23, 2020 at 7:59 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Side note, saw on fb someone had their cat cutoff while parked at the airport. Started the truck, "wow, that sounds cool... oh, NOOO"
  13. Nov 23, 2020 at 8:03 AM
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Can just do what we do on heavy equipment, have a master key switch. Have your ground go from frame to one side of the switch, and your ground from battery to the other side. Switch the key off and battery is disconnected, switch it on and battery is connected
  14. Nov 23, 2020 at 6:31 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    @abner
    I just added one today.
    This setup is more just a prolonged battery isolator than a hidden switch. Although, I’m sure this would still leave most scratching their heads... I work one week at a time and it sits with all its battery robbing jewelry and kills the battery in freezing temps, so here’s my fix.
    I started by drilling a 3/4” hole in the inner fender skins and roughing in the switch location.
    Then I crimped a 1’ long-0 gauge welding cable for the positive circuit extension. Bolted this from switch side (-) side of the switch to the positive battery lug.
    Oh right, I decided to upgrade the oem battery lugs for some generic brass lugs as the factory’s were getting stretched and loose.
    Decided to keep all the factory cables/lugs in tact incase I suck at wiring haha. So, I re-routed the winch and oem positive lug cables to (+) side of the switch and taped the hell out them to form a harness.
    Then, I added a power-tap, for future electrical panel upgrade and stereo. I started with a 1’ long-4 gauge cable tied to an old Phoenix Gold single 4 gauge to quad 8 gauge power splitter. Bolted the splitter to the top/rear of the oem fuse panel lid.
    That’s bout it. :hattip:
    BUGEATER and Tundyfundy like this.
