What OEM Steel Rims can you use for your Tundra?
Discussion in 'Wheels & Tires' started by wwolvverine, Nov 23, 2020.
  1. Nov 23, 2020 at 5:41 AM
    wwolvverine
    wwolvverine [OP] New Member
    2018 Tundra 1794
    I see there is Toyota ( 426010C60) and 426010C050. The latter being a spare wheel. Do steel rims make a difference?
    Thanks,
  2. Nov 23, 2020 at 7:31 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Make a difference to what/who? They're cheap and able to be bent and bent back in many cases off roading...the lighter the vehicle, the better steel wheels will work/last.
  3. Nov 23, 2020 at 7:42 AM
    wwolvverine
    2018 Tundra 1794
    These are OEM from toyota.
  4. Nov 23, 2020 at 8:00 AM
    HulkSmurf14
    2014 Tundra Limited
    Yeah, that's 100% understood...I'm just wondering what your question is... "Do steel rims make a difference?" For spare tires or for running at all times? A difference in what or to what?
  5. Nov 23, 2020 at 8:45 AM
    wwolvverine
    2018 Tundra 1794
    In terms of being able to go the same speed as aluminum's or even safety. Thanks,
  6. Nov 23, 2020 at 8:48 AM
    HulkSmurf14
    2014 Tundra Limited
    thank you for clarifying...if you offroad or mall crawl, you'd be good to go...if you tow a lot, the aluminum counterparts will be more strong. Constant speeds over 90mph+ perhaps might present issues, but in reality, the tires will be the issue and not the wheels...you're good to go either way...
    wwolvverine[OP] likes this.
  7. Nov 23, 2020 at 9:02 AM
    wwolvverine
    2018 Tundra 1794
    Thank you.
    HulkSmurf14[QUOTED] likes this.
