Engine seized up. What a POS
Discussion in 'Off-Topic Discussion' started by BTBAKER, Nov 22, 2020.
  1. Nov 22, 2020 at 4:56 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    My Echo weed whacker engine smoked. I’m thinking of going battery on the next one.
  2. Nov 22, 2020 at 4:59 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    :rofl::rofl::rofl:
    Good one, you had me for a moment!
  3. Nov 22, 2020 at 5:02 PM
    Willard
    Willard New Member
    2024 F250
    I went from an echo srm225 to a dewalt flexvolt 60v trimmer and have been very pleased. I also have their flexvolt 600cfm blower, which is awesome.
    Saltyhero13, BTBAKER[OP] and YardBird like this.
  4. Nov 22, 2020 at 5:03 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Did you check it for a leaking cam tower? What oil are you using? :burp:
  5. Nov 22, 2020 at 5:09 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Air injection pump must have gone out.
    I have had good luck with battery. Even the cheap one at menards is on its 3rd season. Will be a Dewalt when this one dies
    Darkness, Cpl_Punishment and Rica25 like this.
  6. Nov 22, 2020 at 5:09 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Probably cause it didn’t have a transmission cooler...
  7. Nov 22, 2020 at 5:15 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I use a scan gauge II with the Exho app to keep an eye on the exhaust temps.
  8. Nov 22, 2020 at 5:19 PM
    WTF?
    Aren't your weeds dead now anyways?........wait until next Spring when the new weeds cover up the old ones. Easy peasy
  9. Nov 22, 2020 at 5:20 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You smoked your weed whacker??!? Duuuude!!
  10. Nov 22, 2020 at 5:22 PM
    OP meant he smoked weed while using the wacker....
  11. Nov 22, 2020 at 5:22 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I seized what you did there...
  12. Nov 22, 2020 at 5:24 PM
    It....is...what....it.....is....Yota
  13. Nov 22, 2020 at 5:25 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  14. Nov 22, 2020 at 5:27 PM
    Damnit.....
  15. Nov 22, 2020 at 5:46 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I got a battery string trimmer after my echo fried also. Best thing ever
    Darkness, Black Wolf, Rica25 and 2 others like this.
  16. Nov 22, 2020 at 5:49 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    When your truck is reliable, you have to go into other areas of conversation to keep the tundra forum interesting.
  17. Nov 22, 2020 at 6:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Heres the one I have, but I was already set up with Milwaukee tools.
    Link.
    The only time it quits is if the batteries run out. Not a big issue for me as I have plenty of extras. It clears weeds around trees in our heavily wooded yard of about 8 acres. Does the ditch too.
    received_749330825671511.jpg received_383646269541823.jpg received_316418699314432.jpg
    Word of advice for you if you plan on extending your electric yard tool arsenal. Get the one in the link provided with the quik-lok adapter on the shaft. Milwaukee makes a version of the weed eater without this.
    Heres a link to that one.
    Link.
    If you get the quik-lok one you can use different attachment heads. I have the pole saw attachment. Its sweet.
    Link.
    More tools/flexibility with one power base.
  18. Nov 22, 2020 at 6:01 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I was feeling frisky after watching a Bronco victory. Super bowl!
    Darkness, Tundra2 and Black Wolf like this.
  19. Nov 22, 2020 at 6:02 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Love your yard!
    Tundra2[QUOTED] and landphil like this.
  20. Nov 22, 2020 at 6:04 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I’m gonna do it. Echo makes one that is supposed to be good but I have quite a few Milwaukee batteries.
    Black Wolf and Tundra2 like this.
  21. Nov 22, 2020 at 6:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks. You should be here for the holidays.
    Heres a picture of the saw for posterity.
  22. Nov 22, 2020 at 6:19 PM
    Rica25
    Ricardo
    Tulare
    I have a Shindaiwa edger and weed eater for 25 yrs and still running. Have only replaced the little prime probe Once that has been all. I still can't believe it's still running
  23. Nov 22, 2020 at 6:38 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Better than a pole !
    OP- I have the M18 weed eater and would never go back to a gas motor
    BTBAKER[OP] and Rica25 like this.
  24. Nov 22, 2020 at 7:39 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    I read the title and I thought for sure, this was another elk hunter story.
  25. Nov 22, 2020 at 7:42 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I was trimming around my mailbox at the time of the failure.
  26. Nov 22, 2020 at 7:45 PM
    easleycrawler
    Travis
    BTBAKER[QUOTED][OP] and Rica25 like this.
  27. Nov 22, 2020 at 8:08 PM
    We have a clever bunch here to make up for the boredom that reliability causes. On other big 3 forums it's known as derailment.....
  28. Nov 22, 2020 at 8:43 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Never smoked an engine but definitely seized a few clutches back in the day
    Darkness, Black Wolf and BTBAKER[OP] like this.
  29. Nov 22, 2020 at 9:17 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You need a diesel trimmer for that job.
  30. Nov 22, 2020 at 10:12 PM
    GravityGear
    Aurora, CO
    I had the privilege to try an EGO trimmer when I was in FL. My neighbor's mower had died and he asked to borrow my lawnmower. 2 weeks later, he bought an EGO mower and trimmer. He saw me bring out my Ryobi 18v trimmer and came out to stop me. He let me use his EGO trimmer and it was amazing.
    Rica25 and BTBAKER[OP] like this.
