Instrument cluster glass
Discussion in '2.5 Gen Tundras (2014-2021)' started by netranger6, Nov 21, 2020.
  1. Nov 21, 2020 at 1:19 PM
    netranger6
    netranger6 [OP] New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Brand new 21. Used some non oil based wipes and got some on cluster. Now it won't wipe off. Any suggestions? I have had 4 tundra and all get scratches super easy on that glass. But this is first time I couldn't wipe off excess interior wipe residue.
  2. Nov 21, 2020 at 1:29 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    Maybe isopropyl alcohol? What did you use, like a dash cleaner?
  3. Nov 21, 2020 at 1:43 PM
    NorcalHntr
    NorcalHntr New Member
    Nor cal
    2018 Sr5 Tundra Trd Crewmax Mgm
    I did the same thing on my '18 except it was a spray. The only thing I found to get it off was olive oil.
    Tried alcohol degreaser and reapplying the protectant didnt work
    It was very frustrating. I thought I may have etched the plastic it was just overspray though. Needless to say I threw away that protectant.
    CavalryCrew602 likes this.
  4. Nov 21, 2020 at 5:16 PM
    netranger6
    Jeremy
    Interior wipes. For plastic. Non petroleum based.
    Black Wolf likes this.
  5. Nov 21, 2020 at 5:17 PM
    netranger6
    Jeremy
    Olive Oil? On the clear plastic in front of instrument cluster..worked?
  6. Nov 21, 2020 at 5:53 PM
    NorcalHntr
    Nor cal
    Yes it did it. I tried a little spot first to see if it would work. I used olive oil dabbed on a paper towel not too much. Rubbed it in gently so I didn't scratch the plastic. It took a couple times to get it all off. Then I used windex to clean the oil off. It could work for you not sure. Worth a try, Half my guage cluster was "fogged" over, I was pretty bummed
    netranger6[OP] likes this.
  7. Nov 21, 2020 at 7:42 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    It is not glass it is a hard coated plastic. Using anything like rubbing alcohol based solvents will only harm the plastic. Use a soap and water solution to remove it.
  8. Nov 21, 2020 at 7:44 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Strongly recommend microfiber towels.... paper will scratch it....
  9. Nov 22, 2020 at 11:51 AM
    netranger6
    Jeremy
    I freaking can't stand this uber eazy scratchy plastic man. What a stupid part.
    AggiePhil likes this.
  10. Nov 22, 2020 at 12:02 PM
    Charliebrn
    NW Ohio
    The manufacturers don’t have a lot of choice. They can’t use glass and a lot of harder materials due to the hazards they would pose in an accident.flying shards aimed at your face is a bad thing.
  11. Nov 25, 2020 at 2:18 PM
    ChesterSPL
    ChesterSPL New Member
    Shawn
    2020 SR 4x4
    My truck is only 6 months old and that plastic is all scratched up. I am gentle with it because I came from a Tacoma and it scratched also but not as bad as the Tundra. I think ever time I look down at the speedo it gets mad or something, turns defiant and scratches itself just to get to me.
    CavalryCrew602 and Black Wolf like this.
  12. Nov 25, 2020 at 2:58 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    That plastic is a pain. I just switched mine out. They really aren’t that bad a price
  13. Nov 26, 2020 at 4:34 AM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    Try Plexus. I use it with microfiber and get good results.
  14. Nov 26, 2020 at 4:50 AM
    CavalryCrew602
    CavalryCrew602 New Member
    2019 Crewmax XP Tundra
    Borla exhaust, Alpine Halo 9 head unit, Oracle Colorshift rock lights, 3in lift on 17in Fuel bead locks, Paragon bed cover, Recon lights...TBC
    Jay Leno’s interior detailer with micro fiber towels is my hindsight...it’s generally 2020!
