Metal Oil Filter Cap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wilbur, Mar 24, 2016.
  1. Mar 24, 2016 at 7:23 AM
    Wilbur
    Wilbur [OP] New Member
    Savannah, GA
    2014 MGM
    After I did my first oil change, I knew I was going to break the plastic piece of shit somehow. Well...I did. I do not know why the would put a plastic one on the truck but they did. After some research I found they made a metal one that fits. Popped on Amazon where toyota has a store, and got this guy for pretty cheap. Only thing I had to do was put the tundra tube into the housing as it is longer than the one it comes equipped with. I am a lot more confident in this cap and do not now why they didnt equip these vehicles with it in the first place.
    http://www.amazon.com/Genuine-Toyot...psc=1&redirect=true&ref_=od_aui_detailpages00
    Highly recommended.
  2. Mar 24, 2016 at 7:25 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I found this write-up the other day. Was thinking of doing the same.
  3. Mar 24, 2016 at 7:27 AM
    Wilbur
    Savannah, GA
    2014 MGM
    thats the exact one i found! Figured i would bring the knowledge over here. Takes maybe a minute to swap out the tubes.
  4. Mar 24, 2016 at 7:50 AM
    csuviper
    Broomfield, CO
    Nice. If you want to reiterate how to transfer it over and add up some pics we can turn this into a DIY thread??
  5. Mar 24, 2016 at 8:25 AM
    Wilbur
    Savannah, GA
    2014 MGM
    I think i may have the parts still in my garage at home. Let me check, might have thrown them out.
  6. Mar 24, 2016 at 6:05 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Switched out mine on the first oil change. Didn't break the plastic one during removal - just didn't like it.
    robie56 likes this.
  7. Mar 25, 2016 at 12:30 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I'll be doing this to my 2014 Tundra when its time for my first oil change. I'll do a wright up. I understand that it requires some modification. Can't believe Toyota put such a cheap part on such an important and frequently used item... :annoyed: I hope this is not a new trend...
  8. Mar 25, 2016 at 1:35 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    I'm sure Toyota knew they could make some more cash on the side by selling the others rather than including them. Its a universal trick done by the greedy.
  9. Mar 26, 2016 at 1:10 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Swapped mine for the aluminum one on the first oil change. Think I paid $25 for it. Well worth it!
    FirstGenTundra likes this.
  10. Mar 27, 2016 at 2:36 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    The recently eliminated Driver's side grab handle comes to mind.
  11. Mar 28, 2016 at 7:32 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    Great find!
  12. Jul 28, 2020 at 7:25 AM
    Skul-N-Bones
    Skul-N-Bones New Member
    2019 Tundra Crewmax
    Working on it
    I have a 2019 CrewMax 5.7. My guess is this will fit and I understand I will have to swap out the perforated core as the Tundra core is longer. However, this doesn't seem to come with a drain plug. Do I need to order a drain plug as well or can I reuse the original one and is the original one metal? Sorry I can't see it well enough without having to pull the skid plate first.
    Thanks
  13. Jul 28, 2020 at 8:00 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    You can reuse the original drain plug, which is metal.
  14. Jul 28, 2020 at 8:12 AM
    Zero One Actual
    fore_runner, TRDblvd and Bob_Wiley like this.
  15. Jul 29, 2020 at 9:36 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Swapped mine out at 5k miles, doing my own oil changes.
    Bob_Wiley likes this.
  16. Jul 30, 2020 at 3:43 AM
    Zero One Actual
  17. Jul 30, 2020 at 5:04 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    How are the plastic caps being broken?
  18. Jul 30, 2020 at 5:15 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Uuuuhhhhhhhh.............put on by gorillas? Thus requiring removal by gorillas????
  19. Jul 30, 2020 at 6:18 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    No, it's nothing new. I can name some earlier issues like rusty frames and beds and the dreaded AIP valves.
  20. Jul 31, 2020 at 3:05 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I am curious about this also, my 2010 has 77k miles on it and I recently changed the oil for the 15th time with the plastic element holder, no problem.
    timdske and Rex Kramer[QUOTED] like this.
  21. Jul 31, 2020 at 3:59 AM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I've changed the oil on many Toyotas with the canister type filter and I've never had an issue with the plastic cover. Generally when I've replaced them it was due to the previous person used the wrong tool to remove the cover and broke it. I've had more problems with aluminum covers than plastic. Saturn would be a nightmare when the goon before would use all his weight tightening it. This is my set I use for Toyota vehicles. Never had a problem.
    Rex Kramer likes this.
  22. Jul 31, 2020 at 4:41 AM
    Rex Kramer
    Georgia
  23. Nov 21, 2020 at 8:07 AM
    bfunke
    bfunke Tundra Curmudgeon
    How did you get the old tube out of the OEM housing? Did you have to bend the metal tab? I don't want to damage it.
