Which aftermarket muffler?
Discussion in 'Performance and Tuning' started by shayned97, Jul 26, 2020.
  1. Jul 26, 2020 at 1:21 PM
    shayned97
    shayned97 [OP] New Member
    Shayne
    2016 Blazin Blue Tundra TRD Offroad
    5.7 sounds great.....but it could sound better. So I was thinking of getting the TRD Exhaust but after a bit of thinking spending $1000+ on it doesn't seem to make much sense when the stock one does the job. So I decided I am OK with spending the money to swap the muffler to get better sound. Anyone have any recommendations? Once the stock pipes rust out ill get TRD but this will be a stop gap.
    YardBird likes this.
  2. Jul 26, 2020 at 1:22 PM
    Seaflea
    Seaflea New Member
    William
  3. Jul 26, 2020 at 2:31 PM
    shayned97
    Shayne
    Appreciate the help to BAMufflers. I've seen that recommended around the forum but that is a full system and I'm looking for a weld in muffler rather then a full system. Just to save some cash.
    Tundyfundy likes this.
  4. Jul 26, 2020 at 2:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have a 5x11x22 magnaflow in my stock pipes. It has just a fuzz more volume than stock, no drone tho. Any louder of a muffler and you will have drone.
    i have also tried a spintech 3000xl. Amazing sound, droned pretty bad though
  5. Jul 26, 2020 at 2:49 PM
    shayned97
    Shayne
    Would you mind linking the one you have?
  6. Jul 26, 2020 at 2:59 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I put the Gibson MWA on. It sounds decent but drones. Put a resonator from DD on and it helped a lot. Just be aware that if you pick the wrong muffler it will drone and cost you extra to buy the resonator
  7. Jul 26, 2020 at 2:59 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Another vote for Keith @dirtydeeds call him I bet he’ll make you a weld in... he is the best and his systems are legit for the Tundra!
    Beesta and HulkSmurf14 like this.
  8. Jul 26, 2020 at 3:52 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have this https://www.magnaflow.com/products/...nterdual-straight-through-performance-muffler
    It actually has some rumble on the outside, very quiet inside, just a low hum. If your tailpipe has the factory resonator, then it has almost zero interior hum (ive tried both tailpipes).
    overall i like the sound a lot. Ive also had the dirty deeds, which is waaaay cooler, but for a lot more investment.
  9. Jul 26, 2020 at 4:38 PM
    On a budget? Get a decent Flowmaster knock off. Flowmaster's patent has expired. Get a Flowsound dual 2.25" inlets with single 3" outlet. (a size that Flowmaster doesn't make by the way) Mine is going on Friday. Welded in of course. Should be minimal low end torque loss and it's using the same size inlets and outlet and keeping the single exhaust. I fully expect it to be just fine. I found about the Flowsound on a couple well known Jeep forums with excellent reviews. $30 to $40. If there is drone, which I doubt, it's quite easy and cheap to add a Hemholtz style resonator which would be an additional $15 at my go to place.. No need to spend $600+ for a decent single exhaust and you simply use your current mid pipes and exhaust pipe with minor adaptation. My install cost will be $225. Peanuts....I'll post pics and sound check. I'm pretty good over the years here doing mods on a budget with great results.
    :mudding:
    Saltyhero13, 2010bigdog and Chrslefty like this.
  10. Jul 26, 2020 at 4:53 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Beesta, 16 blue crewmax and CNE0207 like this.
  11. Jul 26, 2020 at 5:10 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Check the group buys... you can score a BA Muffler for a great deal on here
  12. Jul 26, 2020 at 6:16 PM
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    I’m running a weld in Magnaflow as well and really like it. Nice throaty low end sound but no real drone in the cab. Sorry, don’t know which one. I had it done at a local muffler shop.
    Black Wolf likes this.
  13. Jul 26, 2020 at 11:08 PM
    Nifty_Nate
    Nifty_Nate New Member
    Got a part number or link? I can only find a 3" single in and 2.5" dual out, but the flow would be going the wrong way.
  14. Jul 27, 2020 at 12:02 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    On my last truck I had a flowmaster, they upped the pipe to 3" from cat back and it was amazing. Whole system was like 300 bucks
  15. Jul 27, 2020 at 5:21 AM
    Nifty_Nate[QUOTED] likes this.
  16. Jul 27, 2020 at 5:45 AM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    Keith at dirtydeedsindustries@gmail.com has just the muffler as well as the full system i would check with him first
    CNE0207 likes this.
  17. Jul 27, 2020 at 6:40 AM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    I just ordered my system from Keith. I'd give him a call for a good deal.
    CNE0207 likes this.
  18. Jul 27, 2020 at 3:25 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    This will really explain the systems and give you some direction.
  19. Jul 27, 2020 at 3:36 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Again... Keith is the man.
    MTRock and dirtydeeds[QUOTED] like this.
  20. Jul 27, 2020 at 10:03 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    I installed a black widow venom 250 dual 2.5" in, single 3" out with a single tailpipe exiting in front of the rear tire. Exterior volume isn't obnoxious, but sounds very healthy. Interior noise is noticeable on acceleration, but once cruising, the exhaust note almost completely dissipates. The tire noise at 70 mph is louder than the exhaust. Been super happy with this exhaust thus far and can't recommend it enough. There is literally zero drone when cruising, I can't stress that enough.
  21. Oct 28, 2020 at 7:41 PM
  22. Nov 13, 2020 at 1:50 PM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Tundra234, WILLINH and MTRock like this.
  23. Nov 13, 2020 at 4:48 PM
    dirtydeeds
    Keith
    USA
    sale ends 11/15/20
  24. Nov 13, 2020 at 5:38 PM
    glowblue
    glowblue From time to time
    VA
  25. Nov 13, 2020 at 5:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    All or just stainless?
    dirtydeeds likes this.
  26. Nov 14, 2020 at 9:40 AM
    dirtydeeds
    Keith
    USA
    The sale that ends tomorrow is for stainless.
  27. Nov 20, 2020 at 12:08 PM
    Alkare
    Alkare New Member
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Just installed my 12" from Dirty Deeds. Love it!!!
