RSI SmartCap coming in July
Discussion in '2.5 Gen Tundras (2014-2021)' started by RedNecky, Apr 10, 2020.
  1. Jul 6, 2020 at 10:56 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Not feeling it, that's an ugly cap on both fronts.
    Tundyfundy and Tracy Perry like this.
  2. Jul 18, 2020 at 6:18 PM
    LJOHNS
    LJOHNS New Member
    Agreed...
  3. Sep 16, 2020 at 1:05 PM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    First post! Was just at a local (Vancouver, BC) dealer looking for cap (and other) options for my yet-to-arrive 2021 CrewMax TRD Off Road Premium. Figured with the 10-15 week lead time most are quoting, I'd better get moving.
    Stopped in and looked over a Smartcap Evo. Boy, they are nice. Fit and finish is exceptional. The side windoors are silky smooth and HUGE, though no way to screen the openers; the vent looks like it might work. Roof rails are nicely integrated. Looked a bit blocky, but again, really well made. Dealer said they're dropping the price to $4999CAD which makes it just a few hundred more than a similarly equipped ARE CX-HD, or Leer, for that matter.
    HOWEVER: The one glaring issue I can see will be condensation. All that steel will be a dripping nightmare for half the year. They do not, to my understanding, offer any insulation options.
    Result: I'm going with the good old lined ARE CX with windoors, tracks, and a front slider - $4k taxes in.
  4. Nov 19, 2020 at 3:19 PM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    After a long wait, I had this installed last week. This thing is built well. I am impressed with the quality, too.
  5. Nov 19, 2020 at 3:34 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Nice wheels!!!
    rochmpr[QUOTED] likes this.
  6. Nov 19, 2020 at 3:59 PM
    timsp8
    NY
    No leaks or anything? The back looks like it’s too far forward to make a good seal.
  7. Nov 19, 2020 at 4:03 PM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    It does not fluch out and overlap the tailgate like fiberglass tops. There is a seal there. Haven't had enough rain to see how everything seals, but i have never seen a topper / bed water tight.
    timsp8[QUOTED] likes this.
  8. Nov 20, 2020 at 4:10 AM
    timsp8
    NY
    Looks nice. I know what you mean. My ARE leaked at the front. I had to put some butyl tape on the front corners to fix it. You can’t see it, but it’s a pain to remove it when I want to take the cap off for anything.
  9. Nov 20, 2020 at 6:03 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    can you take photo of cab to shell area not sure if i want to loose the full rear window roll down
    thanks nice set up
  10. Nov 22, 2020 at 2:49 PM
    cch2a
    cch2a New Member
    Its funny I normally don't like shells but kind of liking this one. Nice truck.
    rochmpr likes this.
  11. Nov 30, 2020 at 7:57 AM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
  12. Dec 3, 2020 at 11:30 AM
    INT.EGRATED
    INT.EGRATED New Member
    2016 Tacoma TRD Sport MT 4x4
    do these have some sort of window in the front to access the bed from the cab? it’d be nice if they had both a slide and pop in
  13. Dec 13, 2020 at 3:30 PM
    PC12Pilot
    PC12Pilot New Member
    James
    2010 Black Tundra
    Just put mine on my 2010 Crewmax. I really like it. It sits flush with my tailgate compared to newer Tundras. It has little sliding windows in the front and on both sides as well.
  14. Dec 13, 2020 at 3:38 PM
    INT.EGRATED
    Can you show any pics/video of how the front slide works? Wonder if this'd be worth it with rear sliding windows on tundra.
  15. Dec 13, 2020 at 4:01 PM
    PC12Pilot
    James
    2010 Black Tundra
    Kind of hard to jump on there and get a video, but here is a picture of the front slide. Just a finger pinch and slide right. Is probably 10 x 12 or 8 x 10 window
    RookieEP likes this.
  16. Dec 14, 2020 at 9:49 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Can the RSI be opened from the inside?
  17. Feb 17, 2021 at 6:44 PM
    RedNecky
    RedNecky [OP] New Member
    Patrick
    2017 Crewcab TRD OR White
    Undercover SE Tonneau
    I sent two web requests asking for the weight of the Tundra, short bed unit, without any options. I never heard back. I then called them and was told it weighs 246 pounds without any options in the short bed configuration. I’m not sure how this compares to a fiberglass unit, but it seems heavy. You better have help if you want to remove it! It is a very nice unit but I think I’ll stay with my Undercover tonneau cover.
  18. Feb 18, 2021 at 10:17 AM
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    how you liking it?
  19. Feb 18, 2021 at 11:17 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Payload capacity remaining: Zero
    Saltyhero13 and clarkritchie like this.
  20. Feb 18, 2021 at 12:25 PM
    #50
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    No screens, no interior lighting, no insulation, no power connections, no large slider, no thank you.
  21. Feb 23, 2021 at 9:36 AM
    #51
    November Sun
    Huntsville, Alabama
    I don't like how it doesn't sit flush at the tailgate on the 3rd Gens.
  22. Mar 29, 2021 at 3:19 PM
    #52
    Last of the V8
    Last of the V8 New Member
    21 limited Trd calvary Blue
    Rsi smartcap, predator steps, roadmaster suspension, nicks tyranny cooler. Rago dash mount plate. Console safe.
    In case anyone wants to see a double cab version on 6.5 foot bed.20210329_140523.jpg
  23. Mar 29, 2021 at 4:23 PM
    #53
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Saw one of these on a ram today, man are they ugly
