Microfiber dye bled on paint
Discussion in 'Detailing' started by Airn890, Nov 19, 2020.
  1. Nov 19, 2020 at 3:09 PM
    Airn890
    Airn890 [OP] New Member
    airn
    2021 tundra
    So...
    Brand new white 21 tundra
    I used lacquer thinner to remove painted pin stripes.
    luckily I only did the front fender before I realized that the dye literally made my fender look like a highlighter.
    I didn’t realize it was a terrible idea to use a yellow microfiber.
    I hope someone can help here recommending a polish or compound to use.
  2. Nov 19, 2020 at 3:14 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
  3. Nov 19, 2020 at 3:14 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Post up a pic. Maybe try rubbing alcohol on a white terry cloth
    BravoDeltaRomeo likes this.
  4. Nov 19, 2020 at 3:15 PM
    YotaBro
    Calvin
    FL
    Dawn dishsoap is a degreaser and might help it. It might remove your clear coat so you might need to rewax it after. But I agree, start with rubbing alcohol too.
  5. Nov 19, 2020 at 5:04 PM
    Airn890
    airn
    2021 tundra
    I don’t have a pic right now. Man this sucks. I’m going to try rubbing alcohol in one spot
  6. Nov 19, 2020 at 5:07 PM
    JackwagonJim
    JackwagonJim New Member
    Purlear, NC
    Been there before. Isopropyl alcohol on terry cloth rag as noted above.
    Wynnded likes this.
  7. Nov 19, 2020 at 5:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Confirming that IPA will remove wax, but the CC should be okay.
  8. Nov 19, 2020 at 6:45 PM
    JackwagonJim
    Purlear, NC
    Yup. You will needto rewax.
    Did this on my old tacoma..used red rag and isopropyl to get pitch offthe hood. Then had to use a white rag to remove the red.
    Btw.. keep the iso off any vinyl, like flat black..itll add a sheen to it..ask me how I know. :)
    Wynnded likes this.
  9. Nov 20, 2020 at 8:39 PM
    briarpatch
    briarpatch New Member
    Dawn won't remove clearcoat......you need an abrasive for that
    NewImprovedRon likes this.
  10. Nov 20, 2020 at 8:44 PM
    briarpatch
    I have not heard of this one yet. In the event you need a polish, you should be able to buy Meguiars Ultimate Polish locally. If not, call local auto parts stores, or shops that supply automotive paint, and see of they have some Meguiars M205. You will need to re-apply any wax once you're done.
  11. Nov 20, 2020 at 8:49 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    painted pinstripe? That doesn’t sound right to me
  12. Nov 21, 2020 at 6:54 AM
    briarpatch
    What part of it seems wrong? There are some guys who still do painted pinstriping.....most use a stencil. Once in a while, you find someone with the skill to do it freehand.
  13. Nov 21, 2020 at 6:55 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  14. Nov 21, 2020 at 2:57 PM
    Airn890
    airn
    2021 tundra
    Ya the stripes were definitely painted on.
    honestly I got rid of most of it but in my mind I can still see a hue.
    either way, lesson to all: only use white terry cloth with lacquer thinner!
