Adding some rake to stock TRD Fox Pro suspension
Discussion in 'Suspension' started by Terndrerrr, Nov 18, 2020.
  1. Nov 18, 2020 at 8:30 AM
    Terndrerrr
    Terndrerrr [OP] 923000 miles to go
    Music City
    6UR-FE
    How did you go about doing this? I searched and it looks like most people are adding coachbuilder shackles. Have any of y’all swapped in rear leafs (dobinsons or deaver k37 or u748) and kept the TRD Fox rear shocks?
  2. Nov 18, 2020 at 9:00 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Just purchase longer shackles, Coach Builder, ToyTec, Pro Form Fab. No need for new leaf springs. The shackle upgrade is so easy, and it gives you the rake you want.
    mountainpete and Terndrerrr[OP] like this.
  3. Nov 18, 2020 at 9:01 AM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    My understanding is that new spring packs are best but they’re pricey. Most guys who are running new spring packs have also upgraded their suspension (beyond what you would find on the Pro).
    TheBeast and Terndrerrr[OP] like this.
  4. Nov 18, 2020 at 9:46 AM
    Bad Cow
    Georgia USA
    Just to achieve "rake" why spend the $ on an entire spring pack? The short and sweet answer is "shackles".
    mountainpete likes this.
  5. Nov 18, 2020 at 9:54 AM
    Terndrerrr
    Music City
    6UR-FE
    I will be towing/hauling some pretty heavy loads, and I really don’t want any squat in the rear.
  6. Nov 18, 2020 at 9:57 AM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I went with the TC 3/4" shackles with the Icon expansion pack.
  7. Nov 18, 2020 at 10:00 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    How heavy? Tundras tend to do well with airbags and daystar cradles for loads at or beyond payload capacity. A combo of shackles or Icon add a leaf and airbags is common, reliable and proven to add some rake plus manage heavy loads.
  8. Nov 18, 2020 at 10:42 AM
    Terndrerrr
    Music City
    6UR-FE
    I expect to be towing around 5k-6k lbs several times a year. And filling the bed with lumber and brick/stones. I'm just worried about doing all that while leveled.
    Bad Cow likes this.
  9. Nov 18, 2020 at 10:57 AM
    Bad Cow
    Georgia USA
    If you plan on working your suspension like that, then you definitely need some major upgrades, more than just shackles.
  10. Nov 18, 2020 at 11:05 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    A properly set up trailer like that is <600lbs of tongue weight. That's about half of the Pro's rated payload, and should pose no issue at all with shackles.
    Now "filling" the bed with bricks is a bit concerning.... If you're doing demolition work, or letting the home center drop a pallet of pavers in your bed, then you might want to consider a dump trailer. Because adding several thousand dollars to a $55K truck and then using it to haul rubble is crazy in my opinion.
  11. Nov 18, 2020 at 11:58 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Personally, I'd go with the Icon expansion pack so you gain a little travel.
  12. Nov 18, 2020 at 12:19 PM
    TheBeast
    TheBeast The Beach
    new leaf pack + bags if towing a lot.
    I like Deaver myself. custom or U748 min for hauling
