Switching to full synthetic... When.....
Discussion in 'Off-Topic Discussion' started by Jerry311SD, Nov 16, 2020.
  1. Nov 16, 2020 at 7:42 PM
    Jerry311SD
    Jerry311SD [OP] New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    So my Benz is dead,we were able to pick up a 2018 civic with 20k miles from the local Honda dealership.
    The oil in it looks new. But when it's time to change it does it matter if I do full synthetic with 20k miles.
    I'm thinking it won't hurt at all.
    YardBird likes this.
  2. Nov 16, 2020 at 7:47 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Check your manual, Honda might recommend synthetic and it may already have that in it. Most new cars are running synthetic to go further between changes.
  3. Nov 16, 2020 at 7:58 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Agreed^^^^. I’d be surprised if it isn’t using synthetic already.
    GODZILLA and Jerry311SD[OP] like this.
  4. Nov 16, 2020 at 8:14 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    From what I can find all variants of the 2018 Civic run 0-20 synthetic.
  5. Nov 17, 2020 at 4:55 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Yeah Im finding the same. Looks like full Synthetic is what ill be throwing in it in about 5000 miles.
    Slow little car and the CVT trans is interesting but its something reliable for her to drive to work and something I wont have to work on too much,
    YardBird and BTBAKER[QUOTED] like this.
  6. Nov 17, 2020 at 5:41 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, my parents rented a Civic on a recent trip and hated the CVT. Also, I didn't think those 1.5T engines were super reliable, though maybe they've gotten better since they were first produced.
  7. Nov 17, 2020 at 7:49 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    theyre good little cars, just watch for oil burning. it plagues all the modern 4 cylinders. 5k mile intervals will really help prevent that from being an issue. its the extended intervals with 0 weight oil that causes the rings to eventually seize and allow blow by
    Cpl_Punishment likes this.
  8. Nov 18, 2020 at 4:55 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Being in San Diego I was going to Run 10-30 in it.
  9. Nov 18, 2020 at 5:51 AM
    empty_lord
    05 rollover special
    Ehhh, I wouldn’t. Going that much heavier will affect how the vtec will function. The engines designed to work with 0w-20. 5w-20 isn’t a bad idea
    Heavier oil can have weird side effects on new cars
  10. Nov 18, 2020 at 6:17 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    No issue at 20k. Just don’t cheap out on the filter. Synthetic can be had at a reasonable price at Walmart, if you’re gonna DIY.
