2004 Tundra no crank electric is good to the fuses
Discussion in '1st Gen Tundras (2000-2006)' started by Danjojo55, Nov 14, 2020.
  1. Nov 14, 2020 at 8:00 PM
    Danjojo55
    Danjojo55 [OP] New Member
    2011 Tundra
    This tundra has been sitting for some time, put a strong battery in it where nothing came on. Took battery out and cleaned battery terminals and ground points. Reinstalled battery the following became live
    *head lights
    *tail lights
    *interior lamps
    *instrument lights
    *drivers side seat controls/ didn’t try passenger seat
    *Windshield wipers
    *exterior mirrors
    ** no radio is currently installed and I did not check for power
    Items I noted that did come on line
    #windows, door locks
    #Cargo light
    #starter did not crank engine- also, I did not hear the start relay
    Any help of the direction I might try. I am mechanical but not so much a mechanic by trade any way.
    Thank you
  2. Nov 15, 2020 at 6:23 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nothing happens at all? Any sound when you turn the ignition?
  3. Nov 15, 2020 at 6:42 AM
    Danjojo55
    2011 Tundra
    no sound. i dont know if the buzzer or bell has been disconnected by the previous person.
    the instrament lights do come on right away.
  4. Nov 15, 2020 at 6:45 AM
    Voss
    2003 AC TRD 4x4
    Check the ignition fuse.
  5. Nov 15, 2020 at 7:23 AM
    Danjojo55
    2011 Tundra
    ok, im pretty sure i checked and found them good.
    i cannot get to the truck until Tuesday morning, but i will recheck again. With all the fueses i easaly could have missed this one.
    if its good, next place to look?
  6. Nov 17, 2020 at 12:31 PM
    Danjojo55
    2011 Tundra
    Fueses seem to be good, what powers up the door locks and windows
  7. Nov 17, 2020 at 1:16 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    With the key 'on' does the check engine light turn on?
    This will let you know the ECU has power.
  8. Nov 17, 2020 at 1:24 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    You positive about that battery?
  9. Nov 18, 2020 at 6:02 AM
    Battery cable corrosion or other contact / wiring corrosion. Also chewed wires are good things to check for.
