Which Harness to get? Headunit install
Discussion in 'Audio & Video' started by mcduck, Nov 12, 2020.
  1. Nov 12, 2020 at 8:57 PM
    mcduck
    mcduck [OP] New Member
    McDuck
    2019 Tundra
  2. Nov 14, 2020 at 12:24 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    OK, so you have a Pioneer head unit that you want to install. And, you listed the part numbers for the Maestro RR and the corresponding Maestro TO2 wiring harness. My first question is: did you already purchase those two Maestro parts? Question 2: Did you plug your info into the iDatalink website to confirm that those two parts will be compatible with your new Pioneer H/U?
  3. Nov 14, 2020 at 12:30 PM
    glowblue
    glowblue From time to time
    VA
    Check out Crutchfield...
    AntLBFD likes this.
  4. Nov 16, 2020 at 5:26 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Definitely check out idatalink website. Plug in your car info and they list everything you need.
  5. Nov 16, 2020 at 5:56 PM
  6. Nov 17, 2020 at 2:17 AM
    preacher35
    Not sure if this guy is coming back, BUT, if he does, and wants to install the Maestro RR, he needs to absolutely get the TO2 harness.
