What happened here?
Discussion in '2.5 Gen Tundras (2014-2021)' started by cjcbama, Nov 3, 2020.
  1. Nov 3, 2020 at 12:39 PM
    cjcbama
    cjcbama [OP] New Member
    Looking at buying a 2017 Tundra Limited. Everything looked good until I popped the hood. Any ideas what caused the firewall insulation to get messed up like that? Please see attached picture.
  2. Nov 3, 2020 at 12:49 PM
    Welcome from NY.
    Looks like mice were getting in.
    Tundyfundy likes this.
  3. Nov 3, 2020 at 12:49 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mice or other rodents...they LOVE that insulation!
    tttrdpro likes this.
  4. Nov 3, 2020 at 1:08 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Is the brake fluid super clean or just absent?
  5. Nov 3, 2020 at 1:15 PM
    cjcbama
    I also noticed the reservoir looked empty so i reached over and bumped it. It was empty.
    hagrid likes this.
  6. Nov 3, 2020 at 1:24 PM
    Tortuga83
    Tortuga83 New Member
    Tortuga
    I would say move on from that Tundra. Empty resi might be a bad omen.
    CO_Native and tttrdpro like this.
  7. Nov 3, 2020 at 1:25 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Rodents. They love the insulation and also the wiring in Toyotas because Toyota uses some kind of soy based products in it. Had that issue and some dryer sheets and peppermint oil spray solved it.
    Edit: unless its the lighting that empty brake fluid resi is not confidence inspiring on how that truck was taken care of.
    2manytoys likes this.
  8. Nov 3, 2020 at 1:31 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
  9. Nov 3, 2020 at 1:40 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Tundra234 and hagrid like this.
  10. Nov 3, 2020 at 1:54 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    The empty brake fluid reservoir would scare me far more than the insulation. There's a pretty serious leak somewhere that the previous owner ignored. I'd be afraid of other maintenance issues that have been ignored, or even worse, crudely patched. I shudder to think about what condition the engine oil is in, and whether it was ever changed on a regular basis.
  11. Nov 3, 2020 at 2:17 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I wouldn’t buy it. Do as you please.
  12. Nov 3, 2020 at 2:17 PM
    Adam New Member
    Looks like it is at a dealer. See if they have the service records on it just for shits and grins. I would stay away personally unless they are giving it at a fire sale price with a full warranty.
  13. Nov 3, 2020 at 2:56 PM
    timsp8
    NY
    That wiring looks like it’s been repaired too, which could also mean something chewed through it.
    ShinyConcretE likes this.
  14. Nov 14, 2020 at 2:00 PM
    Tortuga83
    Tortuga
    Did you end up purchasing the Tundra?
  15. Nov 14, 2020 at 2:46 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Same thing, same place on my 2019, vermin of some sort. I found the start of a nest on top of the engine cover, went to the car wash, soaked the entire down and the engine bay down in engine cleaner and washed away all the grime and scent of what ever it was trying to build a home there, no problems since.
    Check your cabin air filter, I replaced mine after that as well in case it had made it to there.
    HulkSmurf14 likes this.
  16. Nov 15, 2020 at 4:53 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Here’s the pics from my 2919
    550137AD-041E-4242-A398-8D6E6B90373C.jpg D50E9493-8709-46F3-A9F2-701126D9875B.jpg
  17. Nov 15, 2020 at 6:25 PM
    Randy Morton
    Randy
    Those with, and without, rodent damage might want to invest in a can of this.
