Falling brake pedal
Discussion in '1st Gen Tundras (2000-2006)' started by wcooperider3rd, Nov 14, 2020.
  1. Nov 14, 2020 at 12:54 PM
    wcooperider3rd
    wcooperider3rd [OP] New Member
    Wayne
    2005 Tundra Double Cab Sr5 4.7L RWD
    Alright. So I have had this problem I'm pretty sure the whole time I had the truck. (Since 2017) so I recently replaced my drums September 19th. In the process, wd ruptured a brake cylinder and picked up one, and obviously had to bleed brakes. MC never went empty. About a month ago, I was in Vegas and noticed my e brake didn't catch. At all. Adjusted the drums fully, and now it'll be hard on initial application after driving a bit, but after I stop it'll fall to the floor. Also when I left go, I feel like the rear brakes kind of let go a bit late. And if I'm in park, even with pumping, the brake is soft af. Bleed all 4 points with engine running and no air in system. Also, I can hear a hissing each time brakes are applied near the abs module, and inside the brake line that goes to the rear left brake (the cylinder we replaced). Could the module be bringing air into the system?
  2. Nov 14, 2020 at 5:48 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    I’m about to replace all my brakes. Curious, don’t know that it’s related, but what brake fluid did you put in when bleeding?
  3. Nov 14, 2020 at 5:49 PM
    wcooperider3rd
    Wayne
    DOT 3. That's it. Brake fluid is brake fluid other than that.
    YardBird likes this.
  4. Nov 15, 2020 at 9:13 AM
    jpink
    Knoxville
    Maybe, I wasn’t looking for brand. I know 5.1 is recommended due to boiling point being higher than 3.
    I don’t know about the hissing, but my pedal is spongy and the LSPV is already adjusted near the top on mine.
    As much as it might suck it might be worth getting it jacked up again and in position so you can see/hear what’s happening better.
    My, inexperienced, thoughts.
  5. Nov 15, 2020 at 9:30 AM
    Professional Hand Model
    Fred
    Hand Protectors
    In order bleed:
    1) Pass rear 20-25 pumps
    2) LSBPV 15-20 pumps
    3) Driver rear 15-20 pumps
    4) Pass front 15 -20 pumps
    5) Driver front 15 pumps
    I bleed mine with truck off and board under brake pedal.
  6. Nov 15, 2020 at 9:32 AM
    How many times did you have to fill the res during a full bleed?
  7. Nov 15, 2020 at 9:32 AM
    wcooperider3rd
    Wayne
    How do you bleed the LSBPV? I've seen / heard people adjusting it ... I've never touched it yet
  8. Nov 15, 2020 at 10:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It has a bleeder valve on it, same as any brake.
  9. Nov 15, 2020 at 1:48 PM
    Fred
    Hand Protectors
    About every 10 pumps to be on the safe side. Maybe 15 max.
  10. Nov 15, 2020 at 1:48 PM
    Fred
    Hand Protectors
    Same a wheels. You might have some gnar gnar up it there.
