So I want to install a turbo...
Discussion in '1st Gen Tundras (2000-2006)' started by TruckGoBurr, Nov 13, 2020.
  1. Nov 13, 2020 at 8:59 AM
    TruckGoBurr
    TruckGoBurr [OP] New Member
    Louis
    2003 Red Toyota Tundra SR5
    Straight Pipe Inverter
    I own a 1st Gen Toyota Tundra and I'm very interested in installing a turbocharger which I have seen across this forum a couple of times. A couple of people said just to buy a supercharger but i cant seem to find any for my truck which brings me back to the Turbo. My truck is still pretty stock and I was wondering what modifications should I make before installing a turbo and also if anyone could point me in the right direction on where to do more research on turbos.
    https://www.ebay.com/itm/For-Tundra...E-2UZFE-2UZ-Land-Cruiser-4-7L-v8/183150139532
    Mountun Goat and TomGreen like this.
  2. Nov 13, 2020 at 9:27 AM
    TomGreen
    TomGreen New Member
    I would love to see someone attempt this kit. Seen it for a long time on the internet. I wish they had taken more pics from different angles
  3. Nov 13, 2020 at 9:27 AM
  4. Nov 13, 2020 at 9:29 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That's a great option for cheap. your only problem is going to be tuning. You'll likely need to go completely custom tuning, which is spendy.
    wandering_boy, Hooptytrix and hagrid like this.
  5. Nov 13, 2020 at 9:56 AM
    TomGreen
    TomGreen New Member
    I could be wrong, I often am, bit I think @dirtydeeds is running like 6 psi without a tune
  6. Nov 13, 2020 at 10:12 AM
    GravityGear
    Aurora, CO
    CHOO CHOO BOI!!!
    If I was going to turbo an older engine, I would at least do a compression check across all the cylinders. When you turbo something, you'll be creating increased crank case pressures. I personally would like to know if my rings are sealing properly still. Also, make sure to check your valve cover gaskets as they can blow out due to the increase crank case pressure. Check/change your trans fluid, make sure you're still getting proper lockup with the TC. If you're having issues now, the extra power may speed you up towards a replacement or rebuild.
  7. Nov 13, 2020 at 10:17 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The 4.7 can take boost. Just not a lot. I think 6 psi is like max safe boost.. connecting rods are weak on these engines
  8. Nov 13, 2020 at 1:38 PM
    TruckGoBurr
    Louis
    When it comes to custom tuning where would I have to go?
    The truck is running great and has been for years (was my dads before being mine) but I will check everything and post my results soon!
    Mountun Goat likes this.
  9. Nov 13, 2020 at 2:04 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Definitely interested to see how this turns out!:burnrubber:
  10. Nov 13, 2020 at 2:19 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Why do you want a turbo charger? I think is a waste of mula!!!
    Dr Doobie and 2mchfun like this.
  11. Nov 13, 2020 at 2:42 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    @TruckGoBurr doesn't Magnusson have a supercharger available for 03?
  12. Nov 13, 2020 at 2:46 PM
    Half the shit we do to our trucks is a waste of money. We don't always need a reason.
  13. Nov 13, 2020 at 2:51 PM
    bmf4069 Captain wtf
    Turd gens are a waste of mula!
  14. Nov 13, 2020 at 3:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    This sort of talk only encourages us.
  15. Nov 13, 2020 at 7:34 PM
    FirstTruck
    Stock, for now
    100% Correct. Maybe 90%?
  16. Nov 14, 2020 at 12:46 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Do it and tell all about it here.
  17. Nov 14, 2020 at 12:51 PM
    TomGreen
    TomGreen New Member
  18. Nov 14, 2020 at 12:58 PM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
  19. Nov 14, 2020 at 2:00 PM
    TruckGoBurr
    Louis
    https://www.amazon.com/gp/product/B013OL5TBG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Just purchased this for checking the cylinders pressure, I'm also going to get it realigned soon!
  20. Nov 15, 2020 at 1:24 PM
    TruckGoBurr
    Louis
    Compression seems to be good, im getting around 170 psi for each cylinder.
    Also think I need to clean the engine bay just so it looks a little nicer when I throw in the turbo.
  21. Nov 24, 2020 at 3:55 PM
    Toyotajunky
    Toyotajunky New Member
    Silver 2004 Tundra 4.7
    Unichip Shorty headers Shift kit Hot air intake SOS lowering kit
    I also have purchased the turbo kit for my Tundra. I have yet to install it, it's my daily. I might try and boost it on stock a ECU, when I finally get around to it
  22. Dec 3, 2020 at 6:15 AM
    TruckGoBurr
    Louis
    ***QUICK UPDATE***
    I'm currently in the process of decking out my truck I purchased new fuel injectors which should also make better use of the Turbo. I finished installing the inverter and ran an extension cable from the back of the truck to the front. http://dirtydeedsindustries.com/product/fuel-injectors/
  23. Dec 3, 2020 at 6:30 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Digging around the memory bank (I'm getting old) I remember many companies trying to turbo Toyota vehicles and the end result was the end of the project. The engines usually blow and the tuning was an issue. I do know that some have finally been able to crack the toyota cpu but I don't know if our cpu is on the list.
    I always thought that at some point in time we would see a cpu specialist for toyota like Hondata is for Honda, unfortunately.....
  24. Dec 3, 2020 at 6:38 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    @ViktorG might be a very valuable member to talk to @TruckGoBurr
    I love the idea of boosting, even a small amount of boost makes for a safe/better time
    Tundra2 likes this.
  25. Dec 3, 2020 at 7:03 AM
    TruckGoBurr
    Louis
    Im considering just buying a completely new ECU i just have no clue what to get.
    I'll send him a quick dm, but what should I talk to him about?
    Mountun Goat[QUOTED] likes this.
  26. Dec 3, 2020 at 7:39 AM
    This is 1st gen section. I think Viktor has a 5.7..
  27. Dec 3, 2020 at 10:27 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yes I understand that.
    @TruckGoBurr
    He also is a custom tuner. So might be helpful for someone who wants to ask computer tuning questions too. And he’s a Toyota mechanic as well. I’m sure he’s seen a 4.7 a coup times?
  28. Dec 3, 2020 at 1:54 PM
    empty_lord
    05 rollover special
    I’m very curious if anyone has managed to tune with the stock ecu on a 1st gen 4.7
    robabeatle, Mountun Goat and Tundra2 like this.
  29. Dec 4, 2020 at 9:45 AM
    wrmathis
    wrmathis New Member
  30. Dec 17, 2020 at 9:57 AM
    TruckGoBurr
    Louis
    I'm seeing this just after I purchased this: https://jetchip.com/shop/chips-modules-programmers/v-force/jet-v-force-plus-performance-module-8/, but I will update you guys when it gets here. (Also you get 25% off promo code so if anyone's interested). The fuel injectors came in yesterday and I'll be updating you guys on that shortly as well. Also should I make a YouTube channel to document the progression of my truck, so far its still pretty much stock with a straight pipe and new headlights?
    *Just realized that the tunes you showed me are for the tuner I bought so ill look into those.*
