Towing a 35 foot 7000lb trailer - Need Airbags?
Discussion in 'Towing & Hauling' started by GNX6, Nov 11, 2020.
  1. Nov 14, 2020 at 3:20 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    That was my point...was making it from first hand experience vs reading it on the internet /s
    Ruggybuggy[QUOTED] likes this.
  2. Nov 14, 2020 at 9:08 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Agreeing and confirming.
  3. Nov 15, 2020 at 7:04 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Don't do it.
  4. Nov 15, 2020 at 7:05 AM
    Ray Christensen
    Ray Christensen New Member
    Ray
    Forest Grove, Oregon
    2018 Tundra Double Cab Longbed
    A.R.E. Canopy, Deck rail system, Tube style running boards, Front and Rear TRD sway bars, Blackout lettering, FUEL Covert rims and Goodyear skins, blacked out bumper corners, grill surround and hood bump.
    Great video! Made me think of things that I hadn't taken into consideration when it comes to buying a travel trailer. Ya, you might be able to pull it but can you steer it or stop it
    Cpl_Punishment likes this.
  5. Nov 15, 2020 at 8:03 AM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I have a 32’ trailer that I bought last year. We got in 9 trips this year and I am currently working on getting an HD truck. It does ok with basic in-state trips but is clearly overmatched for the long trips. This is with a high quality WDH and I never carry water. Not feasible to do what you have described and still be within the payload specs. When you get to the hills or run into significant wind it will be a very uneasy situation. If something bad does happen you can be at fault for being overloaded.
  6. Nov 15, 2020 at 8:34 AM
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    For what that probably costs you could buy a well used 1 ton HD dually and be a lot happier going down the road.
    landphil likes this.
  7. Nov 15, 2020 at 8:50 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I would echo most everyone on here. You need a new truck or a much smaller set up.
  8. Nov 15, 2020 at 9:36 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    If you're from a state that allows triples then you'd be good to go. I've seen several like that in the south, some of them are motorized. You unhook and then drive the trailer into its spot. Lots of triples set ups down here.
  9. Nov 15, 2020 at 9:52 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've never seen anything like this before. Just looks odd. If the added fifth wheel carrier was motorized I could see it being handy to back in the 5th wheel in tight situations.
  10. Nov 15, 2020 at 10:06 AM
    18" TRD Off Road Wheels
    Look up the Mr. Trailer safety hitch. I think that's what it is.
    Here's a link. You have to scroll down. https://mrtrailer.com/safetyhitch.htm
  11. Nov 15, 2020 at 1:52 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The only advantage to that would be to keep the payload off the truck but I would rather spend the money on a more capable truck.
  12. Nov 15, 2020 at 1:59 PM
    I think I agree. The added length would be unmanageable for anything remotely off road. No clue what they cost, either. I imagine they are not cheap.
  13. Nov 15, 2020 at 2:13 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    U will have to have a trans cooler (lol(
    Bammer, Jaypown and Cpl_Punishment like this.
  14. Nov 15, 2020 at 3:04 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    The OP has been quiet.....
    I am guessing he is on his way back this Sunday from his camping and kayaking trip in the setup from his first post?:D
  15. Nov 15, 2020 at 8:43 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Yep terrible experience.. good luck backing that thing into a campsite
  16. Nov 15, 2020 at 8:45 PM
    It's not like a triple. It can lock to back as normal. Read the info in the link posted previously.
  17. Nov 16, 2020 at 8:15 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Just wait for the new 2022 Tundra Duramax HD 3500. :notsure:
  18. Nov 16, 2020 at 8:26 AM
    knoxville36
    Knoxville, TN
    Haha, you might be waiting until 3022 for that....
  19. Nov 16, 2020 at 8:34 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It may not be right for a Tundra and I have no personal experience, but it may be more maneuverable than I thought.
    https://www.safetytowingsystems.com/faqs/
    Ruggybuggy likes this.
  20. Nov 16, 2020 at 8:40 AM
    #50
    Terndrerrr
    Music City
    6UR-FE
    it’s gonna be a diesel hybrid that gets 45mpg. It’ll only weigh 5k lbs and drive like a mid-engine Corvette, yet it will have a payload of 3k lbs. It’ll tow 30k lbs but won’t be pushed around by it. It’ll also come with LT suspension, a fully boxed frame, front and rear lockers, and a Toyota winch. It’ll be a great commuter, daily driver, off-roader, overlander, and tow pig. It’ll have the nicest ride on-road, off-road, loaded, and unloaded. It will be a crewmax with a short bed that extends from 5.5’ to 8.1’ at the push of a button. It will be all things to all people.
  21. Nov 16, 2020 at 9:40 AM
    #51
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    Will it have a transmission cooler?
  22. Nov 16, 2020 at 9:46 AM
    #52
    mountainpete
    It's going to be a CVT so no cooler necessary.
