2018+ TSS issues with a lift - Can it be re-caliberated?
Discussion in 'Suspension' started by DarknessReigns, May 5, 2019.
  1. May 5, 2019 at 5:52 AM
    DarknessReigns
    DarknessReigns [OP] New Member
    Hey everyone,
    I'm looking to buy a truck this week and on the fence about getting a 2018/2019 model.
    The reason is because I have read and watched some youtube vids suggesting that TSS has caused some issues for people with lifts.
    Also one person mentioned that you can re-caliberate the TSS at the dealer after you put a lift on.
    Can anyone confirm this is true and if this should solve the issues of TSS acting up?
    I'm planning on putting on a 4.5" BDS lift if that is of any help.
    Thank you
  2. May 5, 2019 at 5:55 AM
    timsp8
    NY
  3. May 5, 2019 at 8:32 AM
    DarknessReigns
    AggiePhil likes this.
  4. May 5, 2019 at 8:36 AM
    It can be recalibrated, by dealer only. As long as it’s level (like it is from factory)
    Edit: rather slight rake
    realtorblake likes this.
  5. May 5, 2019 at 8:44 AM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I have a 5/3 lift that left a slight rake in the front. No TSS issues so far. I think not having the rake might cause me problems. If I could get rid of the TSS, I would.
  6. May 5, 2019 at 8:55 AM
    undermyvoodoo82
    undermyvoodoo82 New Member
    '19 Crewmax Limited TRD
    My '19 is getting recalibrated tomorrow. I told my service advisor I was planning on a leveling kit and he said good thing I told him beforehand because they can't address the recall after it has been leveled and he made a comment they were working with the guys that purchased "factory" leveled trucks from the dealership.
  7. May 5, 2019 at 9:33 AM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    im slightly nose high without any issues yet... I have a 2019
  8. May 5, 2019 at 11:08 AM
    timsp8
    NY
    There is a lot of discussion in that thread about recalibrating trucks with a lift.
    If you read through the whole thread, it mentions some dealers won’t touch a lifted truck. It also says that Toyota says if it’s lifted then the dealer should turn off the pcs.
    Unless you have techstream, based on that thread you need either a good dealer or no it cannot be recalibrated.
  9. May 5, 2019 at 2:29 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Mine was recalibrated and hasn’t had an issue since. With the lift, they need to calibrate the sensor and camera together. If one is done and not the other, you will get the malfunction again.
  10. May 6, 2019 at 7:47 AM
    schaderaide
    schaderaide New Member
    Orange County, CA
    I have an Icon Stage 3 lift and havent had any TSS related issues. The Dealer did recommend the re-calibration but for $550, I'm holding off until I actually have a problem. I have heard that once you go above 4" its more likely to see the TSS issues
  11. May 6, 2019 at 7:48 AM
    schaderaide
    Orange County, CA
    This still make absolutely zero sense to me. The recall should have nothing to do with the lift.
  12. May 18, 2019 at 6:28 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It’s getting to the point where some of us need to get attorneys. Like I stated earlier. I’ve had pcs issues for 15,000 miles before I lifted my truck 5000 miles ago. I am not releasing Toyota from their obligation to fix this faulty system just because I lifted my truck a couple thousand miles ago, the issue is pre-existing. I just don’t get it. It’s like Toyota is trying to save money and pass blame for a shitty design.
  13. May 31, 2019 at 8:53 AM
    rollingTide29
    rollingTide29 New Member
    Chase
    Murfreesboro, TN
    2019 MGM TRD Sport Crewmax
    I just brought my vehicle in for its first 5k service and was told they were not allowed to do the recall because it wasn't at stock height. I have 6112's set at 1.9" and a shackle in the rear. Hopefully not doing the recall won't affect anything.
  14. May 31, 2019 at 9:07 AM
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    Seriously?? Anything up to 3" doesn't even void any warranty, so how can they justify not doing the recall on a 2" lift??
    rollingTide29[QUOTED] likes this.
  15. May 31, 2019 at 9:18 AM
    rollingTide29
    Chase
    Murfreesboro, TN
    I'm wondering the same thing. I'm wondering if I need to try another dealer, or just ignore the recall since I haven't been affected by any sensor issues, yet.
  16. Nov 14, 2020 at 9:41 PM
    Sgasp90
    Sgasp90 New Member
    2020 trd pro tundra
    I’m having the same problems with my 2020 trd pro. Tried doing the paper clip truck but I don’t think it works with the newer modes. Got an appointment at the dealership this week hoping to get some good news. Mines got a 4 inch lift from ready lift.
