Wheels spacers required for TRD BBS wheels?
Discussion in 'Wheels & Tires' started by Alkare, Nov 14, 2020.
  1. Nov 14, 2020 at 12:02 PM
    Alkare
    Alkare [OP] New Member
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Anyone know if wheel spacers are required to install 2021 TRD BBS wheels on a 2017?
    I tried to install them and it looks like they are hitting the calipers?
  2. Nov 14, 2020 at 12:42 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    That should be a negative. Is your truck stock? Have a big brake kit? Wheels are interchangeable without issue on 3rd gens.
  3. Nov 14, 2020 at 12:43 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You do not need wheel spacers unless you’re running a wide tire
  4. Nov 14, 2020 at 1:09 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    No spacers needed, but it does run much closer to calipers than the stock wheels.
  5. Nov 14, 2020 at 1:19 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    I bought this truck as a lease return so I am guessing they are stock. I will try it again and see. I didn't realize that you have to have the original lug nuts for these wheels. Luckily the guy I bought the wheels from still had them.
  6. Nov 14, 2020 at 2:38 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Brain fart. Got them on.
