275 70 18 vs 295 65 18
Discussion in 'Wheels & Tires' started by Bertatundra29, Nov 12, 2020.
  1. Nov 12, 2020 at 11:02 AM
    Bertatundra29
    Bertatundra29 [OP] New Member
    2017 grey tundra platinum
    switching from 285 60 20s I run in the summer months to 18s for the winter im wondering which tire will look better. My offset on the rims I have is only +1 so it should stick out a bit. I'm losing .3 of a inch height wise running the 275 and .4 on the 295 just wondering what you guys run and like thanks
  2. Nov 12, 2020 at 12:45 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Thinner tire would give you more bite in snow and ice. The wider you go the more the trucks weight is spread out causing less downforce.
