Undercoat, or NOT to Undercoat ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ac762x39, Oct 5, 2020.
  1. Oct 8, 2020 at 4:43 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
  2. Oct 8, 2020 at 5:31 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I applied a heavy coat to it about this time last year and just checked it a few days ago, and it still looks brand new underneath, so I'm planning on every two years. As far as feeling it, it was slightly tacky after the initial installation, but now it seems completely dry. You can see in the pics i took last year some of the yellow haze on the sway-bar bushing brackets. Hope this helps.
  3. Oct 8, 2020 at 5:43 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
  4. Oct 8, 2020 at 6:11 PM
    TILLY
    Massachusetts
    I ended up using 6 cans in the end, which was enough to do everything including underneath the bed.
    mdrabicki and PWMDMD[QUOTED] like this.
  5. Nov 12, 2020 at 9:12 AM
    mdrabicki
    mdrabicki New Member
    Mark
    2020 Toyota Tundra TRD PRO
    I was using Fluid Film for years on my 2 cars and 2000 Tundra which was instrumental in keeping the frame rust problems to a minimum. The down side is that overspray or leakage of Fluid Film onto the softer rubber components like door, hood seals (weather stripping) ends up absorbing it turning it into an inflated mess. Another downside is that most of it washes off by the end of winter from the car washes and constant road under sprays so must be reapplied yearly. Since I have a new 2020 TRD Pro with virgin underside I wanted to try something new. So this is the first year I am switching over to trying Amsoil HD MP. I used 12 cans on my new truck and 6 cans a piece on the Civic SI and Acura RL. I coat everything, not just the frame rails and suspension components but the entire underside, removing all the rubber grommets under the rocker panels and spraying in there, door jambs, hinges, every nook and cranny where salt and brine can collect and eventually start the corrosion process, coated the wheel wells, inside bumpers, tow hitch, brake and fuel lines, brackets, heatshields and bolts and, removed the skid plate, spray up and everywhere in there..... With the Amsoil your limited to where your non flexible rubber straw can spray. So for the hard to reach areas, like inside the bottoms of the door panels, above the trans and above the gas tank I used fluid film with a 16" flexible hose that has a spreader tip allowing the lanolin to spray in all directions and coat everywhere --> https://www.amazon.com/Fluid-Film-Spray-Extension-Wand/dp/B00CLUGXFI . I used this flex tube inside the boxed frame rails (the front 1/3 of the frame) and popped out the rubber grommets in the doors on both the inner and outer sides to run the tube down and coat the inner bottom panels. I have a buddy that has a side business applying Fluid Film to cars so I learned a lot from him. Don't forget under the hood, and lightly spray any exposed nuts and bolts and hose clamps and brackets. All those rusted on my 2000 tundra from moisture and salt spray that would work its way under the hood while driving throughout winter so I learned from that and determined to make them last on this new truck. Amsoil (cosmoline) unlike the more liquidy Fluid Film (lanolin) in my experience has been safe on all plastic per my buddy who has been using it and just leaves a waxy coating on the surface of plastic/rubber rather than being absorbed like Fluid Film. In the end I used 12 cans of Amsoil HD MP and 5 cans of Fluid Film on my truck. Lets see how long each lasts :) Oh, I used 12 cans of Amsoil total over the course of 2 days. I went back over a second day approaching the truck (on ramps) this time from the front instead of rear and saw a bunch of places that I either missed or I left only a very thin coating on since the amber color looked light so I went over everything again, second coat just to be sure. A case of 12 Amsoil HD MP cans if you sign up for the Amsoil club ends up being a little less than $130 shipped
  6. Nov 12, 2020 at 12:45 PM
    ac762x39
    ac762x39 [OP] New Member
    A.C.
    2015 Tundra
    I finally had time to apply Fluid film to my truck. I got 6 cans from Amazon, but only used 4. I was a little conservative when applying it. Now the waiting game begins.
  7. Nov 12, 2020 at 1:16 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    Yeah, but I'm sayin', that TruCoat, you don't get it and you get oxidization problems. It'll cost you a heck of lot more'n five hundred
    I'll talk to my boss. See, they install that TruCoat at the factory, there's nothin' we can do, but I'll talk to my boss.
    made me think of Fargo. Obviously I don’t have any undercoat on mine.
  8. Nov 14, 2020 at 3:37 AM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    I have used ACF-50 for years with good results on my trucks and motorcycles. It creeps. My '20 PRO has been through one nasty winter and still looks exceptional. I tried Krown and Fluid Film on previous trucks, both professionally applied, and went back to doing it myself with ACF-50. I don a hazmat suit, do two spray-the-shit out of everything & wipe sessions, and settle in for our long winter.
  9. Nov 14, 2020 at 4:04 AM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    I'm doing either Krown or Woolwax in a couple of weekends from now. Have used Krown for many years with good results, never used Woolwax.
  10. Nov 15, 2020 at 4:31 PM
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Another vote for Krown here. Did to my 2016DC since new and was happy with the results. My 2020 is getting the same.
