Custom Glocks Please!!
Discussion in 'Guns & Hunting' started by Rngr188, Oct 9, 2020.
  1. Nov 6, 2020 at 6:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Someone else on here mentioned it already, but I’ll add some pictures:
    Get a P80 and then Gucci the f*ck out of it. Glock is to pistols what the AR is to long guns - once you’ve got the frame, your only limits are your imagination and your budget. I was never a fan of “true” Glocks - the grip angle just didn’t feel right to me. But the P80 gives you back the grip angle of a 1911 and all the customization options of a Glock. This one is the PF940Cv1 in gray.
    2B4AC485-AA15-4CF0-9E95-DC111DC9E464.jpg 009154B1-06D7-4326-8567-8C5339432C20.jpg 32F55400-6CB2-41A4-B469-5C89FE602787.jpg
    Of course, don’t discredit the Sig P320. The “gun” is the serialized internal frame with the slide rails and all the fire control parts (trigger, sear, etc.) and EVERYTHING else is modular. The after-market options for these is growing fast now too, as evident in this build (the only thing factory is the internal parts in the FCU...).
    GODZILLA and Skew12 like this.
  2. Nov 6, 2020 at 7:31 PM
    mbn225
    mbn225 New Member
    Louisiana
    2008 Tundra Crewmax TRD
    Rock Warrior Bits Flowmaster exhaust 3/1 Lift
    43X
    kittyhawk and equin like this.
  3. Nov 7, 2020 at 9:40 AM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    If your looking for a 19 to customize, 23s are usually easier to find since 40s are less desirable and the frame is the same. There are conversion barrels available in whatever flavor you want. Also if anyone in central California is looking for a 23 I’ll give someone a tundra forum discount. Already comes with a lone wolf or storm lake (can’t remember now) and ported barrel and night sights.
  4. Nov 7, 2020 at 10:35 AM
    Cummins3500
    Logan
    Little glock 43 action.
    mods:
    *True precision barrel
    *Over watch precision tac trigger
    *grey ghost connector and springs
    *true precision +2 mag extension
    yet to go on the gun
    *tyrant designs extended mag release
    *tyrant designs extended slide stop
    Patch999 and Ely010606 like this.
  5. Nov 9, 2020 at 8:37 AM
    Kung
    KG, VA
    What do you think of it so far? I was able to get a Glock 43 yesterday new for right around $370, so I couldn't pass it up. It'd be nice to have >6 rds (OEM), but I can get an aftermarket mag or two for that. Next might be a P365 or G43x.
    Cummins3500[QUOTED] likes this.
  6. Nov 9, 2020 at 10:12 AM
    Cummins3500
    Logan
    I wasn’t a fan of the trigger right out of the box. It’s definitely shootable now with the trigger work. In fairness though I’m a 1911 fan through and through. The 43 replaced a sig 938. I do like how easily concealable it is. I mainly got it to try it. I’ll keep it but I’m not sure how long it’ll pull carry duties. I’ve been looking at the sig 365’d pretty hard
  7. Nov 9, 2020 at 10:19 AM
    18" TRD Off Road Wheels
    Go handle a 365 for a while before you decide to get one. Lots of people like the gun but says it feels weird because of how thing the grip is, especially those with larger hands.
  8. Nov 9, 2020 at 10:28 AM
    TheTripleLindy
    TheTripleLindy New Member
    Not starting a :crapstorm:
    Just saw this and thought it was funny.
    773_eddie, CourtJester and B33 like this.
  9. Nov 9, 2020 at 10:31 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Like I said above, I am more of a simple man.
    Here's a couple of mine.
    O.S.T.
    GLOCK 43X GEN 5, 19 GEN 3, 17 GEN 2
    MY "TRICKED OUT" 43X NOW. LOL. (Recover Tactical Slide Rack, TruGlo Brite-Site Tritium Slight)
    Another Photo.
  10. Nov 10, 2020 at 4:19 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    Don’t get aftermarket mags, just buy Glock mags and replace the floor plates with a +2 extension. I had Hyve plates on mine and they worked great.
    Sephon likes this.
  11. Nov 10, 2020 at 6:27 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    I run many different aftermarket mags. For my G19 Gen 4, I learned that it doesn't like KCI mags. It just has a difficult time releasing the mag but I've never had a failure to feed. Glock mags and base plates are overpriced, in my opinion. They also print more if you plan on using it for an EDC.
  12. Nov 10, 2020 at 8:06 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    I run the +2 Hyve plates on my 43 as well. They are great!
    Hurricane[QUOTED] likes this.
  13. Nov 10, 2020 at 10:01 AM
    Hurricane
    NC
    2017 White 1794
    None
    The problem you have is that no one really makes a decent mag for the 43 besides Glock. ETS mags are garbage and KCI is so hit and miss that’s it’s not worth the headache. I would suggest magpul mags but they don’t make a mag for the 43. So you are pretty much stuck with the Glock factory mags. $30 is pretty cheap when my life might depend on it.
  14. Nov 10, 2020 at 10:08 AM
    FIFY
    :boink:
  15. Nov 10, 2020 at 10:47 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I've got a Hyve +2 and I get feeding issues on the last couple rounds occasionally. I really want to like it but I can't trust it for carry. :(
  16. Nov 10, 2020 at 11:14 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Added a privateer plate to spruce it up. Had to get the zev off there. It’s the little things. A130164C-B515-4CBA-8ACE-46C7F077CEBE.jpg
    Patch999 likes this.
  17. Nov 11, 2020 at 12:41 PM
    Sephon
    Northwest PA
    That sucks, I would contact Hyve. I've got it on 3 mags and I've put thousands of rounds through them and never had a problem.
    Hurricane likes this.
  18. Nov 12, 2020 at 7:02 AM
    Kung
    KG, VA
    So I found out the other day that I (veteran, but not disabled/retired/active) could get in on the Glock Blue Label program. ALSO found out it was for the 'household' - not just me.
    Wife said "Oh REALLY...." and we left the local gun shop/range with this for her yesterday. She LOVES it. Glock 19X, comes with 3 magazines, cleaning kit, lock. I'll likely buy one myself in a few weeks.
  19. Nov 12, 2020 at 7:06 AM
    XSP2020
    XSP2020 New Member
    Atlanta Ga
    2020 Black Tundra XSP
  20. Nov 12, 2020 at 8:07 AM
    #50
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
  21. Nov 12, 2020 at 8:11 AM
    #51
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Super duper like
